查看: 1615|回复: 1
VS-RK3399嵌入式安卓主板如何修改并默认HDMI分辨率?
    2021-6-29 16:40
  • 签到天数: 6 天
    发表于 2020-7-16 13:03:21 | 显示全部楼层 |阅读模式
    VS-RK3399嵌入式安卓主板修改并默认HDMI分辨率
    过滤HDMI分辨率
    驱动部分
            kernel/drivers/gpu/drm/rockchip/dw_hdmi-rockchip.c
                    static enum drm_mode_status
                    dw_hdmi_rockchip_mode_valid(struct drm_connector *connector,
                                                    struct drm_display_mode *mode)
                            struct drm_encoder *encoder = connector->encoder;
                            enum drm_mode_status status = MODE_OK;
                            struct drm_device *dev = connector->dev;
                            struct rockchip_drm_private *priv = dev->dev_private;
                            struct drm_crtc *crtc;
                             * Pixel clocks we support are always < 2GHz and so fit in an
                             * int.  We should make sure source rate does too so we don't get
                             * overflow when we multiply by 1000.
    +                        if(!(!strcmp(mode->name, "4096x2160") || !strcmp(mode->name, "3840x2160") ||
    +                                ((!strcmp(mode->name, "1920x1080")) && mode->vrefresh == 60)||
    +                                ((!strcmp(mode->name, "1366x768")) && mode->vrefresh == 60)||
    +                                ((!strcmp(mode->name, "1280x720")) && mode->vrefresh == 60))){
    +                                printk(KERN_ERR"bad mode:%s, vrefresh:%dn",mode->name, mode->vrefresh);
    +                                return MODE_BAD;
    默认HDMI分辨率
            out/target/product/rk3399_mid/system/build.prop
            添加persist.sys.resolution.aux=4096x2160p60
    2021-6-29 16:40
  • 签到天数: 6 天
     楼主| 发表于 2020-7-16 13:03:22 | 显示全部楼层
    欢迎探讨,更多技术交流17796350642
    GMT+8, 2024-5-15 07:38 , Processed in 0.126407 second(s), 20 queries , MemCache On.
