查看: 1924|回复: 1
[教程] GPS V2B Shield For pcDuino
版主
发表于 2014-4-4 10:21:18 |显示全部楼层
GPS shield V2-B  是一款为了全球定位系统而设计的带SD接口的GPS模块扩展板 。
一、产品介绍:
  • On-board SD card slot can be used to data log.
  • Easy adoption with best performance
  • Integrated antenna and EMC protection
  • Built-in backup battery allowing hot/warm starts and better performance
  • No external component demand, just connect and use.
  • Minimum RF and EMI efforts
  • Small size of 18 (W) x 21 (L) x 7 (H) (mm) with patch antenna of 18x18x4mm.
  • Fully implementation of ultra-high performance SiRFstarIII single chip architecture
  • High tracking sensitivity of -159dBm
  • Low power consumption of 40mA at full tracking
  • Hardware power saving control pin allowing power off GPS via GPIO
二、硬件清单:
pcDuino V2   x1
GPS shield V2B x1
三、测试代码:
void setup()
  Serial.begin(9600);
void  loop()
  if(Serial.available()>0)
  char c = Serial.read();
  printf(“%c”,c);
  fflush(stdout);
四、测试运行:
(1)将GPS Shield V2B插在pcDuino V2上面、并将GPS Shield上面的跳线J1-RX短路到MTX上、J2-TX短路到MRX上,给pcDuinoV2上电:
(2)打开Arduino IDE,输入测试代码:
(3)运行代码可以看到命令终端输出一些GPS的数据(数据格式说明):
GMT+8, 2018-6-19 14:40 , Processed in 0.097671 second(s), 13 queries , MemCache On.
