为了进行温湿度曲线的绘制,这里先介绍一下TFT液晶屏的用法,由于并行的TFT屏占用GPIO资源较多,使用这里选用SPI通讯方式的串口屏,它与MCU的连接关系如下: TFT_CS --PA4 TFT_RST --PA5 TFT_D/C --PA6 TFT_SDI --PA7 TFT_SCK --PA8 TFT_LED --PB0 定义TFT屏输出高低电平语句: #define LCD_CS_High() GPIO_WriteBit(GPIOA, GPIO_Pin_4, Bit_SET) #define LCD_CS_Low() GPIO_WriteBit(GPIOA, GPIO_Pin_4,Bit_RESET) #define LCD_REST_High() GPIO_WriteBit(GPIOA, GPIO_Pin_5, Bit_SET) #define LCD_REST_Low() GPIO_WriteBit(GPIOA, GPIO_Pin_5,Bit_RESET) #define LCD_DC_High() GPIO_WriteBit(GPIOA, GPIO_Pin_6, Bit_SET) #define LCD_DC_Low() GPIO_WriteBit(GPIOA, GPIO_Pin_6,Bit_RESET) #define LCD_SDI_High() GPIO_WriteBit(GPIOA, GPIO_Pin_7, Bit_SET) #define LCD_SDI_Low() GPIO_WriteBit(GPIOA, GPIO_Pin_7,Bit_RESET) #define LCD_SCK_High() GPIO_WriteBit(GPIOA, GPIO_Pin_8, Bit_SET) #define LCD_SCK_Low() GPIO_WriteBit(GPIOA, GPIO_Pin_8,Bit_RESET) #define LCD_LED_High() GPIO_WriteBit(GPIOB, GPIO_Pin_0,Bit_SET) TFT屏引脚配置函数: - void SPI_CONFIG()
- GPIO_InitTypeDef gpioInitStrcut;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
- gpioInitStrcut.GPIO_Mode = GPIO_Mode_Out_PP;
- gpioInitStrcut.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8;
- gpioInitStrcut.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &gpioInitStrcut);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
- gpioInitStrcut.GPIO_Pin = GPIO_Pin_0;
- GPIO_Init(GPIOB, &gpioInitStrcut);
- LCD_LED_High();
复制代码 TFT屏初始化函数: - void Lcd_Init(void)
- LCD_REST_Low();
- DelayXms(20);
- LCD_REST_High();
- DelayXms(20);
- LCD_CS_Low();
- LCD_WR_REG(0xCB);
- LCD_WR_DATA8(0x39);
- LCD_WR_DATA8(0x2C);
- LCD_WR_DATA8(0x00);
- LCD_WR_DATA8(0x34);
- LCD_WR_DATA8(0x02);
- LCD_WR_REG(0xCF);
- LCD_WR_DATA8(0XC1);
- LCD_WR_DATA8(0X30);
- LCD_WR_REG(0xE8);
- LCD_WR_DATA8(0x85);
- LCD_WR_DATA8(0x78);
- LCD_WR_REG(0xEA);
- LCD_WR_REG(0xED);
- LCD_WR_DATA8(0x64);
- LCD_WR_DATA8(0x03);
- LCD_WR_DATA8(0X12);
- LCD_WR_DATA8(0X81);
- LCD_WR_REG(0xF7);
- LCD_WR_DATA8(0x20);
- LCD_WR_REG(0xC0);
- LCD_WR_DATA8(0x23);
- LCD_WR_REG(0xC1);
- LCD_WR_DATA8(0x10);
- LCD_WR_REG(0xC5);
- LCD_WR_DATA8(0x3e);
- LCD_WR_DATA8(0x28);
- LCD_WR_REG(0xC7);
- LCD_WR_DATA8(0x86);
- LCD_WR_REG(0x36);
- LCD_WR_DATA8(0x48);
- LCD_WR_REG(0x3A);
- LCD_WR_DATA8(0x55);
- LCD_WR_REG(0xB1);
- LCD_WR_DATA8(0x18);
- LCD_WR_REG(0xB6);
- LCD_WR_DATA8(0x08);
- LCD_WR_DATA8(0x82);
- LCD_WR_DATA8(0x27);
- LCD_WR_REG(0xF2);
- LCD_WR_REG(0x26);
- LCD_WR_DATA8(0x01);
- LCD_WR_REG(0xE0);
- LCD_WR_DATA8(0x0F);
- LCD_WR_DATA8(0x31);
- LCD_WR_DATA8(0x2B);
- LCD_WR_DATA8(0x0C);
- LCD_WR_DATA8(0x0E);
- LCD_WR_DATA8(0x4E);
- LCD_WR_DATA8(0xF1);
- LCD_WR_DATA8(0x37);
- LCD_WR_DATA8(0x07);
- LCD_WR_DATA8(0x09);
- LCD_WR_REG(0XE1);
- LCD_WR_DATA8(0x14);
- LCD_WR_DATA8(0x11);
- LCD_WR_DATA8(0xC1);
- LCD_WR_DATA8(0x36);
- LCD_WR_REG(0x11);
- DelayXms(120);
- LCD_WR_REG(0x29);
- LCD_WR_REG(0x2c);
复制代码 为自行构建小字库,可像OLED屏那样使用字模提取软件PCtoLCD2002,其操作界面如图1所示。
图1 字模提取
由于所购置的2.2寸串口屏是一块竖向显示屏,因此在制作图2的显示效果时,必须对相应的显示函数进行转置,如字符、数值、中文显示函数及波形绘制函数等。
图2 转置处理
利用温湿度检测例程,在配置字符显示函数和图形绘制函数的情况下,可以实现图3所示的设计效果。
图3 曲线绘制
实现温湿度曲线绘制的主函数如下: - int main(void)
- int16_t i,sj,sp,j,sq,sg;
- uint32_t tem;
- uint32_t hum;
- uint32_t n=0,m;
- Hardware_Init();
- SPI_CONFIG();
- DelayXms(1000);
- Lcd_Init();
- LCD_Clear(RED);
- BACK_COLOR=RED;
- POINT_COLOR=WHITE;
- showhanzi16h(40,100,6,0);
- showhanzi16h(40,120,5,0);
- showhanzi16h(40,140,4,0);
- showhanzi16h(40,160,3,0);
- showhanzi16h(40,180,2,0);
- showhanzi16h(40,200,1,0);
- showhanzi16h(40,220,0,0);
- showhanzi16h(200,160,2,0);
- showhanzi16h(200,180,1,0);
- showhanzi16h(200,280,2,0);
- showhanzi16h(200,300,0,0);
- DelayMs(1000);
- KEY_Init();
- LCD_DrawLine(10, 300, 190, 300);
- LCD_DrawLine(190, 10, 190, 300);
- sp=220-190;
- sq=sp;
- while(1)
- SHT20_GetValue();
- tem=sht20Info.tempreture;
- hum=sht20Info.humidity;
- j++;
- POINT_COLOR=YELLOW;
- sj=tem*4;
- sg=hum*2;
- LCD_DrawLine(220-sp, 300-4*(j-1), 220-sj, 300-4*(j));
- POINT_COLOR=GREEN;
- LCD_DrawLine(220-sq, 300-4*(j-1), 220-sg, 300-4*(j));
- sp=sj;
- sq=sg;
- if(j>=64)
- Loop:
- LCD_Clear(RED);
- j=0;
- tem=tem*10;
- hum=hum*10;
- LCD_ShowCharh(200,140,':',0);
- LCD_ShowCharh(200,260,':',0);
- LCD_ShowCharh(200,250,tem/100+0x30,0);
- LCD_ShowCharh(200,240,tem%100/10+0x30,0);
- LCD_ShowCharh(200,230,'.',0);
- tem=tem%10;
- LCD_ShowCharh(200,220,tem+0x30,0);
- LCD_ShowCharh(200,130,hum/100+0x30,0);
- LCD_ShowCharh(200,120,hum%100/10+0x30,0);
- LCD_ShowCharh(200,110,'.',0);
- hum=hum%10;
- LCD_ShowCharh(200,100,hum+0x30,0);
- // 采样间隔设置
- if (!GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_12)) n=18000; //时级
- if (!GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_13)) goto loop;//清除
- if (!GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_14)) n=5; //秒级
- if (!GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_15)) n=300; //分级
- For(m=0;m<n;m++) DelayMs(200);
复制代码 |
