查看: 357|回复: 0
[技术] 【赚周年比】技术贴——Fireduino学习之DLNA
    3 天前
  • 签到天数: 832 天
    发表于 2017-1-12 23:53:54 |显示全部楼层
           学习了如何播放TF卡上的音乐文件后,就要尝试通过WIFI播放音乐,但是对网络协议不懂,但是Fireduino支持DLNA播放,虽然用过DLNA,但是对于它 的实现是不懂的,所以就下载了官网提供的程序。
    1. #include <Arduino.h>
    2. #include "TF.h"
    3. #include "Audio.h"
    4. #include <WiFi.h>
    5. char ssid[] = "HiWiFi_37C468";     //  your network SSID (name)
    6. char pass[] = "";  // your network password
    7. int status = WL_IDLE_STATUS;
    8. void printWifiStatus();
    9. void setup() {
    10.   Serial.begin(115200);
    11.   Serial.print("\r\narduino setup ...\r\n");
    12.   if(!SD.begin())
    13.   {
    14.     Serial.println("sd init err\r\n");
    15.     while(1);
    16.   }
    17.   // check for the presence of the shield:
    18.   if (WiFi.status() == WL_NO_SHIELD) {
    19.     Serial.println("WiFi shield not present");
    20.     // don't continue:
    21.     while (true);
    22.   }
    23.   String fv = WiFi.firmwareVersion();
    24.   if (fv != "1.1.0") {
    25.     Serial.println("Please upgrade the firmware");
    26.   }
    27.   // attempt to connect to Wifi network:
    28.   while (status != WL_CONNECTED) {
    29.     Serial.print("Attempting to connect to SSID: ");
    30.     Serial.println(ssid);
    31.     // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    32.     status = WiFi.begin(ssid, pass);
    33.     // wait 10 seconds for connection:
    34.     // delay(10000);
    35.   }
    36.   Serial.println("Connected to wifi");
    37.   printWifiStatus();
    38.   Audio.begin(AUDIO_DLNA);
    39. }
    40. void loop() {
    41.   Serial.println("loop");
    42.   delay(2000);
    43. }
    44. void printWifiStatus() {
    45.   // print the SSID of the network you're attached to:
    46.   Serial.print("SSID: ");
    47.   Serial.println(WiFi.SSID());
    48.   // print your WiFi shield's IP address:
    49.   IPAddress ip = WiFi.localIP();
    50.   Serial.print("IP Address: ");
    51.   Serial.println(ip);
    52.   // print the received signal strength:
    53.   long rssi = WiFi.RSSI();
    54.   Serial.print("signal strength (RSSI):");
    55.   Serial.print(rssi);
    56.   Serial.println(" dBm");
    57. }
    实际使用时发现Fireduino挑路由器,在实验室是用的是水星的路由器,重复多次下载,查看代码,都没发现问题,但就是不出声音,内心是郁闷的,难道官网提供的代码有错误,回到宿舍接着折腾,终于出声音了,还是一样的代码。只不过换了个路由,宿舍用的是极路由一代。
    还有一个问题就是,我用的音乐软件是网易云音乐,多次使用后,手机客户端DLNA会显示多个Fireduino的名字,有时真不好分清楚哪个是现在使用的设备名字,也不太清楚怎么让客户端记住设备,而不重复显示。
    dlna.zip
    1018 Bytes, 下载次数: 0
    已有 1 人评分周年币 收起 理由
    loveeeboard + 15
    总评分: 周年币 + 15   查看全部评分
    GMT+8, 2018-5-21 18:47 , Processed in 0.079861 second(s), 17 queries , MemCache On.
