查看: 3484|回复: 0
Openwrt 安全模式failsafe分析
发表于 2017-12-30 14:00:25 | 显示全部楼层 |阅读模式
安全模式作用:
只加载基本的文件系统,可以修改密码,网络配置等,可以进行升级系统,Uboot等操作;
依赖hotplug机制;
procd中进行preinit初始化;同时注册hotplug 事件;
文件/etc/hotplug-preinit.json
  1.     [
  2.             [ "case", "ACTION", {
  3.                     "add": [
  4.                             [ "if",
  5.                                     [ "has", "FIRMWARE" ],
  6.                                     [
  7.                                             [ "exec", "/sbin/hotplug-call", "%SUBSYSTEM%" ],
  8.                                             [ "load-firmware", "/lib/firmware" ],
  9.                                             [ "return" ]
  10.                                     ]
  11.                             ],
  12.                     ],
  13.             }, ],
  14.             [ "if",
  15.                     [ "and",
  16.                             [ "eq", "SUBSYSTEM", "button" ],
  17.                     ],
  18.                     [ "exec", "/etc/rc.button/failsafe" ]
  19.             ],
  20.     ]
[ "exec", "/etc/rc.button/failsafe" ],检测到按键运行此脚本
  1.     #!/bin/sh
  2.
  3.     [ "${TYPE}" = "switch" ] || echo ${BUTTON} > /tmp/failsafe_button
  4.     return 0
只要按键引脚有状态变化,即创建/tmp/failsafe_button 文件,将被脚本/lib/preinit/30_failsafe_wait用到
  1.     failsafe_wait() {
  2.             FAILSAFE=
  3.             grep -q 'failsafe=' /proc/cmdline && FAILSAFE=true && export FAILSAFE
  4.             if [ "$FAILSAFE" != "true" ]; then
  5.                     pi_failsafe_net_message=true
  6.                     preinit_net_echo "Please press button now to enter failsafe"
  7.                     pi_failsafe_net_message=false
  8.                     <span style="color:#CC0000;">fs_wait_for_key</span> f 'to enter failsafe mode' $fs_failsafe_wait_timeout && FAILSAFE=true
  9.                     <span style="color:#FF6600;">[ -f "/tmp/failsafe_button" ]</span> && FAILSAFE=true && echo "- failsafe button "`cat /tmp/failsafe_button`" was pressed -"
  10.                     [ "$FAILSAFE" = "true" ] && export FAILSAFE && touch /tmp/failsafe
  11.             fi
  12.     }
  13.
  14.     boot_hook_add preinit_main failsafe_wait
fs_wait_for_key 函数处理按键 ' f ' 消息以及设定调试信息输出等级,此方式是通过系统调试串口进行;
[ -f "/tmp/failsafe_button" ] && FAILSAFE=true &&echo "- failsafe button "`cat /tmp/failsafe_button`" was pressed -"
此处 判断failsafe_button文件存在,即进入安全模式;
需要注意的是:procd 捕获按键信息,然后调用hotplug脚本,是在preinit阶段,此时overlay文件系统还未加载,使用的romfs,因此如果想禁用安全模式,不能在系统启动完后修改/etc/rc.button/failsafe脚本。因此preinit阶段,使用的romfs,用户修改的文件在overlayfs中,还未被加载;
So,禁用按键进入安全模式的方法是:在sysupgrade.bin固件编译阶段,修改/etc/rc.button/failsafe脚本,不创建/tmp/failsafe_button 文件即可;
GMT+8, 2024-4-24 23:21 , Processed in 0.115884 second(s), 15 queries , MemCache On.
