[征集]你玩AI,我送幸运,为AI套件专区添砖加瓦--4角蜂鸟AI视觉套件:(四)ROS下订阅并处理图像
对于熟悉ROS的朋友们来说,图像的topic有了,我们就可以开始自己想干的事情了。这里我创建一个名为hs_image_sub的package来处理角蜂鸟的图像,图像的topic 名字为上一篇提到的:/hs/camera/image_raw. 也是我们打开rqt_image_view窗口看到的东西。 这篇博客主要是利用opencv来获取角蜂鸟图像,然后做一个阈值处理,并且打开窗口显示原图和处理后的图像。有了opencv想做什么处理都可以了,这篇文章主要是教大家在ROS里获取并调用图像。 cd ~/catkin_ws/src catkin_create_pkg hs_image_sub roscpp sensor_msgs cv_bridge
然后 cd ~/catkin_ws/src/hs_image_sub/src touch hs_image_sub_node.cpp gedit hs_image_sub_node.cpp
填入以下代码
#include <ros/ros.h> #include <sensor_msgs/Image.h> #include <sensor_msgs/image_encodings.h> #include <image_transport/image_transport.h> #include <cv_bridge/cv_bridge.h> // OpenCV #include <opencv2/opencv.hpp> #include <opencv2/imgproc/imgproc.hpp> #include <opencv2/highgui/highgui.hpp> using namespace std; using namespace cv; const string Original_winName = "Original Image"; const string Thresh_winName = "Threshed Image"; Mat cameraFeed; Mat HSV; Mat threshold_ori; void rgbCallback(const sensor_msgs::ImageConstPtr& msg) { cv_bridge::CvImageConstPtr cv_ptr; try { cv_ptr = cv_bridge::toCvCopy(msg, sensor_msgs::image_encodings::BGR8); // Caution the type here. } catch (cv_bridge::Exception& ex) { ROS_ERROR("cv_bridge exception in rgbcallback: %s", ex.what()); exit(-1); } cameraFeed = cv_ptr->image.clone(); cvtColor(cameraFeed,HSV,COLOR_BGR2HSV); inRange(HSV,Scalar(0,133,0),Scalar(21,256,256),threshold_ori); //show frames imshow(Original_winName,cameraFeed); imshow(Thresh_winName,threshold_ori); //delay 10ms so that screen can refresh. //image will not appear without this waitKey() command waitKey(10); } int main(int argc, char *argv[]) { ros::init(argc, argv, "HornedSungemGrabber"); ros::NodeHandle n; // topic name of HornedSungem ros::Subscriber rgb_sub = n.subscribe("/hs/camera/image_raw", 1, rgbCallback); ROS_INFO("Subscribe to the HS color image topic."); ros::spin(); return 0; }
代码比较简单,主要是订阅图像源,调用回调函数做阈值处理。 注意这里的topic name 和回调函数里的格式:BGR8,只能是这个。
保存,然后 cd ~/catkin_ws/src/hs_image_sub/ gedit CMakeLists.txt 全选,替换为以下内容
cmake_minimum_required(VERSION 2.8.3) project(hs_image_sub) find_package(OpenCV REQUIRED) find_package(catkin REQUIRED COMPONENTS cv_bridge roscpp sensor_msgs ) catkin_package( # INCLUDE_DIRS include # LIBRARIES hs_image_sub # CATKIN_DEPENDS cv_bridge roscpp sensor_msgs # DEPENDS system_lib ) include_directories( # include ${catkin_INCLUDE_DIRS} ) add_executable(${PROJECT_NAME}_node src/hs_image_sub_node.cpp) target_link_libraries(${PROJECT_NAME}_node ${catkin_LIBRARIES} ${OpenCV_LIBS} )
接着编译 cd ~/catkin_ws catkin_make
看到编译成功,运行角蜂鸟ROS的官方程序,启动相机发布图像源,来供我们这里的程序调用 roslaunch horned_sungem_launch hs_camera.launch cnn_type:=googlenet camera:=hs pixels:=360
rosrun hs_image_sub hs_image_sub_node
有了opencv想做什么处理都可以了比如追踪
版权声明:本文为博主原创文章,如需转载,请附上文章原文地址。 https://blog.csdn.net/yaked/article/details/81477833
