查看: 972|回复: 3
[讨论] 【WINC1500-XSTK WiFi】相关介绍
  • 签到天数: 815 天
    发表于 2016-5-25 00:42:10 |显示全部楼层
    The Atmel® ATWILC1000-SD evaluation kit is a hardware platform to evaluate the Atmel® ATWILC1000-MR110PB module.
    Atmel® SmartConnect WILC1000 is an IEEE 802.11 b/g/n IOT link controller SoC. It is the ideal add-On to existing MCU solutions bringing WiFi through UART or SPI/SDIO-to-WiFi interface. The WILC1000 connects to any Atmel AVR or SMART MCU with minimal resource requirements. The WILC1000 most advanced mode is a single stream 1x1 802.11n mode providing up to 72 Mbps PHY throughput. WILC1000 features fully integrated Power Amplifier, LNA, Switch and Power Management. The WILC1000 provides multiple peripheral interfaces including UART, SPI, SDIO and I2C. The only external clock source needed for the WILC1000 is a high-speed crystal or oscillator with a wide variety of reference clock frequencies supported (between 12 – 32 MHz). The WILC1000 is available in a QFN package.
    Contents: WILC1000 SD Extension board
    Key Features
    • Atmel® ATWILC1000 module mounted on ATWILC1000-SD board
    • Connects to standard SD/MMC connector
    • The Atmel® | SMART ATWILC1000-MR110PB module is a single-band 2.4GHz Wi-Fi connectivity link controller solution
    • Optional external Power supply and Debug headers included
    • Supported with standard SDIO drivers on github
    The Atmel® ATWINC1500-XSTK Xplained Pro starter kit is a hardware platform for evaluating the Atmel ATWINC1500 low cost, low power 802.11 b/g/n WiFi network controller module. Supported by the Atmel Studio integrated development platform, the kit provides easy access to the features of the ATWINC1500 and explains how to integrate the device in a custom design. The Xplained Pro series of evaluation kits include an on-board Embedded Debugger, and no external tools are necessary to program or debug the SAMD21 host MCU that drives the ATWINC1500. The Xplained Pro extension kits offer additional peripherals to extend the features of the board and ease the development of custom designs.
    What is in the box: SAMD21 Xplained Pro, WINC1500 Xplained Pro Extension board, I/O1 Xplained Pro Extension board, Two USB Type A to Micro B Cables (1.5m)
    Key Features
    • Atmel ATWINC1500 module mounted on ATWINC1500 Xplained Pro Extension
    • ATSAMD21-XPRO host MCU board for driving the ATWINC1500 Xplained Pro Extension
    • Atmel I/O1 Xplained Pro for sensor and SD-card input to host MCU
    • Embedded debugger (EDBG) for programming SAMD21 host MCU
    • Virtual COM-port interface to host MCU via UART
    • Wired firmware updates for ATWINC1500 module via virtual COM-port interface
    • Atmel Data Gateway Interface (DGI) to host MCU via SPI and TWI
    • ATECC108 CryptoAuthentication device connected to host MCU
    • Two extension headers
    • Three possible power sources
    • External power
    • Target USB
    • 32KHz crystal
    • 16MHz crystal
    • Supported with application examples trough Atmel gallery
    Key parameters for ATWINC1500Parameter
    Value
    Pin Count:
    40
    SPI:
    1
    TWI (I2C):
    0
    UART:
    1
    Temp. Range (deg C):
    -40 to 85
    Operating Voltage (Vcc):
    3.0 to 4.2
    Frequency Band:
    2.4 GHz
    Max Data Rate (Mb/s):
    72
    Antenna Diversity:
    No
    External PA Control:
    No
    Power Output (dBm):
    19
    Receiver Sensitivity (dBm):
    -90
    Receive Current Consumption (mA):
    70
    Transmit Current Consumption (mA):
    172
  • 签到天数: 815 天
    发表于 2016-5-25 00:43:02 |显示全部楼层
    Atmel® SmartConnect-WINC1500 is an IEEE 802.11 b/g/n IOT network controller SoC. It is the ideal add-On to existing MCU solutions bringing WiFi and Network capabilities through UART or SPI-to-WiFi interface. The WINC1500 connects to any Atmel AVR or SMART MCU with minimal resource requirements. The WINC1500 most advanced mode is a single stream 1x1 802.11n mode providing up to 72 Mbps PHY throughput. WINC1500 features fully integrated Power Amplifier, LNA, Switch and Power Management. The WINC1500 provides internal Flash memory as well as multiple peripheral interfaces including UART, SPI, and I2C. The only external clock source needed for the WINC1500 is a high-speed crystal or oscillator with a wide variety of reference clock frequencies supported (between 12 – 32 MHz). The WINC1500 is available in a QFN package.
    Key Features
    Single-band 2.4GHz b/g/n
    Extreme low power
    Compact footprint: 33.8 x 14.9 mm
    Operating Voltage: 3.0 to 4.2
    Serial Host Interface SPI or UART
    Worldwide acceptance: FCC (USA), CE (Europe) and TELEC
    RoHS compliant
    Security protocols supported – WPA/WPA2 Personal, TLS, SSL
    Network services – DHCP, DNS, TCP/IP (IPv4), UDP, HTTP, HTTP
    Key Parameters
    ParameterValue
    Pin Count:
    40
    SPI:
    1
    TWI (I2C):
    0
    UART:
    1
    -40 to 85
    3.0 to 4.2
    Frequency Band:
    2.4 GHz
    72
    Antenna Diversity:
    No
    No
    秀才
    2013-1-22 10:13
    发表于 2016-5-25 14:00:58 |显示全部楼层
    英文的。。。
  • 签到天数: 815 天
    发表于 2016-5-29 20:07:21 |显示全部楼层
    关于IO1 Xplained介绍,它拥有众多的功能,如microSD、光线传感器、温度传感器。见http://www.eeboard.com/topic/xplained-pro/8/
    GMT+8, 2018-6-20 06:01 , Processed in 0.118683 second(s), 16 queries , MemCache On.
