查看: 3066|回复: 0
raspbian-jessie 2016-07-13 image for BPI-M1/M1+/R1/M2+/M3/M64 发布
发表于 2016-7-14 17:05:20 | 显示全部楼层 |阅读模式
raspbian-jessie 2016-07-13 image for BPI-M1/M1+/R1/M2+/M3/M64 发布,支持IOT node-red IoT 系统.
  • based on RASPBIAN JESSIE 2016-05-27(support rpi3 rpi2 rpi1)
  • BPI-M1 / BPI-M1P / BPI-R1 u-boot-2016.05, kernel 3.4.112 (based on armbian's build)
  • username & password: pi/bananapi , root/bananapi
  • support HDMI 1080P & 720P(default)
  • support GMAC
  • support WIFI
  • support SATA
  • support bpi-bootsel cmd can switch to (bpi-m64 & bpi-m3 & bpi-m2 & bpi-m2p & bpi-m1-m1p-r1)
  • support boot.scr (boot.cmd) to fatload script.bin & uImage & uInitrd
  • support boot.scr to set video 1080P & 720P & 480P ...
  • based on armbian's build env. & rootfs, thanks for armbian (http://www.armbian.com)
  • github from https://github.com/igorpecovnik/lib by armbian's work
  • special thanks for linux-sunxi's work (https://linux-sunxi.org)
  • thanks for raspberry.org's work(https://www.raspberrypi.org/downloads/raspbian)
  • support node-red
Google Drive:
https://drive.google.com/file/d/0B_YnvHgh2rwjdTh5ZnVZam1rb0E/view?usp=sharing3
MD5: 156b09907586ea9e86481bda73f4254f
note: raspbian-jessie 2016-07-13 image for BPI-M1/M1+/R1/M2+/M3/M64 have support node-red IoT system.
BPI-M1 ,BPI-M1+,BPI-R1 镜像下载地址 ,注意,一个镜像,支持三种板,自动识别硬件
http://forum.banana-pi.org/t/bpi ... img-2016-07-13/2010
BPI-M2+:
http://forum.banana-pi.org/t/bpi ... img-2016-07-13/2008
BPI-M3:
http://forum.banana-pi.org/t/bpi ... img-2016-07-13/2009
BPI-M63
http://forum.banana-pi.org/t/bpi ... img-2016-07-13/2017
GMT+8, 2024-4-18 15:04 , Processed in 0.109095 second(s), 16 queries , MemCache On.
