[GD32F190方案分享] 基于GD32F190的I2C总线扫描 因为挂在I2C总线的装置, 经常不确定该装置地址的I2C是甚么, 因此做了个I2C总线扫描程序! 程序使用GD32F190的I2C2 , PF6:SCL, PF7:SDA.
扫描后由USB串口输出结果.
主程序如下: - /**
- * @file main.c
- * @author MCU SD
- * @version V1.0.0
- * @date 12-Jun-2016
- * @brief The main function file.
- /* Includes ------------------------------------------------------------------*/
- #include <stdio.h>
- #include "gd32f1x0.h"
- #include "SysTick.h"
- #include "gd32f1x0_eval.h"
- #ifdef __GNUC__
- /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
- set to 'Yes') calls __io_putchar() */
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif /* __GNUC__ */
- /* Private variables ---------------------------------------------------------*/
- #define I2C_OWN_ADDRESS7 0x82
- #define I2C2_Speed 100000 // 100KHz
- uint8_t I2C_Count = 0; // 0~127 : number of I2C devise
- uint16_t I2C_Device_Address = 0x0; // (from 0x00 to 0x7F)<<1
- uint16_t I2C_TimeOut = 0xFFFF;
- uint16_t I2C_Time = 0;
- uint8_t I2C_Found = 0; // 0:not found 1:found
- uint8_t I2C_Found_Count = 0; // total found
- uint8_t count;
- /* Private function prototypes -----------------------------------------------*/
- static void USART_Configuration(void);
- void I2C2_GPIO_Configuration(void);
- void I2C2_Configuration(void);
- /* Private functions ---------------------------------------------------------*/
- * @brief Main program.
- * @param None
- * @retval None
- int main(void)
- /* SysTick Configuration*/
- SysTick_Configuration();
- /* USART parameter Configuration */
- USART_Configuration(); // 115200,8,n,1
- /* Config I2C2 GPIO */
- I2C2_GPIO_Configuration(); // PF6(SCL) , PF7(SDA)
- /* I2C2 parameter Configuration */
- I2C2_Configuration(); // I2C2, AF0
- /* GD32190R-EVAL-V1.1 Start up */
- printf("\r\n The I2C Master : SCL(PF6) , SDA(PF7) \n\r");
- printf("\r\n The I2C Speed : %d \n\r", I2C2_Speed);
- // if(I2C_24C02_Test()==I2C_OK)
- for (I2C_Count=0; I2C_Count<128; I2C_Count++)
- I2C_Device_Address = I2C_Count << 1;
- /* Enable I2C2 */
- I2C_Enable(I2C2,ENABLE);
- /* The software must wait until I2C Bus is idle */
- I2C_Time = 0;
- while( I2C_GetBitState(I2C2,I2C_FLAG_I2CBSY) && (I2C_Time < I2C_TimeOut) ) {I2C_Time++;}
- /* Send a start condition to I2C bus */
- I2C_StartOnBus_Enable(I2C2,ENABLE);
- /* The software must wait until SBSEND bit is set */
- I2C_Time = 0;
- while(!I2C_StateDetect(I2C2,I2C_PROGRAMMINGMODE_MASTER_SBSEND) && (I2C_Time < I2C_TimeOut) ) {I2C_Time++;}
- /* Send slave address to I2C bus */
- I2C_AddressingDevice_7bit(I2C2,I2C_Device_Address,I2C_DIRECTION_TRANSMITTER);
- /* The software must wait until ADDSEND bit is set*/
- I2C_Found = 0; // default : not found I2C Device
- I2C_Time = 0;
- while( I2C_Time < I2C_TimeOut ) {
- I2C_Time++;
- if ( I2C_StateDetect(I2C2,I2C_PROGRAMMINGMODE_MASTER_TRANSMITTER_ADDSEND) ) // found I2C Device
- I2C_Found = 1;
- break; // break while()
- I2C_StopOnBus_Enable(I2C2,ENABLE);
- I2C_Time = 0;
- while( (I2C2->CTLR1&0x0200) && (I2C_Time < I2C_TimeOut) ) {I2C_Time++;}
- if ( I2C_Found )
- printf("\r\n I2C Found : 0x%02X \n\r", I2C_Device_Address);
- I2C_Found_Count++;
- else
- // printf("\r\n I2C Not Found : 0x%02X \n\r", I2C_Device_Address);
- printf("\r\n Total Found I2C Device Number : %d \n\r", I2C_Found_Count);
- while(1)
- * @brief Retarget the C library printf function to the USART.
- * @param None
- * @retval None
- PUTCHAR_PROTOTYPE
- /* Place your implementation of fputc here */
- /* e.g. write a character to the USART */
- USART_DataSend( EVAL_COM1 , (uint8_t) ch );
- /* Loop until transmit data register is empty */
- while (USART_GetBitState( EVAL_COM1 , USART_FLAG_TBE) == RESET)
- return ch;
- * @brief Configure USART1.
- * @param None
- * @retval None
- void USART_Configuration(void)
- USART_InitPara USART_InitStructure;
- USART_DeInit( EVAL_COM1 );
- USART_InitStructure.USART_BRR = 115200;
- USART_InitStructure.USART_WL = USART_WL_8B;
- USART_InitStructure.USART_STBits = USART_STBITS_1;
- USART_InitStructure.USART_Parity = USART_PARITY_RESET;
- USART_InitStructure.USART_HardwareFlowControl = USART_HARDWAREFLOWCONTROL_NONE;
- USART_InitStructure.USART_RxorTx = USART_RXORTX_RX | USART_RXORTX_TX;
- GD_EVAL_COMInit(&USART_InitStructure);
- * @brief Cofigure the I2C2 GPIO.
- * @param None
- * @retval None
- GPIO_InitPara GPIO_InitStructure;
- /* Enable GPIO clock */
- RCC_AHBPeriphClock_Enable( RCC_AHBPERIPH_GPIOF, ENABLE );
- /* Configure I2C2 pins: SCL and SDA */
- GPIO_InitStructure.GPIO_Pin = GPIO_PIN_6 | GPIO_PIN_7; // SCL , SDA
- GPIO_InitStructure.GPIO_Mode = GPIO_MODE_AF;
- GPIO_InitStructure.GPIO_OType = GPIO_OTYPE_OD;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PUPD_NOPULL;
- GPIO_InitStructure.GPIO_Speed = GPIO_SPEED_50MHZ ;
- GPIO_Init(GPIOF, &GPIO_InitStructure) ;
- GPIO_PinAFConfig(GPIOF,GPIO_PINSOURCE6,GPIO_AF_0);
- GPIO_PinAFConfig(GPIOF,GPIO_PINSOURCE7,GPIO_AF_0);
- * @brief Cofigure the I2C2 interface.
- * @param None
- * @retval None
- I2C_InitPara I2C_InitStructure;
- I2C_DeInit(I2C2);
- /* Enable I2C2 APB1 clock */
- RCC_APB1PeriphClock_Enable( RCC_APB1PERIPH_I2C2, ENABLE );
- /* I2C configuration */
- I2C_InitStructure.I2C_Protocol = I2C_PROTOCOL_I2C;
- I2C_InitStructure.I2C_DutyCycle = I2C_DUTYCYCLE_2;
- I2C_InitStructure.I2C_BitRate = I2C2_Speed;
- I2C_InitStructure.I2C_AddressingMode = I2C_ADDRESSING_MODE_7BIT;
- I2C_InitStructure.I2C_DeviceAddress = I2C_OWN_ADDRESS7;
- I2C_Init(I2C2, &I2C_InitStructure);
- /* Enable I2C2 */
- I2C_Enable(I2C2, ENABLE );
- /* Enable Acknowledge */
- I2C_Acknowledge_Enable( I2C2 , ENABLE );
- /******************* (C) COPYRIGHT 2016 GIGADEVICE *****END OF FILE****/
I2C_scan_main.zip
(2.2 KB, 下载次数: 16)
