查看: 538|回复: 0
[原创] 【BPI-M2 Zero试用】LCD1602网络校时数字日历时钟
版主
  • 签到天数: 308 天
    发表于 2018-3-11 18:34:54 |显示全部楼层
    下面介绍使用BPI-M2 Zero连接LCD1602(I2C)打造网络自动对时的数字日历时钟的方法
    首先将BPI-M2 Zero开发板的SDA SCL连接到I2C接口的LCD1602的SDA SCL(下图的PIN3 PIN5),然后将LCD1602的VCC GND连接开发板的PIN2 PIN6
    从上图可知开发板的上面接口为I2C1,但是实际测试在ARMBIAN中显示为I2C0,安装如下组件
    1. sudo apt-get install i2c-tools python-smbus
    输入下面命令打开I2C-0
    1. sudo armbian-config
    保存后重启,然后输入下面命令查看I2C地址
    创建python脚本lcd-clock.py,输入下面代码
    1. import smbus
    2. import time
    3. import os
    4. from time import gmtime, strftime, localtime
    5. os.environ['TZ'] = 'Asia/Shanghai'
    6. time.tzset()
    7. bus = smbus.SMBus(0)
    8. addr = 0x3f
    9. def writeCommand(command):
    10.    bus.write_byte(addr, 0b1100 | command << 4)
    11.    time.sleep(0.005)
    12.    bus.write_byte(addr, 0b1000 | command << 4)
    13.    time.sleep(0.005)
    14. def writeWord(word):
    15.    for i in range(0,len(word)):
    16.       asciiCode =  ord(word[i])
    17.       bus.write_byte(addr, 0b1101 |(asciiCode >> 4 & 0x0F) << 4)
    18.       time.sleep(0.0005)
    19.       bus.write_byte(addr, 0b1001 |(asciiCode >> 4 & 0x0F) << 4)
    20.       time.sleep(0.0005)
    21.       bus.write_byte(addr, 0b1101 |(asciiCode & 0x0F) << 4)
    22.       time.sleep(0.0005)
    23.       bus.write_byte(addr, 0b1001 | (asciiCode & 0x0F) << 4)
    24.       time.sleep(0.0005)
    25. # init
    26. writeCommand(0b0010)
    27. # 4-byte mode, 2 line code
    28. writeCommand(0b0010)
    29. writeCommand(0b1111)
    30. # set cursor mode
    31. writeCommand(0b0000)
    32. writeCommand(0b1100)
    33. # cursor shift mode
    34. writeCommand(0b0000)
    35. writeCommand(0b0110)
    36. writeWord("Welcome")
    37. clear = True
    38. time.sleep(1)
    39. while(1):
    40.    # first line first column
    41.    writeCommand(0b1000)
    42.    writeCommand(0b0000)
    43.    writeWord(strftime("%Y-%m-%d, %a ", localtime()))
    44.    # second line first column
    45.    writeCommand(0b1100)
    46.    writeCommand(0b0000)
    47.    writeWord(strftime("%H:%M:%S", localtime()))
    48.    time.sleep(0.2)
    运行
    1. sudo python lcd-clock.py
    显示效果如下
    GMT+8, 2018-9-22 10:13 , Processed in 0.115065 second(s), 13 queries , MemCache On.
