TA的每日心情 | 开心 2024-1-16 17:48 |
签到天数: 592 天 连续签到: 1 天 [LV.9]以坛为家II
核心代码不到 200 行,整个程序不到 400 行代码,模块化编写,很容易扩展功能,很容易扩展菜单选项,从 uboot 源码和 kernel 驱动,学的框架,先看运行效果:
源码:- /*============================ h 头文件,全局变量,结构体,枚举类型 */
- #include<stdio.h>
- #include<string.h>
- #include<stdlib.h>
- #include<unistd.h>
- #define CHAR_SIZE 0x80
- #define MENU_SIZE array_size()
- #define MODULE_ITEM(item_x,menu,type_x,fn_x) \
- item_type item_x={ \
- .name=menu, \
- .type=type_x, \
- .fn_cmd=fn_x, \
- char input[CHAR_SIZE];
- int error_info;
- volatile int menu_color=37;
- volatile int menu_bg_color=40;
- typedef struct item{
- char name[CHAR_SIZE];
- int type;
- int (*fn_cmd)(void);
- }item_type;
- enum type{
- e_menu,
- e_item,
- e_max,
- /* =============================================== 菜单项
- * 增加,删除菜单项方法:
- * 1,实现功能函数,并使用MODULE_ITEM声明一个菜单项
- * int fn_a(void)
- * printf("sleeping......\n");
- * sleep(1);
- * printf("sucessed!\n");
- * return 0;
- * MODULE_ITEM(item_a,"a: delay 1 sec.",e_item,fn_a)
- * 2,把菜单项(item_a)添加到第 240 行的 menu 列表中。
- * item_type *menu[]={
- * &item_a,
- * &item_b,
- int fn_a(void)
- printf("sleeping......\n");
- sleep(1);
- printf("sucessed!\n");
- return 0;
- MODULE_ITEM(item_a,"a: delay 1 sec.",e_item,fn_a)
- int fn_b(void)
- printf("hello,world.\n");
- return 0;
- MODULE_ITEM(item_b,"b: print "hello,world!"",e_item,fn_b)
- int fn_c(void)
- printf("beep......\n");
- system("echo -n "\a" ");
- return 0;
- MODULE_ITEM(item_c,"c: beep",e_item,fn_c)
- int fn_d(void)
- system("echo "\e[32m hello linux!\e[0m"");
- return 0;
- MODULE_ITEM(item_d,"d: print green font",e_item,fn_d)
- int fn_e(void)
- system("echo "\e[33m hello linux!\e[0m"");
- return 0;
- MODULE_ITEM(item_e,"e: print yellow font",e_item,fn_e)
- int fn_f(void)
- system("echo "\e[34m hello linux!\e[0m"");
- return 0;
- MODULE_ITEM(item_f,"f: print blue font",e_item,fn_f)
- int fn_g(void)
- system("echo "\e[35m hello linux!\e[0m"");
- return 0;
- MODULE_ITEM(item_g,"g: print 紫色 font",e_item,fn_g)
- int fn_h(void)
- system("echo "\e[36m hello linux!\e[0m"");
- return 0;
- MODULE_ITEM(item_h,"h: print 青色 font",e_item,fn_h)
- int fn_i(void)
- menu_color=31;
- return 0;
- MODULE_ITEM(item_i,"i: change menu font color to red",e_item,fn_i)
- int fn_j(void)
- menu_color=32;
- return 0;
- MODULE_ITEM(item_j,"j: change menu font color to green",e_item,fn_j)
- int fn_k(void)
- menu_color=33;
- return 0;
- MODULE_ITEM(item_k,"k: change menu font color to yellow",e_item,fn_k)
- int fn_l(void)
- menu_color=34;
- return 0;
- MODULE_ITEM(item_l,"l: change menu font color to blue",e_item,fn_l)
- int fn_m(void)
- menu_color=35;
- return 0;
- MODULE_ITEM(item_m,"m: change menu font color to 紫色",e_item,fn_m)
- int fn_n(void)
- menu_color=36;
- return 0;
- MODULE_ITEM(item_n,"n: change menu font color to 青色",e_item,fn_n)
- int fn_o(void)
- menu_color=30;
- return 0;
- MODULE_ITEM(item_o,"o: change menu font color to black",e_item,fn_o)
- int fn_p(void)
- menu_color=37;
- return 0;
- MODULE_ITEM(item_p,"p: change menu font color to default",e_item,fn_p)
- int fn_q(void)
- menu_bg_color=41;
- return 0;
- MODULE_ITEM(item_q,"q: change menu background color to red",e_item,fn_q)
- int fn_r(void)
- menu_bg_color=42;
- return 0;
- MODULE_ITEM(item_r,"r: change menu background color to green",e_item,fn_r)
- int fn_s(void)
- menu_bg_color=43;
- return 0;
- MODULE_ITEM(item_s,"s: change menu background color to yellow",e_item,fn_s)
- int fn_t(void)
- menu_bg_color=44;
- return 0;
- MODULE_ITEM(item_t,"t: change menu background color to blue",e_item,fn_t)
- int fn_u(void)
- menu_bg_color=45;
- return 0;
- MODULE_ITEM(item_u,"u: change menu background color to 紫色",e_item,fn_u)
- int fn_v(void)
- menu_bg_color=46;
- return 0;
- MODULE_ITEM(item_v,"v: change menu background color to 青色",e_item,fn_v)
- int fn_w(void)
- menu_bg_color=47;
- return 0;
- MODULE_ITEM(item_w,"w: change menu background color to black",e_item,fn_w)
- int fn_x(void)
- exit(0);
- return 0;
- MODULE_ITEM(item_x,"x: exit.",e_item,fn_x)
- int fn_y(void)
- menu_bg_color=40;
- menu_color=37;
- return 0;
- MODULE_ITEM(item_y,"y: reset menu color to default",e_item,fn_y)
- int fn_z(void)
- printf("this project is the demo for uboot code arch.\n");
- printf(" build by Robe 2018.9.4 \n");
- return 0;
- MODULE_ITEM(item_z,"z: print project info.",e_item,fn_z)
- /* ==============================================菜单列表 */
- item_type *menu[]={
- &item_a,
- &item_b,
- &item_c,
- &item_d,
- &item_e,
- &item_f,
- &item_g,
- &item_h,
- &item_i,
- &item_j,
- &item_k,
- &item_l,
- &item_m,
- &item_n,
- &item_o,
- &item_p,
- &item_q,
- &item_r,
- &item_s,
- &item_t,
- &item_u,
- &item_v,
- &item_w,
- &item_x,
- &item_y,
- &item_z,
- NULL,
- /*=====================================================main */
- int array_size(void)
- int i;
- for(i=0;;i++)
- if (menu[i]==NULL) break;
- return i;
- int init(void)
- error_info=1;
- memset(input,0,CHAR_SIZE);
- int list_menu(void)
- printf("\033[0;%d;%dm",menu_color,menu_bg_color);
- system("clear");
- printf("============ MENU: by Robe @2018.9.4 ==========\n");
- for(int i=0;i<MENU_SIZE;i++)
- printf("%s \n",menu[i]->name);
- printf("===============================================");
- printf("\033[0;0m\n");
- int input_selection(void)
- printf("please select the item: ");
- scanf("%s",input);
- int action(void)
- if(input[0]==menu[i]->name[0])
- menu[i]->fn_cmd();
- error_info=0;
- printf("\n");
- if (error_info==1)
- printf("error: canot find your select item \n");
- system("echo "\a"");
- int after_action(void)
- usleep(1000000);
- int main(void)
- while(1)
- init();
- list_menu();
- input_selection();
- action();
- after_action();
- return 0;
