查看: 1441|回复: 0
芯灵思SinlinxA33开发板Linux中断编程4-最终代码(1)
  • 签到天数: 9 天
    发表于 2019-2-13 16:11:17 | 显示全部楼层 |阅读模式
    按键驱动代码:
    1. #include <linux/module.h>
    2. #include <linux/fs.h>
    3. #include <linux/miscdevice.h>
    4. #include <linux/interrupt.h>
    5. #include <linux/irq.h>
    6. #include <linux/gpio.h>
    7. #include <asm/uaccess.h>
    8. #include <linux/delay.h>
    9. #include <linux/sched.h>
    10. #define DEVICE_BUTTON  "mybtn"
    11. #define BTN_MAJOR   255
    12. static char keybuf[] = {"0"};
    13. static struct miscdevice misc = {
    14.     .minor = BTN_MAJOR,
    15.     .name  = DEVICE_BUTTON,
    16. };
    17. irqreturn_t key_isr(int irq, void* dev)
    18. {
    19.     int btn = 0;
    20.         //读取按键状态
    21.     btn= !gpio_get_value(GPIOL(14));
    22.     printk("key %s\r\n",  btn ? "down" : "up");
    23.         //把按键状态更新到对应的按缓冲中
    24.         keybuf = “0” + btn;
    25.     return IRQ_HANDLED;
    26. }
    27. static ssize_t btn_read  (struct file *flp, char __user *buff, size_t count, loff_t * off)
    28. {
    29.     int ret ;
    30.         if(!count) {
    31.          return 0;
    32.     }
    33.     ret = copy_to_user(buff, keybuf, count);
    34.     if(ret) {
    35.         printk("error:copy_to_user\r\n");
    36.         return -EFAULT;
    37.     }
    38.     return count;
    39. }
    40. static const struct file_operations dev_fops = {
    41.     .read   =   btn_read ,
    42.     .owner  =   THIS_MODULE,
    43. };
    44. static int __init btn_init(void)
    45. {
    46.     int ret;
    47.     int irq;
    48.     int flags;
    49.     flags = IRQ_TYPE_EDGE_BOTH;
    50.     irq = gpio_to_irq( GPIOL(14) );
    51.         //发生中断号为irq的中断会执行key_isr函数。注册成功会在/proc/irq号/KEY文件夹出现或 cat /proc/interrupts, 记录了本中断发生的次数cat /proc/irq/442/spurious
    52.     ret = request_irq(irq,key_isr, flags, "KEY",NULL);
    53.     if(ret < 0)
    54.     {
    55.            irq = gpio_to_irq( GPIOL(14) );
    56.            disable_irq(irq);
    57.            free_irq(irq, NULL);
    58.            return ret;
    59.     }
    60.     ret = misc_register(&misc);
    61.     printk(KERN_EMERG " Device registered \n ");
    62.     return ret;
    63. }
    64. static void __exit btn_exit(void)
    65. {
    66.     int irq;
    67.     irq = gpio_to_irq( GPIOL(14) );
    68.     disable_irq(irq);
    69.     free_irq(irq, NULL);
    70.     misc_deregister(&misc);
    71.     printk(KERN_EMERG " Equipment logged out \n");
    72. }
    73. module_init(btn_init);
    74. module_exit(btn_exit);
    75. MODULE_LICENSE("GPL");
    测试应用代码:
    1. #include <stdio.h>
    2. #include <stdlib.h>
    3. #include <string.h>
    4. #include <sys/types.h>
    5. #include <sys/stat.h>
    6. #include <fcntl.h>
    7. #include <unistd.h>
    8. #include <sys/ioctl.h>
    9. #include <sys/types.h>
    10. #include <errno.h>
    11. #define  DEV_NAME    "/dev/mybtn"
    12. int main(int argc, char *args[])
    13. {
    14.     int fd = 0;
    15.     int ret = 0;
    16.     unsigned char recv_buf[1] = {"0"};
    17.     fd = open(DEV_NAME, O_RDONLY);
    18.     //fd = open(DEV_NAME, O_RDONLY|O_NONBLOCK);
    19.     if(fd < 0) {
    20.         perror("open");
    21.     }
    22.     while(1) {
    23.         strcpy(recv_buf, "0000");
    24.         //读取按键数据
    25.         ret = read(fd, recv_buf, 1);
    26.         if((ret < 0) && (errno != EAGAIN)) {
    27.             perror("read");
    28.             exit(-1);
    29.         }
    30.         //输出按键状态
    31.         printf("%s\r\n", recv_buf);
    32.     }
    33.     return 0;
    34. }
    Makefile代码:
    1. KERN_DIR = /work/lichee/linux-3.4
    2. all:
    3.         make -C $(KERN_DIR) M=`pwd` modules
    4.         arm-none-linux-gnueabi-gcc  btntest.c -o btntest
    5. clean:
    6.         make -C $(KERN_DIR) M=`pwd` modules clean
    7.         rm -rf modules.order
    8. obj-m        += btn_drv.o
    遗憾的是,代码虽然能编译成功,但是驱动加载有错误,等找出原因再发帖补充,开发板交流群 QQ:641395230
    GMT+8, 2024-4-19 14:07 , Processed in 0.119779 second(s), 16 queries , MemCache On.
