查看: 3265|回复: 2
【角蜂鸟试用】数字识别模型 mnist 的使用
    2022-4-28 09:50
  • 签到天数: 443 天
    发表于 2018-8-28 16:37:34 | 显示全部楼层 |阅读模式
    大概操作步骤 :
    1  在 misc 目录下新建目录mnist_test ,添加图片    4.jpg   ;
    2  在 apps 目录下 新建目录mytest   新建mnist_test1.py , 编辑如下代码:
    #加载OpenCV、Numpy以及角蜂鸟HSAPI
    import cv2, sys, numpy as np
    sys.path.append('../../../')
    import hsapi as hs
    # 初始化角蜂鸟、设定内置加载模型、识别对象图片的根目录
    net = hs.HS('mnist')
    imgroot = '../../misc/mnist_test/4.jpg'
    print('mnist test 1')
    img = cv2.imread(imgroot)
    result = net.run(img)
    print(result[1])
    net.q
    3 终端输入命令:
    sudo  chmod 777   mnist_test1.py
    python3 mnist_test1.py
    可以惊奇的看到效果:
    注意:
    代码倒数第二行,如果使用  print(result)
    则会返回结果:
    | ======= Horned Sungem ======== |
    |        Device index [0]        |
    |          Graph:mnist           |
    |    ../../graphs/graph_mnist    |
    |     Model loaded to Python     |
    |   Model allocated to device    |
    my mnist test 1
    [array([[  0,   0,   0,   0,   0,   0,   0,   0,   0,   6,   2,   0,   0,
              7,   3,   0,   2,  12,   0,  11,   1,   2,   3,   0,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,   8,   0,   1,   6,   0,
              2,  10,   0,   2,   0,   4,   0,   0,   0,  11,   5,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,   0,   7,   0,   0,   8,
              0,   0,  14,   0,   3,  13,   7,  14,   4,   0,   0,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,   8,   0,   3,   9,   0,
              0,   0,   0,   6,   5,   0,   0,   0,   2,   5,   9,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,   0,   8,   8,   0,   0,
              1,   1,  12,   0,  16,  17,  11,   0,   0,  25,   0,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,  19,   4,   0,  38, 135,
            226, 254, 240, 255, 247, 244, 252, 239,  14,   0,  13,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,   0,  53, 209, 255, 235,
            237, 255, 250, 249, 253, 255, 245, 255, 151,  16,   0,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,  49, 228, 255, 237, 232,
            139, 110, 248, 142,  23, 106, 255, 243, 255,  96,   3,   0,   0,
              0,   0],
           [  0,   4,   3,   0,   0,   3,   0,  14, 157, 255, 255, 162,  20,
              6,   7, 190,  74,   0,  10,  34, 203, 255, 114,   1,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   7,   2,  11,  76, 255, 237, 202, 183,   0,
              2,   0, 129,  34,  26,   0,  76, 237, 250, 102,   1,   0,   0,
              0,   0],
           [  2,   0,   0,   0,   7,   0,  13, 117, 255, 255, 240,  34,  10,
              0,  21,   0,   9,   0,  11, 195, 255, 240,   5,  12,   0,   0,
              0,   0],
           [  3,   2,   0,   0,   7,   0,   5, 110, 255, 233,  74,  13,   3,
              1,   0,  11,   6,  91, 218, 255, 225,  69,  27,   0,   0,   0,
              0,   0],
           [  0,   0,   0,   0,  11,   0,   3,  70, 235, 255, 163,  55,  35,
             26, 173, 210, 196, 241, 243, 213, 100,   1,   0,   0,   0,   0,
              0,   0],
           [  0,   0,   1,   0,   3,   4,   0,  15, 136, 255, 250, 229, 236,
            216, 255, 250, 255, 238, 177,  16,   0,   0,   0,  11,   0,   0,
              0,   0],
           [  2,   0,   4,   0,   0,   0,   0,   0,  22, 166, 251, 244, 254,
            253, 250, 250, 255, 210,  51,  22,   3,   4,   0,   5,   0,   0,
              0,   0],
           [  1,   0,   5,   2,   0,   6,   8,   2,   0,  28, 232, 255, 255,
            247, 255, 246, 251, 255, 252, 104,   0,   0,   6,   0,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,  24, 200, 243, 239, 207,
             97, 113, 249, 212, 239, 255, 204,  75,   0,   0,  12,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0, 102, 247, 253,  92,   0,
              0,  19, 121,  57,  91, 250, 241, 190,   1,   0,   0,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0, 197, 255, 192,   4,   0,
             11,   0,   0,   7,   3, 208, 241, 236,   0,   8,   0,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0, 226, 247, 235,  21,   9,
              0,   7,  16,   0,  24, 210, 255, 201,   4,   0,   3,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0, 231, 237, 255,  40,   0,
             11,   0,   0,  19, 131, 255, 246,  96,   0,   0,   2,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,  94, 255, 243, 127,  34,
              0,   5,  59, 168, 248, 250, 124,   0,   0,  15,   2,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,  49, 242, 245, 247, 208,
            135, 177, 251, 255, 234, 140,  27,   0,   5,   9,   0,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,   2,  34, 238, 255, 249,
            255, 255, 249, 246, 134,   6,   0,   2,   6,   0,  10,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,   0,  15,  98, 116, 246,
            247, 246, 159,  24,  12,   0,   0,   0,   4,   1,   0,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,   0,   0,  13,   0,   7,
              0,  16,   1,   9,   3,   0,   0,   2,   5,   4,   0,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,   1,   1,   4,   9,   0,
              0,   0,   0,   0,   0,   0,   0,   3,   4,   2,   0,   0,   0,
              0,   0],
           [  0,   0,   0,   0,   0,   0,   0,   0,   1,   0,   0,   4,   8,
             13,   2,   6,   0,   0,   1,   2,   1,   0,   0,   0,   0,   0,
              0,   0]], dtype=uint8), 8]
    这说明 执行 net.run(img),返回的 result 包含两个参数(图像矩阵,检测结果),分别放置在 result[0] 与 result[1]
    2018-9-10 10:24
  • 签到天数: 2 天
    发表于 2018-9-10 10:21:06 | 显示全部楼层
    modivuous的计算棒怎么样??
    2022-4-28 09:50
  • 签到天数: 443 天
     楼主| 发表于 2018-9-13 08:49:05 | 显示全部楼层
    xf622-246882 发表于 2018-9-10 10:21
    modivuous的计算棒怎么样??
    网上看了一些文章 把 modivuous  介绍得相当完美, 誉为GPU的首选良品。据说反应速度快,计算效果好,坐等降价了入手玩一玩。
    GMT+8, 2024-4-24 08:03 , Processed in 0.127637 second(s), 20 queries , MemCache On.
