查看: 3214|回复: 0
google搜索到的R40 uboot 编译教程
发表于 2017-1-3 11:39:42 | 显示全部楼层 |阅读模式
google搜索到的R40 uboot 编译教程,与大家共享一下
# Get and build the BOOT2.0
2
3 ## Download the source code
4         $ git clone git://172.16.1.11/lichee/brandy.git      (B network)
5         $ git clone git://192.168.200.11/lichee/brandy.git   (D network)
6
7 ## Build
8 To support linux-3.10:
9
10         $ cd u-boot-2014.07
11
12 To support linux-3.4:
13
14         $ cd u-boot-2011.09
15
16 Make distclean is necessary if it is your first time to build u-boot
17 or you have ever config other platform.
18
19         $ make distclean
20
21 You must configure U-Boot for one specific board type. This is done by typing:
22
23         $ make NAME_config
24
25 where "NAME_config" is the name of one of the existing configurations;
26 see boards.cfg for more supported names.
27 List of configurations:
28
29         (config 1633)   A31/A31S  :   $ make sun8iw1p1_config
30         (config 1650)   A23       :   $ make sun8iw3p1_config
31         (config 1667)   A33       :   $ make sun8iw5p1_config
32         (config 1673)   A83       :   $ make sun8iw6p1_config
33         (config 1680)   H3        :   $ make sun8iw7p1_config
34         (config 1681)   V3/V3S    :   $ make sun8iw8p1_config
35         (config 1677)   --        :   $ make sun8iw9p1_config
36         (config 1699)   B100      :   $ make sun8iw10p1_config
37         (config 1701)   V40/A20E  :   $ make sun8iw11p1_config
38         (config 1639)   A80       :   $ make sun9iw1p1_config
39         (config 1689)   A64       :   $ make sun50iw1p1_config
40         (config 1718)   H5        :   $ make sun50iw2p1_config
41
42 Finally, build some working images:
43
44         $ make -j14             (build uboot,"make -jn" means to build the image with multiple make jobs)
45         $ make boot0            (build boot0)
46         $ make fes              (build fes)
47         $ make sboot            (build sboot)
48         $ make spl              (build boot0 fes sboot)
49
50 Also,it is possible to build the whole bootloader by typing "./build.sh -p NAME" under directory brandy.
51
52         $ cd ../ && ./build.sh -p NAME
53
54 NAME means the the board name,such as sun6i/sun7i/sun8iw3p1/sun9iw1p1 etc.
55 See boards.cfg for more supported names.
56 List of NAME:
57
58         (build 1633 bootloader)   A31/A31S  :   $ ./build.sh -p sun8iw1p1
59         (build 1650 bootloader)   A23       :   $ ./build.sh -p sun8iw3p1
60         (build 1667 bootloader)   A33       :   $ ./build.sh -p sun8iw5p1
61         (build 1673 bootloader)   A83       :   $ ./build.sh -p sun8iw6p1
62         (build 1680 bootloader)   H3        :   $ ./build.sh -p sun8iw7p1
63         (build 1681 bootloader)   V3/V3S    :   $ ./build.sh -p sun8iw8p1
64         (build 1677 bootloader)   --        :   $ ./build.sh -p sun8iw9p1
65         (build 1699 bootloader)   B100      :   $ ./build.sh -p sun8iw10p1
66         (build 1701 bootloader)   V40/A20E  :   $ ./build.sh -p sun8iw11p1
67         (build 1639 bootloader)   A80       :   $ ./build.sh -p sun9iw1p1
68         (build 1689 bootloader)   A64       :   $ ./build.sh -p sun50iw1p1
69         (build 1718 bootloader)   H5        :   $ ./build.sh -p sun50iw2p1
70
71
72 Enjoy it!
GMT+8, 2024-4-26 05:04 , Processed in 0.104657 second(s), 15 queries , MemCache On.
