查看: 1879|回复: 0
Micropython TPYBoard I2C的用法
    2018-1-6 09:01
  • 签到天数: 7 天
    发表于 2018-5-25 11:11:56 | 显示全部楼层 |阅读模式
    先看看基本用法:
        from pyb import I2C
        i2c = I2C(1)                         # create on bus 1
        i2c = I2C(1, I2C.MASTER)             # create and init as a master
        i2c.init(I2C.MASTER, baudrate=20000) # init as a master
        i2c.init(I2C.SLAVE, addr=0x42)       # init as a slave with given address
        i2c.deinit()                         # turn off the peripheral
        i2c.init(I2C.MASTER)
        i2c.send('123', 0x42)        # send 3 bytes to slave with address 0x42
        i2c.send(b'456', addr=0x42)  # keyword for address
        i2c.is_ready(0x42)           # check if slave 0x42 is ready
        i2c.scan()                   # scan for slaves on the bus, returning
        #   a list of valid addresses
        i2c.mem_read(3, 0x42, 2)     # read 3 bytes from memory of slave 0x42,
        #   starting at address 2 in the slave
        i2c.mem_write('abc', 0x42, 2, timeout=1000) # write 'abc' (3 bytes) to memory of slave 0x42
        # starting at address 2 in the slave, timeout after 1 second
    I2C的用法:
    class pyb.I2C(bus, ...)
    bus,I2C总线的序号
    i2c.deinit(),解除I2C定义
    i2c.init(mode, *, addr=0x12, baudrate=400000, gencall=False),初始化
    mode,只能是 I2C.MASTER 或 I2C.SLAVE
    addr,7位I2C地址
    baudrate,时钟频率
    gencall,通用调用模式
    i2c.is_ready(addr),检测I2C设备是否响应,只对主模式有效
    i2c.mem_read(data, addr, memaddr, *, timeout=5000, addr_size=8),读取数据
    data,整数或者缓存
    addr,设备地址
    memaddr,内存地址
    timeout,读取等待超时时间
    addr_size,memaddr的大小。8位或16位
    i2c.mem_write(data, addr, memaddr, *, timeout=5000, addr_size=8),写入数据,参数含义同上
    i2c.recv(recv, addr=0x00, *, timeout=5000),从总线读取数据
    recv,需要读取数据数量,或者缓冲区
    addr,I2C地址
    timeout,超时时间
    i2c.send(send, addr=0x00, *, timeout=5000)
    send,整数或者缓冲区
    addr,I2C地址
    timeout,超时时间
    i2c.scan(),搜索I2C总线上设备。
    GMT+8, 2024-5-2 06:40 , Processed in 0.113398 second(s), 15 queries , MemCache On.
