查看: 1210|回复: 0
明远智睿MY-IMX6-EK200 Linux-4.1.15测试手册v2.0(2)
    2016-8-19 09:36
    发表于 2019-3-14 15:44:54 | 显示全部楼层 |阅读模式
    【接上一章节明远智睿MY-IMX6-EK200 Linux-4.1.15测试手册v2.01)】
    2.10  GPIO-KEY测试
      【测试说明】:使用 evtest 进行测试
      【接口标识】:KEY3, KEY2, KEY1
      【系统接口】:/dev/input/eventX
    测试操作
      运行 evtest 准备测试
    =====> 输入指令:
    evtest
    =====> 输出信息:
    No device specified, trying to scan all of /dev/input/event*
    Available devices:
    /dev/input/event0:  WM8962 Beep Generator
    /dev/input/event1:  gpio-keys
    Select the device event number [0-1]:
      选择 gpio-keys 所对应的序号
    =====> 输入指令:
    1
    =====> 输出信息:
    Input driver version is 1.0.1
    Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100
    Input device name: "gpio-keys"
    Supported events:
      Event type 0 (EV_SYN)
      Event type 1 (EV_KEY)
        Event code 114 (KEY_VOLUMEDOWN)
        Event code 115 (KEY_VOLUMEUP)
        Event code 116 (KEY_POWER)
    Properties:
    Testing ... (interrupt to exit)
      按动开发板上的按键
    Event: time 1537921332.815219, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 1
    Event: time 1537921332.815219, -------------- SYN_REPORT ------------
    Event: time 1537921332.985211, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 0
    Event: time 1537921332.985211, -------------- SYN_REPORT ------------
    Event: time 1537921335.355204, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 1
    Event: time 1537921335.355204, -------------- SYN_REPORT ------------
    Event: time 1537921335.535203, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 0
    Event: time 1537921335.535203, -------------- SYN_REPORT ------------
    Event: time 1537921337.375207, type 1 (EV_KEY), code 116 (KEY_POWER), value 1
    Event: time 1537921337.375207, -------------- SYN_REPORT ------------
    Event: time 1537921337.535204, type 1 (EV_KEY), code 116 (KEY_POWER), value 0
    Event: time 1537921337.535204, -------------- SYN_REPORT ------------
    测试结果
      当发生按键时,evtest 会输出相应的信息。
    2.11  串口测试(UART2)
      【测试说明】:采用串口自发自收的方式进行测试
      【接口标识】:UART2/3/4/5_TTL
      【系统设备】:/dev/ttymxc1
    测试操作
      短接串口2的发送发接收管脚(J1的7和9号管脚)
      执行测试指令:
    =====> 输入指令:
    /my-demo/gcc-linaro-5.3-arm/serial_test.out /dev/ttymxc1 "www.myzr.com.cn"
    =====> 输出信息:
    Starting send data...finish
    Starting receive data:
    ASCII: 0x77      Character: w
    ASCII: 0x2e      Character: .
    ASCII: 0x6d      Character: m
    ASCII: 0x79      Character: y
    ASCII: 0x7a      Character: z
    ASCII: 0x72      Character: r
    ASCII: 0x63      Character: c
    ASCII: 0x6f      Character: o
    ASCII: 0x6e      Character: n
    ASCII: 0x0       Character:
    测试结果
      执行测试指令后,应用输出如上类似信息即正常。
    2.12  串口测试(UART3)
      【系统设备】:/dev/ttymxc2
    测试操作
      短接串口3的发送发接收管脚(J1的11和13号管脚)
      执行测试指令:
    =====> 输入指令:
    /my-demo/gcc-linaro-5.3-arm/serial_test.out /dev/ttymxc2 "www.myzr.com.cn"
    =====> 输出信息:
    测试结果
    2.13  串口测试(UART4)
      【系统设备】:/dev/ttymxc3
    测试操作
      短接串口4的发送发接收管脚(J1的15和17号管脚)
      执行测试指令:
    =====> 输入指令:
    /my-demo/gcc-linaro-5.3-arm/serial_test.out /dev/ttymxc3 "www.myzr.com.cn"
    =====> 输出信息:
    测试结果
    2.14  串口测试(UART5)
      【系统设备】:/dev/ttymxc4
    测试操作
      短接串口5的发送发接收管脚(J1的16和18号管脚)
      执行测试指令:
    =====> 输入指令:
    /my-demo/gcc-linaro-5.3-arm/serial_test.out /dev/ttymxc4 "www.myzr.com.cn"
    =====> 输出信息:
    测试结果
    2.15  CAN 测试
      【测试说明】:采用CAN1发送,CAN0接收的方式。
      【接口标识】:CAN1,CAN2
      【系统接口】:can0,can1
    测试准备
      将CAN1的CAN_L与CAN2的CAN_L连接。
      将CAN1的CAN_H与CAN2的CAN_H连接。
    测试命令
      配置 CAN1(can0):
    =====> 输入指令:
    ip link set can0 up type can bitrate 125000
      配置 CAN2(can1):
    =====> 输入指令:
    ip link set can1 up type can bitrate 125000
      CAN1 (can0) 后台接收:
    =====> 输入指令:
    candump can0 &
      CAN2(can1)发送数据:
    =====> 输入指令:
    cansend can1 1F334455#1122334455667788
    =====> 输出信息:
    can0  1F334455   [8]  11 22 33 44 55 66 77 88
    测试结果
      CAN2(can1)发送数据后,CAN1(can0)会把接收到的数据输出,如:11 22 33 44 55 66 77 88
    【下章节为明远智睿MY-IMX6-EK200 Linux-4.1.15测试手册v2.03)】
    GMT+8, 2024-4-26 03:08 , Processed in 0.105758 second(s), 15 queries , MemCache On.
