查看: 3278|回复: 1
RIoTboard LTIB 4.0.0 映像放送
  • 签到天数: 1018 天
    发表于 2014-5-6 14:09:37 | 显示全部楼层 |阅读模式
    Ubuntu文件系统对您来说太大了,或者您只需要一个非图形的文件系统?
    Freescale提供LTIB开发包,用于定制Linux的文件系统,
    下面提供一个编译好的文件系统以供有需要的朋友使用:
    http://pan.baidu.com/s/1ntBJGlb
    【使用方法】
    1、拷贝rootfs.tar.bz2到“linux\tools\Mfgtools-Rel-4.1.0_130816_MX6DL_UPDATER\Profiles\MX6DL Linux Update\OS Firmware\files”目录
    2、修改“linux\tools\Mfgtools-Rel-4.1.0_130816_MX6DL_UPDATER\Profiles\MX6DL Linux Update\OS Firmware”目录下“ucl2.xml”文件,在最后添加新的烧写配置:
    1. <LIST name="i.MX6SOLO-linux-RIoTboard-eMMC" desc="Choose eMMC as media">
    2. <CMD state="BootStrap" type="boot" body="BootStrap" file ="u-boot-mx6solo-RIoTboard.bin" >Loading U-boot</CMD>
    3. <CMD state="BootStrap" type="load" file="uImage" address="0x10800000"
    4. loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Kernel.</CMD>
    5. <CMD state="BootStrap" type="load" file="initramfs.cpio.gz.uboot" address="0x10C00000"
    6. loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Initramfs.</CMD>
    7. <CMD state="BootStrap" type="jump" > Jumping to OS image. </CMD>
    8. <CMD state="Updater" type="push" body="send" file="mksdcard.sh.tar">Sending partition shell</CMD>
    9. <CMD state="Updater" type="push" body="$ tar xf $FILE "> Partitioning...</CMD>
    10. <CMD state="Updater" type="push" body="$ sh mksdcard.sh /dev/mmcblk0"> Partitioning...</CMD>
    11. <CMD state="Updater" type="push" body="send" file="files/u-boot-mx6solo-RIoTboard.bin">Sending u-boot.bin</CMD>
    12. <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0 bs=512 seek=2 skip=2 conv=fsync">write u-boot.bin to sd card</CMD>
    13. <CMD state="Updater" type="push" body="$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16">clean up u-boot parameter</CMD>
    14. <CMD state="Updater" type="push" body="send" file="files/uImage">Sending kernel uImage</CMD>
    15. <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync">write kernel image to sd card</CMD>
    16. <CMD state="Updater" type="push" body="$ mkfs.ext3 -j /dev/mmcblk0p1">Formatting rootfs partition</CMD>
    17. <CMD state="Updater" type="push" body="$ mkdir -p /mnt/mmcblk0p1"/>
    18. <CMD state="Updater" type="push" body="$ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1"/>
    19. <CMD state="Updater" type="push" body="pipe tar -jxv -C /mnt/mmcblk0p1" file="files/rootfs.tar.bz2">Sending and writting rootfs</CMD>
    20. <CMD state="Updater" type="push" body="frf">Finishing rootfs write</CMD>
    21. <CMD state="Updater" type="push" body="$ umount /mnt/mmcblk0p1">Unmounting rootfs partition</CMD>
    22. <CMD state="Updater" type="push" body="$ echo Update Complete!">Done</CMD>
    23. </LIST>
    24. </UCL>
    3、修改“linux\tools\Mfgtools-Rel-4.1.0_130816_MX6DL_UPDATER”目录下的“cfg.ini”文件,修改烧写配置:
    1. [profiles]
    2. chip = MX6DL Linux Update
    3. [platform]
    4. board = RIoTboard
    5. [LIST]
    6. name = i.MX6SOLO-linux-RIoTboard-eMMC
    4、按照用户文档介绍,使用MfgTool2重新烧写系统即可。
    2015-8-5 08:38
  • 签到天数: 12 天
    发表于 2014-8-6 23:21:45 | 显示全部楼层
    支持一个~~~
    GMT+8, 2024-4-26 05:20 , Processed in 0.122655 second(s), 17 queries , MemCache On.
