查看: 3300|回复: 0
盈鹏飞EVB335x试用之六:DTU的设计实现
  • 签到天数: 75 天
    发表于 2018-6-6 09:54:49 | 显示全部楼层 |阅读模式
        DTU用于实现电网保护,下面挂很多FTU,通过网线或串口线与维护机通信进行配置监视等,通过网口或串口与管理部分通信接收监控,所以串口应用比较多,一般应该有双网口。试用的板子只有一个网口,也是设计 测试阶段,就采用一个WIFI模块实现了另一个网口。
    DTU需要通过IEC101协议与维护计算机通信,获取对各种FTU和线损模块的配置和测控信息。配置信息包括各个模块的链路地址、遥信、遥控、遥测、电量、SOE等容量、国标地址和名称、定值区号、动作参数等。程序设计的核心是IEC101协议的实现,该协议定义的数据帧结构如下
    一个与维护机通信的例程如下
    //DTU接收主站报文
    void SlaveRec(BYTE recByte)
      switch (m_SReadState)
      case StartByte:
               m_SRecByte[0] = recByte;
               if (m_SRecByte[0] == 0x10)m_SReadState = CtrlByte;
           else if (m_SRecByte[0] == 0x68)m_SReadState = Num_68H_1;
           break;
        //===========  启动字符为68H  ==========//
      case Num_68H_1:
               m_SRecByte[1] = recByte;
           m_SReadState  = Num_68H_2;
               break;
      case Num_68H_2:
               m_SRecByte[2] = recByte;
               if (m_SRecByte[2] == m_SRecByte[1])
               m_SReadState = Start_68H_2;
               else
               m_SReadState = StartByte;
               break;
      case Start_68H_2:
               m_SRecByte[3] = recByte;
           if (m_SRecByte[3] == 0x68)
                       m_MsgIndex   = 0;
                       m_SReadState = Msg_68H;
               else
               break;
      case Msg_68H:
               m_SRecByte[4+m_MsgIndex] = recByte;
               if (m_MsgIndex < (m_SRecByte[1]-1))   // 如读取的字节数小于信息字节数,则继续读取
                       m_MsgIndex++;
               else
                       m_SReadState = Check_68H;
                       m_MsgIndex   = 0;
               break;
      case Check_68H:
           m_SRecByte[4+m_SRecByte[1]] = recByte;
           BYTE tembyte;
           tembyte = GetAddByte(m_SRecByte,m_SRecByte[1],4);
               if (m_SRecByte[4+m_SRecByte[1]] == tembyte)
               m_SReadState = End_68H;
               else
               break;
      case End_68H:              //启动字符为68H的报文接收完毕,解包
               m_SRecByte[5+m_SRecByte[1]] = recByte;
               if (m_SRecByte[5+m_SRecByte[1]] == 0X16 &&
                       m_SRecByte[5] == m_Addr)
                       SUnPack_Start68H();    //解包
               break;
      default:
           m_SReadState = StartByte;      //重新从地址码读取
               break;
    GMT+8, 2024-4-24 12:35 , Processed in 0.128491 second(s), 17 queries , MemCache On.
