TA的每日心情 | 开心 2013-10-31 08:31 |
签到天数: 16 天 连续签到: 1 天 [LV.4]偶尔看看III
楼主 |
发表于 2014-4-18 18:10:55
显示全部楼层
来来来,看看串口登录的第一条指令- root@RIoTboard_6solo:/ # reboot
- SysRq : Emergency Remount R/O
- EXT4-fs (mmcblk0p4): re-mounted. Opts: (null)
- EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
- Emergency Remount complete
- imx2-wdt imx2-wdt.0: Device shutdown: Expect reboot!
- Restarting system.
- U-Boot 2009.08-00695-g055df3a-dirty (Mar 10 2014 - 10:33:47)
- CPU: Freescale i.MX6 family TO1.1 at 792 MHz
- Thermal sensor with ratio = 186
- Temperature: 41 C, calibration data 0x59b5195f
- mx6q pll1: 792MHz
- mx6q pll2: 528MHz
- mx6q pll3: 480MHz
- mx6q pll8: 50MHz
- ipg clock : 66000000Hz
- ipg per clock : 66000000Hz
- uart clock : 80000000Hz
- cspi clock : 60000000Hz
- ahb clock : 132000000Hz
- axi clock : 198000000Hz
- emi_slow clock: 99000000Hz
- ddr clock : 396000000Hz
- usdhc1 clock : 198000000Hz
- usdhc2 clock : 198000000Hz
- usdhc3 clock : 198000000Hz
- usdhc4 clock : 198000000Hz
- nfc clock : 24000000Hz
- Board: i.MX6DL/Solo-RIoTboard: 0x61011 [WDOG ]
- Boot Device: MMC
- I2C: ready
- DRAM: 1 GB
- MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
- *** Warning - bad CRC or MMC, using default environment
- In: serial
- Out: serial
- Err: serial
- Net: got MAC address from IIM: 00:00:00:00:00:00
- ----enet_board_init: phy reset
- FEC0 [PRIME]
- Hit any key to stop autoboot: 3 2 1 0
- kernel @ 10808000 (4739640)
- ramdisk @ 11800000 (233777)
- kernel cmdline:
- use uboot command line:
- console=ttymxc1,115200 init=/init nosmp video=mxcfb0:dev=hdmi,1280x720M@60,bpp=32 video=mxcfb1:off fbmem=10M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale
- Starting kernel ...
- Initializing cgroup subsys cpu
- Linux version 3.0.35-06430-gd4e9d43-dirty (android@embest-tech) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #4 SMP PREEMPT Fri Mar 7 17:32:26 CST 2014
- CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
- CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
- Machine: Freescale i.MX 6Solo RIoTboard
- Ignoring unrecognised tag 0x54410008
- Memory policy: ECC disabled, Data cache writealloc
- CPU identified as i.MX6DL/SOLO, silicon rev 1.1
- PERCPU: Embedded 7 pages/cpu @c1309000 s6592 r8192 d13888 u32768
- Built 1 zonelists in Zone order, mobility grouping on. Total pages: 208128
- Kernel command line: console=ttymxc1,115200 init=/init nosmp video=mxcfb0:dev=hdmi,1280x720M@60,bpp=32 video=mxcfb1:off fbmem=10M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale
- PID hash table entries: 2048 (order: 1, 8192 bytes)
- Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
- Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
- Memory: 767MB 54MB = 821MB total
- Memory: 820552k/820552k available, 228024k reserved, 431104K highmem
- Virtual kernel memory layout:
- vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
- DMA : 0xfbe00000 - 0xffe00000 ( 64 MB)
- vmalloc : 0xd9800000 - 0xf2000000 ( 392 MB)
- lowmem : 0xc0000000 - 0xd9000000 ( 400 MB)
- pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
- modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
- .init : 0xc0008000 - 0xc0046000 ( 248 kB)
- .text : 0xc0046000 - 0xc08d4f94 (8764 kB)
- .data : 0xc08d6000 - 0xc0977de0 ( 648 kB)
- .bss : 0xc0977e04 - 0xc0affb48 (1568 kB)
- Preemptible hierarchical RCU implementation.
- NR_IRQS:624
- MXC GPIO hardware
- sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
- Set periph_clk's parent to pll2_pfd_400M!
- arm_max_freq=1GHz
- MXC_Early serial console at MMIO 0x21e8000 (options '115200')
- bootconsole [ttymxc1] enabled
- Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
- pid_max: default: 32768 minimum: 301
- Mount-cache hash table entries: 512
- Initializing cgroup subsys debug
- Initializing cgroup subsys cpuacct
- Initializing cgroup subsys freezer
- CPU: Testing write buffer coherency: ok
- hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
- Brought up 1 CPUs
- SMP: Total of 1 processors activated (1581.05 BogoMIPS).
- print_constraints: dummy:
- NET: Registered protocol family 16
- print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
- print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
- print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
- print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
- print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
- print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
- ram_console: got buffer at 3ff00000, size 100000
- ram_console: found existing buffer, size 32368, start 32368
- console [ram-1] enabled
- ----ldb_init
- hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
- hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
- hw-breakpoint: maximum watchpoint size is 4 bytes.
- L310 cache controller enabled
- l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32050000, Cache size: 524288 B
- bio: create slab <bio-0> at 0
- mxs-dma mxs-dma-apbh: initialized
- print_constraints: VDDA: 2500 mV
- print_constraints: VDDIO: 3300 mV
- machine_constraints_voltage: VDDD: unsupportable voltage constraints
- reg-fixed-voltage reg-fixed-voltage.2: Failed to register regulator: -22
- reg-fixed-voltage: probe of reg-fixed-voltage.2 failed with error -22
- print_constraints: vmmc: 3300 mV
- vgaarb: loaded
- SCSI subsystem initialized
- spi_imx imx6q-ecspi.0: probed
- usbcore: registered new interface driver usbfs
- usbcore: registered new interface driver hub
- usbcore: registered new device driver usb
- Freescale USB OTG Driver loaded, $Revision: 1.55 $
- mc_pfuze 1-0008: recv failed!:-5,0
- mc_pfuze: probe of 1-0008 failed with error -1
- imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
- mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
- mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
- MIPI CSI2 driver module loaded
- Advanced Linux Sound Architecture Driver Version 1.0.24.
- Bluetooth: Core ver 2.16
- NET: Registered protocol family 31
- Bluetooth: HCI device and connection manager initialized
- Bluetooth: HCI socket layer initialized
- Bluetooth: L2CAP socket layer initialized
- Bluetooth: SCO socket layer initialized
- i2c-core: driver [max17135] using legacy suspend method
- i2c-core: driver [max17135] using legacy resume method
- Switching to clocksource mxc_timer1
- NET: Registered protocol family 2
- IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
- TCP established hash table entries: 65536 (order: 7, 524288 bytes)
- TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
- TCP: Hash tables configured (established 65536 bind 65536)
- TCP reno registered
- UDP hash table entries: 256 (order: 1, 8192 bytes)
- UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
- RPC: Registered named UNIX socket transport module.
- RPC: Registered udp transport module.
- RPC: Registered tcp transport module.
- RPC: Registered tcp NFSv4.1 backchannel transport module.
- PCI: CLS 0 bytes, default 32
- Unpacking initramfs...
- Freeing initrd memory: 228K
- PMU: registered new PMU device of type 0
- Static Power Management for Freescale i.MX6
- wait mode is enabled for i.MX6
- cpaddr = d9820000 suspend_iram_base=d98b8000
- PM driver module loaded
- IMX usb wakeup probe
- the wakeup pdata is 0xd63fbb20
- add wake up source irq 75
- the wakeup pdata is 0xd63fb8e0
- cpu regulator mode:ldo_enable
- i.MXC CPU frequency driver
- highmem bounce pool size: 64 pages
- ashmem: initialized
- NTFS driver 2.1.30 [Flags: R/O].
- JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
- fuse init (API version 7.16)
- msgmni has been set to 761
- NET: Registered protocol family 38
- cryptodev: driver loaded.
- io scheduler noop registered
- io scheduler deadline registered
- io scheduler cfq registered (default)
- mxc_mipi_dsi mxc_mipi_dsi: i.MX MIPI DSI driver probed
- MIPI DSI driver module loaded
- mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi
- mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0x1a:0xa0:0xc1
- fbcvt: 1280x720@60: CVT Name - .921M9
- imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
- mxc_sdc_fb mxc_sdc_fb.1: Can't get fb option for mxcfb1!
- imx-sdma imx-sdma: loaded firmware 1.1
- imx-sdma imx-sdma: initialized
- Serial: IMX driver
- imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
- imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
- console [ttymxc1] enabled, bootconsole disabled
- imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
- loop: module loaded
- m25p80 spi0.0: unrecognized JEDEC id ffffff
- GPMI NAND driver registered. (IMX)
- vcan: Virtual CAN interface driver
- CAN device driver interface
- flexcan netdevice driver
- FEC Ethernet Driver
- fec_enet_mii_bus: probed
- PPP generic driver version 2.4.2
- PPP Deflate Compression module registered
- PPP BSD Compression module registered
- PPP MPPE Compression module registered
- NET: Registered protocol family 24
- PPTP driver version 0.8.5
- tun: Universal TUN/TAP device driver, 1.6
- tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
- ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
- fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
- fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
- fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
- fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
- hub 1-0:1.0: USB hub found
- hub 1-0:1.0: 1 port detected
- add wake up source irq 72
- fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
- fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
- fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
- fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
- hub 2-0:1.0: USB hub found
- hub 2-0:1.0: 1 port detected
- usbcore: registered new interface driver cdc_acm
- cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
- Initializing USB Mass Storage driver...
- usbcore: registered new interface driver usb-storage
- USB Mass Storage support registered.
- usbcore: registered new interface driver usbserial
- usbserial: USB Serial Driver core
- USB Serial support registered for GSM modem (1-port)
- usbcore: registered new interface driver option
- option: v0.7.2:USB Driver for GSM modems
- USB Serial support registered for Qualcomm USB modem
- usbcore: registered new interface driver qcserial
- ARC USBOTG Device Controller driver (1 August 2005)
- android_usb gadget: Mass Storage Function, version: 2009/09/11
- android_usb gadget: Number of LUNs=1
- lun0: LUN: removable file: (no medium)
- Gadget Android: controller 'fsl-usb2-udc' not recognized
- android_usb gadget: android_usb ready
- Suspend udc for OTG auto detect
- USB Host suspend begins
- will suspend roothub and its children
- ehci_fsl_bus_suspend begins, DR
- ehci_fsl_bus_suspend ends, DR
- host suspend ends
- USB Gadget resume begins
- fsl_udc_resume, Wait for wakeup thread finishes
- dr_controller_run: udc enter low power mode
- USB Gadget resume ends
- fsl-usb2-udc: bind to driver android_usb
- mousedev: PS/2 mouse device common for all mice
- generic touchscreen driver, <@>.
- usb 2-1: new high speed USB device number 2 using fsl-ehci
- hub 2-1:1.0: USB hub found
- hub 2-1:1.0: 4 ports detected
- >>>>> ct365_get_vendor() called <<<<<
- Chip ID: 0x0
- Chip data allocation failed: 0x0
- i2c-core: driver [generic_ts] using legacy suspend method
- i2c-core: driver [generic_ts] using legacy resume method
- i2c-core: driver [isl29023] using legacy suspend method
- i2c-core: driver [isl29023] using legacy resume method
- using rtc device, snvs_rtc, for alarms
- snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
- i2c /dev entries driver
- Linux video capture interface: v2.00
- mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
- mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
- usbcore: registered new interface driver uvcvideo
- USB Video Class driver (v1.1.0)
- i2c-core: driver [mag3110] using legacy suspend method
- i2c-core: driver [mag3110] using legacy resume method
- imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
- device-mapper: uevent: version 1.0.3
- device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
- Bluetooth: Virtual HCI driver ver 1.3
- Bluetooth: HCI UART driver ver 2.2
- Bluetooth: HCIATH3K protocol initialized
- Bluetooth: Generic Bluetooth USB driver ver 0.6
- usbcore: registered new interface driver btusb
- sdhci: Secure Digital Host Controller Interface driver
- sdhci: Copyright(c) Pierre Ossman
- mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using ADMA
- mmc1: SDHCI controller on platform [sdhci-esdhc-imx.1] using ADMA
- mmc2: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA
- mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
- VPU initialized
- mxc_asrc registered
- Galcore version 4.6.9.6622
- revserved_memory_account:viv_gpu registerd
- Thermal calibration data is 0x59b5195f
- Anatop Thermal registered as thermal_zone0
- anatop_thermal_probe: default cooling device is cpufreq!
- Registered led device: sys_led
- Registered led device: user_led
- usbcore: registered new interface driver usbhid
- usbhid: USB HID core driver
- mmc0: new high speed DDR MMC card at address 0001
- logger: created 256K log 'log_main'
- mmcblk0: mmc0:0001 MMC04G 3.57 GiB
- logger: created 256K log 'log_events'
- mmcblk0boot0: mmc0:0001 MMC04G partition 1 2.00 MiB
- logger: created 256K log 'log_radio'
- mmcblk0boot1: mmc0:0001 MMC04G partition 2 2.00 MiB
- logger: created 256K log 'log_system'
- usbcore: registered new interface driver snd-usb-audio
- mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
- Cirrus Logic CS42888 ALSA SoC Codec Driver
- i2c-core: driver [cs42888] using legacy suspend method
- i2c-core: driver [cs42888] using legacy resume method
- mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4
- mmcblk0: p4 size 5324800 extends beyond EOD, truncated
- mmcblk0boot1: unknown partition table
- mmcblk0boot0: unknown partition table
- ----sab_sgtl5000_init
- ----enable clko_clk.
- sgtl5000 0-000a: Failed to get supply 'VDDD': -19
- print_constraints: 0-000a: 850 <--> 1600 mV at 1200 mV normal
- sgtl5000 0-000a: sgtl5000 revision 17
- asoc: sgtl5000 <-> imx-ssi.1 mapping ok
- imx_3stack asoc driver
- asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok
- ALSA device list:
- #0: sgtl5000-audio
- #1: imx-hdmi-soc
- oprofile: using arm/armv7-ca9
- GACT probability NOT on
- Mirror/redirect action on
- u32 classifier
- Actions configured
- Netfilter messages via NETLINK v0.30.
- nf_conntrack version 0.5.0 (12824 buckets, 51296 max)
- ctnetlink v0.93: registering with nfnetlink.
- NF_TPROXY: Transparent proxy support initialized, version 4.1.0
- NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
- xt_time: kernel timezone is -0000
- IPv4 over IPv4 tunneling driver
- GRE over IPv4 demultiplexor driver
- ip_tables: (C) 2000-2006 Netfilter Core Team
- arp_tables: (C) 2002 David S. Miller
- TCP cubic registered
- NET: Registered protocol family 10
- Mobile IPv6
- ip6_tables: (C) 2000-2006 Netfilter Core Team
- IPv6 over IPv4 tunneling driver
- NET: Registered protocol family 17
- NET: Registered protocol family 15
- can: controller area network core (rev 20090105 abi 8)
- NET: Registered protocol family 29
- can: raw protocol (rev 20090105)
- can: broadcast manager protocol (rev 20090105 t)
- Bluetooth: RFCOMM TTY layer initialized
- Bluetooth: RFCOMM socket layer initialized
- Bluetooth: RFCOMM ver 1.11
- Bluetooth: BNEP (Ethernet Emulation) ver 1.3
- Bluetooth: BNEP filters: protocol multicast
- Bluetooth: HIDP (Human Interface Emulation) ver 1.2
- L2TP core driver, V2.0
- PPPoL2TP kernel driver, V2.0
- L2TP IP encapsulation support (L2TPv3)
- L2TP netlink interface
- L2TP ethernet pseudowire support (L2TPv3)
- lib80211: common routines for IEEE802.11 drivers
- lib80211_crypt: registered algorithm 'NULL'
- lib80211_crypt: registered algorithm 'WEP'
- lib80211_crypt: registered algorithm 'CCMP'
- lib80211_crypt: registered algorithm 'TKIP'
- VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
- Bus freq driver module loaded
- Bus freq driver Enabled
- mxc_dvfs_core_probe
- DVFS driver module loaded
- snvs_rtc snvs_rtc.0: setting system clock to 1970-01-02 00:03:17 UTC (86597)
- Freeing init memory: 248K
- android_usb: already disabled
- mtp_bind_config
- root@RIoTboard_6solo:/ # _pages_prepare+0x100/0x188) from [<c00ffe04>] (free_hot_cold_page+0x20/0x1b4)
- [<c00ffe04>] (free_hot_cold_page+0x20/0x1b4) from [<c0057714>] (dma_free_coherent+0x13c/0x1c4)
- [<c0057714>] (dma_free_coherent+0x13c/0x1c4) from [<c02e6b5c>] (mxcfb_set_par+0x558/0x834)
- [<c02e6b5c>] (mxcfb_set_par+0x558/0x834) from [<c02d4d88>] (fb_set_var+0x124/0x290)
- [<c02d4d88>] (fb_set_var+0x124/0x290) from [<c02d5200>] (do_fb_ioctl+0x30c/0x5d0)
- [<c02d5200>] (do_fb_ioctl+0x30c/0x5d0) from [<c01405c0>] (do_vfs_ioctl+0x80/0x54c)
- [<c01405c0>] (do_vfs_ioctl+0x80/0x54c) from [<c0140ac4>] (sys_ioctl+0x38/0x5c)
- [<c0140ac4>] (sys_ioctl+0x38/0x5c) from [<c004c900>] (ret_fast_syscall+0x0/0x30)
- BUG: Bad page state in process SurfaceFlinger pfn:4f62d
- page:c12ec5a0 count:0 mapcount:0 mapping: (null) index:0x0
- page flags: 0x40000400(reserved)
- [<c0053fc4>] (unwind_backtrace+0x0/0x138) from [<c00fe2b0>] (bad_page+0x9c/0xf8)
- [<c00fe2b0>] (bad_page+0x9c/0xf8) from [<c00fe40c>] (free_pages_prepare+0x100/0x188)
- [<c00fe40c>] (free_pages_prepare+0x100/0x188) from [<c00ffe04>] (free_hot_cold_page+0x20/0x1b4)
- BUG: Bad page state in process SurfaceFlinger pfn:4f62e
- page:c12ec5c0 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f62f
- page:c12ec5e0 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f630
- page:c12ec600 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f631
- page:c12ec620 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f632
- page:c12ec640 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f633
- page:c12ec660 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f634
- page:c12ec680 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f635
- page:c12ec6a0 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f636
- page:c12ec6c0 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f637
- page:c12ec6e0 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f638
- page:c12ec700 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f639
- page:c12ec720 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f63a
- page:c12ec740 count:0 mapcount:0 mapping: (null) index:0x0
- BUG: Bad page state in process SurfaceFlinger pfn:4f63b
- page:c12ec760 count:0 mapcount:0 mapping: (null) index:0x0
- ehci_fsl_bus_suspend begins, Host 1
- ehci_fsl_bus_suspend ends, Host 1
- ERROR: v4l2 capture: slave not found!
- ERROR: HDMI is not ready!
- asoc: can't open platform imx-hdmi-soc-audio.0
- warning: `zygote' uses 32-bit capabilities (legacy support in use)
- request_suspend_state: wakeup (3->0) at 14780244338 (1970-01-02 00:03:28.785381003 UTC)
- eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:04, irq=-1)
- ADDRCONF(NETDEV_UP): eth0: link is not ready
- acc_open
- acc_release
- ehci_fsl_bus_resume begins, Host 1
- ehci_fsl_bus_resume ends, Host 1
- ehci_fsl_bus_resume begins, DR
- init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
复制代码 |
