查看: 2048|回复: 0
角蜂鸟AI视觉套件:(四)ROS下订阅并处理图像
    发表于 2019-3-5 15:07:07 | 显示全部楼层 |阅读模式
    对于熟悉ROS的朋友们来说,图像的topic有了,我们就可以开始自己想干的事情了。这里我创建一个名为hs_image_sub的package来处理角蜂鸟的图像,图像的topic 名字为上一篇提到的:/hs/camera/image_raw. 也是我们打开rqt_image_view窗口看到的东西。
    这篇博客主要是利用opencv来获取角蜂鸟图像,然后做一个阈值处理,并且打开窗口显示原图和处理后的图像。有了opencv想做什么处理都可以了,这篇文章主要是教大家在ROS里获取并调用图像。
    1. cd ~/catkin_ws/src
    2. catkin_create_pkg hs_image_sub roscpp sensor_msgs cv_bridge
    然后
    1. cd ~/catkin_ws/src/hs_image_sub/src
    2. touch hs_image_sub_node.cpp
    3. gedit hs_image_sub_node.cpp
    填入以下代码
    1. #include <ros/ros.h>
    2. #include <sensor_msgs/Image.h>
    3. #include <sensor_msgs/image_encodings.h>
    4. #include <image_transport/image_transport.h>
    5. #include <cv_bridge/cv_bridge.h>
    6. // OpenCV
    7. #include <opencv2/opencv.hpp>
    8. #include <opencv2/imgproc/imgproc.hpp>
    9. #include <opencv2/highgui/highgui.hpp>
    10. using namespace std;
    11. using namespace cv;
    12. const string Original_winName = "Original Image";
    13. const string Thresh_winName = "Threshed Image";
    14. Mat cameraFeed;
    15. Mat HSV;
    16. Mat threshold_ori;
    17. void rgbCallback(const sensor_msgs::ImageConstPtr& msg)
    18. {
    19.     cv_bridge::CvImageConstPtr cv_ptr;
    20.     try
    21.     {
    22.         cv_ptr = cv_bridge::toCvCopy(msg, sensor_msgs::image_encodings::BGR8); // Caution the type here.
    23.     }
    24.     catch (cv_bridge::Exception& ex)
    25.     {
    26.         ROS_ERROR("cv_bridge exception in rgbcallback: %s", ex.what());
    27.         exit(-1);
    28.     }
    29.     cameraFeed = cv_ptr->image.clone();
    30.     cvtColor(cameraFeed,HSV,COLOR_BGR2HSV);
    31.     inRange(HSV,Scalar(0,133,0),Scalar(21,256,256),threshold_ori);
    32.
    33.     //show frames
    34.     imshow(Original_winName,cameraFeed);
    35.     imshow(Thresh_winName,threshold_ori);
    36.     //delay 10ms so that screen can refresh.
    37.     //image will not appear without this waitKey() command
    38.     waitKey(10);
    39. }
    40. int main(int argc, char *argv[])
    41. {
    42.     ros::init(argc, argv, "HornedSungemGrabber");
    43.     ros::NodeHandle n;
    44. //        topic name of HornedSungem
    45.     ros::Subscriber rgb_sub = n.subscribe("/hs/camera/image_raw", 1, rgbCallback);
    46.     ROS_INFO("Subscribe to the HS color image topic.");
    47.     ros::spin();
    48.     return 0;
    49. }
    代码比较简单,主要是订阅图像源,调用回调函数做阈值处理。
    注意这里的topic name 和回调函数里的格式:BGR8,只能是这个。
    保存,然后
    gedit CMakeLists.txt
    全选,替换为以下内容
    1. cmake_minimum_required(VERSION 2.8.3)
    2. project(hs_image_sub)
    3. find_package(OpenCV REQUIRED)
    4. find_package(catkin REQUIRED COMPONENTS
    5.   cv_bridge
    6.   roscpp
    7.   sensor_msgs
    8. )
    9. catkin_package(
    10. #  INCLUDE_DIRS include
    11. #  LIBRARIES hs_image_sub
    12. #  CATKIN_DEPENDS cv_bridge roscpp sensor_msgs
    13. #  DEPENDS system_lib
    14. )
    15. include_directories(
    16. # include
    17.   ${catkin_INCLUDE_DIRS}
    18. )
    19. add_executable(${PROJECT_NAME}_node src/hs_image_sub_node.cpp)
    20. target_link_libraries(${PROJECT_NAME}_node
    21.    ${catkin_LIBRARIES} ${OpenCV_LIBS}
    22. )
    接着编译
    1. cd ~/catkin_ws
    2. catkin_make
    看到编译成功,运行角蜂鸟ROS的官方程序,启动相机发布图像源,来供我们这里的程序调用
    1. roslaunch horned_sungem_launch hs_camera.launch cnn_type:=googlenet camera:=hs pixels:=360
    2. rosrun hs_image_sub hs_image_sub_node
    有了opencv想做什么处理都可以了比如追踪
    作者:yaked
    来源:CSDN
    相关文章阅读
    (一)开箱及软件开发环境配置
    (二)人工智能深度体验
    (三)ROS案例
    (四)ROS下订阅并处理图像
    GMT+8, 2024-4-19 15:37 , Processed in 0.117756 second(s), 16 queries , MemCache On.
