查看: 3739|回复: 3
战舰V3通过ESP8266获得网络天气
发表于 2017-11-27 16:57:52 | 显示全部楼层 |阅读模式
之前用8266和机智云成功通信了,见 帖子 http://club.gizwits.com/thread-8048-1-1.html  但是一直不知道8266是怎么设置联网,因为这个是下载的机智云的固件。后来就寻思着做了这个网络天气的。网上几乎没有人用STM32做天气的,基本上都是用arduino或者直接用esp8266+oled。
一、
硬件:战舰V3 + ESP8266 + 2.8寸屏
软件:1、esp8266的配置
         2、连接天气的服务器,get API数据
         3、cjson的移植与解析
         4、UTF8转GBK转码,这个网上很少例程
         5、图标的取模
   首先配置esp8266为透传模式
01
02
03
04
05
06
07
08
09
10
11
12
13
14
15
16
17
18
19
20
while(atk_8266_send_cmd("AT","OK",20))//¼ì2éWIFIÄ£¿éêÇ·ñÔúÏß
                atk_8266_quit_trans();//íË3öí¸′«
                atk_8266_send_cmd("AT+CIPMODE=0","OK",200);  //1رÕí¸′«Ä£ê½
                Show_Str(40,55,200,16,"Î′¼ì2aμ½Ä£¿é!!!",16,0);
                delay_ms(800);
                LCD_Fill(40,55,200,55+16,WHITE);
                Show_Str(40,55,200,16,"3¢êÔᬽóÄ£¿é...",16,0);
        while(atk_8266_send_cmd("ATE0","OK",20));//1رջØÏÔ
        atk_8266_send_cmd("AT+CWMODE=1","OK",50);                //éèÖÃWIFI STAÄ£ê½
        atk_8266_send_cmd("AT+RST","OK",20);                //DHCP·tÎñÆ÷1رÕ(½öAPÄ£ê½óDD§)
        delay_ms(1000);         //Ñóê±3Sμè′yÖØÆô3é1|
        delay_ms(1000);
        delay_ms(1000);
        delay_ms(1000);
        //éèÖÃᬽóμ½μÄWIFIíøÂçÃû3Æ/¼óÃü·½ê½/ÃüÂë,Õa¼¸¸ö2ÎêyDèòa¸ù¾YÄú×Ô¼oμÄ·óéÆ÷éèÖýøDDDT¸Ä!!
        atk_8266_send_cmd("AT+CIPMUX=0","OK",20);   //0£oμ¥ᬽó£¬1£o¶àᬽó
        sprintf((char*)p,"AT+CWJAP=\"%s\",\"%s\"",wifista_ssid,wifista_password);//éèÖÃÎTÏß2Îêy:ssid,ÃüÂë
        while(atk_8266_send_cmd(p,"WIFI GOT IP",300));                                        //ᬽóÄ¿±ê·óéÆ÷,2¢Çò»ñμÃIP
然后连接天气服务器,get API
01
02
03
04
05
06
07
08
09
10
11
12
13
14
15
16
17
sprintf((char*)p,"AT+CIPSTART=\"TCP\",\"%s\",%s",WEATHER_SERVERIP,WEATHER_PORTNUM);    //ÅäÖÃÄ¿±êTCP·tÎñÆ÷
        res = atk_8266_send_cmd(p,"OK",200);//ᬽóμ½Ä¿±êTCP·tÎñÆ÷
        if(res==1)
                myfree(SRAMIN,p);
                return 1;
        delay_ms(300);
        atk_8266_send_cmd("AT+CIPMODE=1","OK",100);      //′«êäÄ£ê½Îa£oí¸′«
        atk_8266_get_wanip(ipbuf);//»ñè¡WAN IP
        sprintf((char*)p,"IPμØÖ·:%s ¶Ë¿ú:%s",ipbuf,(u8*)WEATHER_PORTNUM);
//        Show_Str(30,65,200,12,p,12,0);                                //ÏÔê¾IPμØÖ·oí¶Ë¿ú
        USART3_RX_STA=0;
        atk_8266_send_cmd("AT+CIPSEND","OK",100);         //¿aê¼í¸′«
        printf("start trans...\r\n");
        u3_printf("GET [color=rgb(0, 130, 0) !important]https://api.seniverse.com);
然后再解析这个API返回的数据,并予以显示。
二、
1.目前免费的API有很多,我比较喜欢“心知天气”( https://www.seniverse.com/ )和 “和风天气”(http://www.heweather.com/  )。
  大家可以到这两个网站去注册,选择你们喜欢的天气API。心知天气的免费API返回的数据表少,功能较少。而和风天气的免费API则返回的比较详细。
  我这里选择心知天气,然后大家可以去看看心知天气的文档,里面有详细的数据结构(cjson数据)。
2.移植和解析cjson。
  这个东西很简单,我也是第一次移植,不过看了一篇教程就会了。推荐大家看下这两篇文章就可以了。
  http://blog.csdn.net/xukai871105/article/details/32346797    这个讲cjson的格式讲的蛮好的
  http://blog.csdn.net/lintax/article/details/50993958     这个讲cjson的使用
  https://sourceforge.net/projects/cjson/          这个网站是下载cjson的
  移植cjson,注意两点,一个是cjson占用堆比较大,大约3K,这个坑我就遇到了,使用默认的堆大小不能运行,于是我把堆改成了4K。
  第二点就是 要为 cjson 配置malloc ,打开cjson.c,修改下面几处。修改成原子的mymalloc,由于原子的mymalloc有个选择SRAMIN的参数,所以我又封装了下,弄了个my_malloc。
3.连接天气服务器,然后get 天气的api。
   这里卡了好半天,一开始用网口调试助手连上了服务器,然后get那个API链接的时候,一直不成功,原来是要在这个链接后面加两个回车,这个得感谢坛友  svwydh
4.解析天气数据
  用cjson库来解析天气数据,这里有个问题就是获得的天气数据的格式都是  utf8 的,无法直接显示在屏上,需要转码成GBK的,而原子哥的汉字例程就是gbk的。
  utf8转gbk这个网上也比较少,问了很多网友,有人说用查表法,于是又去找,侥幸找到了一个类似的,然后修改了下,居然可以用。
5.图标的制作
  首先自己去选一套漂亮的天气图标,我刚才推荐的那两个网站里已经为大家准备了图标,可自行下载。
  然后用战舰光盘里那个Image2lcd的软件,选择输出灰度为单色,这样取模以后的数据最小。打开你的天气图标,然后点保存,就可以保存为一个数组的c文件,将这个
  数组添加到你的工程里去。
大体上的难点和知识点就是上面这些。
上几张效果图。一张彩色的,一张白色的,大家觉得哪个好看点。
接下来传个演示视频由于视频不能播放,先放个链接:http://v.youku.com/v_show/id_XMz ... qq-pf-to=pcqq.group
如果大家感兴趣,将会上传源码。
@svwydh 感谢
以下是源码,喜欢的可自行下载。 ESP8266获取网络天气适配战舰V3.zip
  • 签到天数: 10 天
    发表于 2017-11-27 20:53:55 | 显示全部楼层
    不错额,谢谢分享!
  • 签到天数: 10 天
    发表于 2017-11-27 20:54:26 | 显示全部楼层
    代码怎么就是个图片呢?
     楼主| 发表于 2017-12-6 15:25:19 | 显示全部楼层
    yayasoso 发表于 2017-11-27 20:54
    代码怎么就是个图片呢?
    复制过来的。
    你百度搜索一下标题,在opendv社区有原文
    GMT+8, 2024-3-29 08:16 , Processed in 0.137663 second(s), 21 queries , MemCache On.
