查看: 2895|回复: 0
[大赛作品提交] 基于树莓派的智能空气净化器
  • 签到天数: 8 天
    发表于 2018-1-10 20:00:24 | 显示全部楼层 |阅读模式
    感谢E络盟提供的助赛基金。
    1.原理介绍
    空气净化器在阴霾漫天的帝都是生活必不可少的生活品,在树莓派的辅助下,可以更人性化的照顾家里或办公区域的环境,通过树莓派与各个信号采集模块的绑定,可以实现信号传递与空气湿度、温度、质量等监控,通过连接空气净化模块进行空气检测,将数据采集完成后通过通信网络上传到网络服务器,实现智能空气净化器功能。
    2.系统版本
    硬件: 树莓派、pm2.5传感器模块、温度传感器、风扇、湿度传感器、滤网、滤芯、pwm调速器
    系统版本:Ubuntu
    软件:visual studio
    3.应用源代码
    1. #! /usr/bin/python
    2. # -*- coding:utf-8 -*-
    3. #
    4. import  os,commands,time
    5. #获取当前温度
    6. device_file ='/sys/bus/w1/devices/28-031681e171ff/w1_slave'#18B20设备接口
    7. def read_temp_raw():
    8.     f = open(device_file,'r')
    9.     lines = f.readlines()
    10.     f.close()
    11.     return lines
    12. def gettemperature():
    13.     temp_c=-1
    14.     lines = read_temp_raw()
    15.     while lines[0].strip()[-3:] != 'YES':
    16.         time.sleep(0.2)
    17.         lines = read_temp_raw()
    18.     equals_pos = lines[1].find('t=')
    19.     if equals_pos != -1:
    20.         temp_string = lines[1][equals_pos+2:]
    21.         temp_c = float(temp_string)/1000.0
    22.     return temp_c
    23. #获取当前湿度
    24. def gethumidity():
    25.
    26.   while 1:
    27.     channel = 21 #gpi 4
    28.     data = []
    29.     j = 0
    30.     GPIO.setmode(GPIO.BCM)
    31.     time.sleep(1)
    32.     GPIO.setup(channel, GPIO.OUT)
    33.     GPIO.output(channel, GPIO.LOW)
    34.     time.sleep(0.02)
    35.     GPIO.output(channel, GPIO.HIGH)
    36.     GPIO.setup(channel, GPIO.IN)
    37.     while GPIO.input(channel) == GPIO.LOW:
    38.       continue
    39.     while GPIO.input(channel) == GPIO.HIGH:
    40.       continue
    41.     while j < 40:
    42.       k = 0
    43.       while GPIO.input(channel) == GPIO.LOW:
    44.         continue
    45.       while GPIO.input(channel) == GPIO.HIGH:
    46.         k += 1
    47.         if k > 100:
    48.           break
    49.       if k < 8:
    50.         data.append(0)
    51.       else:
    52.         data.append(1)
    53.       j += 1
    54.     #print "sensor is working."
    55.     #print data
    56.     humidity_bit = data[0:8]
    57.     humidity_point_bit = data[8:16]
    58.     temperature_bit = data[16:24]
    59.     temperature_point_bit = data[24:32]
    60.     check_bit = data[32:40]
    61.     humidity = 0
    62.     humidity_point = 0
    63.     temperature = 0
    64.     temperature_point = 0
    65.     check = 0
    66.     for i in range(8):
    67.       humidity += humidity_bit[i] * 2 ** (7-i)
    68.       humidity_point += humidity_point_bit[i] * 2 ** (7-i)
    69.       temperature += temperature_bit[i] * 2 ** (7-i)
    70.       temperature_point += temperature_point_bit[i] * 2 ** (7-i)
    71.       check += check_bit[i] * 2 ** (7-i)
    72.     tmp = humidity + humidity_point + temperature + temperature_point
    73.     if check == tmp:
    74.       retrun humidity
    4.演示照片
    设备全图
    设备全图
    树莓派近图
    树莓派近图
    模拟器截屏
    模拟器截屏
    原理图
    原理图
    演示视频
    1.zip (2.41 MB, 下载次数: 13)
    GMT+8, 2024-4-20 11:09 , Processed in 0.127020 second(s), 18 queries , MemCache On.
