查看: 3129|回复: 0
GD32方案分享⑧:PWM实验
  • 签到天数: 7 天
    发表于 2017-5-27 23:45:51 | 显示全部楼层 |阅读模式
    因为我们需要驱动电机,所以我们需要输出PWM波,参照例程中的PWM例子进行修改
    PWM频率 = (当前主频(200Mhz)/(period+1))/(prescaler+1)
    通道占空比 = (duty/period)*100%
    分别输出了 50% 10Khz的PWM波 90% 10Khz的PWM波
    1. #include "PWM.h"
    2. void PWM_Init(void)
    3. {
    4.    rcu_periph_clock_enable(RCU_GPIOB);
    5.
    6.     gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_3);
    7.     gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_3);
    8.     gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_10);
    9.     gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_10);
    10.     gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_11);
    11.     gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_11);
    12.     gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_3);
    13.     gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_10);
    14.     gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_11);
    15.     timer_oc_parameter_struct timer_ocintpara;
    16.     timer_parameter_struct timer_initpara;
    17.     rcu_periph_clock_enable(RCU_TIMER1);
    18.     rcu_timer_clock_prescaler_config(RCU_TIMER_PSC_MUL4);
    19.     timer_deinit(TIMER1);
    20.     /* TIMER1 configuration */
    21.     timer_initpara.prescaler         = 1;
    22.     timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    23.     timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    24.     timer_initpara.period            = 9999;
    25.     timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    26.     timer_initpara.repetitioncounter = 0;
    27.     timer_init(TIMER1,&timer_initpara);
    28.     /* CH1,CH2 and CH3 configuration in PWM mode1 */
    29.     timer_ocintpara.ocpolarity  = TIMER_OC_POLARITY_HIGH;
    30.     timer_ocintpara.outputstate = TIMER_CCX_ENABLE;
    31.     timer_channel_output_config(TIMER1,TIMER_CH_1,&timer_ocintpara);
    32.     timer_channel_output_config(TIMER1,TIMER_CH_2,&timer_ocintpara);
    33.     timer_channel_output_config(TIMER1,TIMER_CH_3,&timer_ocintpara);
    34.     /* CH1 configuration in PWM mode1,duty cycle 25% */
    35.     timer_channel_output_pulse_value_config(TIMER1,TIMER_CH_1,1999);
    36.     timer_channel_output_mode_config(TIMER1,TIMER_CH_1,TIMER_OC_MODE_PWM0);
    37.     timer_channel_output_shadow_config(TIMER1,TIMER_CH_1,TIMER_OC_SHADOW_DISABLE);
    38.     /* CH2 configuration in PWM mode1,duty cycle 50% */
    39.     timer_channel_output_pulse_value_config(TIMER1,TIMER_CH_2,4999);
    40.     timer_channel_output_mode_config(TIMER1,TIMER_CH_2,TIMER_OC_MODE_PWM0);
    41.     timer_channel_output_shadow_config(TIMER1,TIMER_CH_2,TIMER_OC_SHADOW_DISABLE);
    42.     /* CH3 configuration in PWM mode1,duty cycle 75% */
    43.     timer_channel_output_pulse_value_config(TIMER1,TIMER_CH_3,8999);
    44.     timer_channel_output_mode_config(TIMER1,TIMER_CH_3,TIMER_OC_MODE_PWM0);
    45.     timer_channel_output_shadow_config(TIMER1,TIMER_CH_3,TIMER_OC_SHADOW_DISABLE);
    46.     /* auto-reload preload enable */
    47.     timer_auto_reload_shadow_enable(TIMER1);
    48.     /* auto-reload preload enable */
    49.     timer_enable(TIMER1);
    50. }
    明天开始搭建小车硬件 附件: myGD32 - 副本.rar (7.42 MB, 下载次数: 16)
    GMT+8, 2024-4-18 19:42 , Processed in 0.111454 second(s), 16 queries , MemCache On.
