查看: 20056|回复: 0
[教程] 树莓派教程之小型web服务器
  • 签到天数: 361 天
    发表于 2014-2-20 09:18:33 | 显示全部楼层 |阅读模式
    这次要搭建一个nginx+php+mysql+dnspod动态解析
    有路由器的么直接去路由器管理界面把树莓的mac绑定下,再映射这样会方便很多,不用担心ip变掉。
    首先sudo su获得root权限后操作会方便很多
    apt-get update
    apt-get install nginx php5-fpm php5-cli php5-curl php5-gd php5-mcrypt php5-mysql php5-cgi mysql-server
    安装期间会提示叫你输入数据库密码(这必须要记住..)
    • 环境配置
    在root权限命令行输入命令
    nano /etc/nginx/nginx.conf
    对照修改如下
    开头部分
    user www-data;worker_processes 1;   修改这里pid /var/run/nginx.pid;events {worker_connections 64; 修改这里# multi_accept on;}
    继续向后找到gzip  去掉前面的注释 修改如下
    gzip on;gzip_disable "msie6";gzip_vary on;gzip_proxied any;gzip_comp_level 6;gzip_buffers 16 8k;gzip_http_version 1.1;gzip_types text/plain text/css application/json application/x-javascript text/xml application/xml application/xml+rss text/javascript;
    Ctrol+O保存 Ctrl+X退出
    在root权限命令行输入命令
    nano /etc/php5/fpm/php.ini
    找到这一段
    ; Maximum amount of memory a script may consume (128MB) ; http://php.net/memory-limit memory_limit = 32M  修改这里 找到这一段 ; cgi.fix_pathinfo provides *real* PATH_INFO/PATH_TRANSLATED support for CGI.  PHP's ; previous behaviour was to set PATH_TRANSLATED to SCRIPT_FILENAME, and to not grok ; what PATH_INFO is.  For more information on PATH_INFO, see the cgi specs.  Setting ; this to 1 will cause PHP CGI to fix its paths to conform to the spec.  A setting ; of zero causes PHP to behave as before.  Default is 1.  You should fix your scripts ; to use SCRIPT_FILENAME rather than PATH_TRANSLATED. ;http://php.net/cgi.fix-pathinfo cgi.fix_pathinfo=1  修改这里
    在root权限命令行输入命令
    nano /etc/php5/fpm/php-fpm.conf
    找到这一段
    ; The maximum number of processes FPM will fork. This has been design to control ; the global number of processes when using dynamic PM within a lot of pools. ; Use it with caution. ; Note: A value of 0 indicates no limit ; Default Value: 0 process.max = 4  修改这里
    接着改nginx
    nano /etc/nginx/sites-enabled/default
    找到这里 修改如下
    # Please see /usr/share/doc/nginx-doc/examples/ for more detailed examples.##server {listen   80; ## listen for ipv4; this line is default and implied#listen   [::]:80 default_server ipv6only=on; ## listen for ipv6root /home/pi/www; #建议放在此文件夹内,以后管理更加方便# index index.html index.htm;index index.php index.html index.htm;# Make site accessible from http://localhost/server_name localhost;
    在这句后面增加以下内容
           if (!-e $request_filename) {rewrite ^(.*)$ /index.php$1 last;}
    找到这句
    location ~ .php$ {
    连同后续内容修改如下
       location ~ .*.php(/.*)*${#fastcgi_split_path_info ^(.+.php)(/.+)$;#       # NOTE: You should have "cgi.fix_pathinfo = 0;" in php.ini##       # With php5-cgi alone:#       fastcgi_pass 127.0.0.1:9000;#       # With php5-fpm:fastcgi_pass unix:/var/run/php5-fpm.sock;fastcgi_index index.php;include fastcgi_params;}
    完成之后重新加载服务
    service nginx reloadservice php5-fpm reloadservice mysql reload
    接下来安装phpmyadmin
    mkdir /home/pi/wwwwget http://downloads.sourceforge.net ... -languages.zipunzip phpMyAdmin-3.5.7-all-languages.zip
    最后给文件夹权限
    chown www-data:www-data /home/pi/www -Rchmod 755 /home/pi/www -R
    最后是dnspod的设置
    https://gist.github.com/chuangbo/833369
    这里已有源代码
    需要修改的地方如下
    params = dict(login_email="email", # dnspod的邮箱login_password="password", # 你的密码format="json",domain_id=100, #domain_id http://geekpi.cn/dnspod域名编号去左边的连接获取record_id=100, # record_id 记录id同上,子域名前面的编号sub_domain="www", # 你想要解析的子域名record_line="默认",)
    保存为dnspod.py
    然后输入 nohup python main.py &
    就已经在后台运行了按ctrl+c也不会退出,只有用kill才能删除进程
    GMT+8, 2024-4-26 22:04 , Processed in 0.101375 second(s), 15 queries , MemCache On.
