查看: 2697|回复: 2
圆点博士小四轴通讯指令的执行代码
  • 签到天数: 21 天
    发表于 2014-5-8 17:56:59 | 显示全部楼层 |阅读模式
    下面列出圆点博士小四轴所支持的通讯命令的源代码。
    if((anbt_com_command_HH=='R')&&(anbt_com_command_HL=='C')) anbt_com_command_ops=0xA0;     //remote ctrol
        else if((anbt_com_command_HH=='B')&&(anbt_com_command_HL=='A')&&(anbt_com_command_LH=='T'))   anbt_com_command_ops=0xA1;  //read voltage
        else if((anbt_com_command_HH=='V')&&(anbt_com_command_HL=='E')&&(anbt_com_command_LH=='R'))  anbt_com_command_ops=0xA2;  //return version
        else if((anbt_com_command_HH=='C')&&(anbt_com_command_HL=='T')&&(anbt_com_command_LH=='R')&&(anbt_com_command_LL=='L')) anbt_com_command_ops=0xA3;  //read PI data
        else if((anbt_com_command_HH=='P')&&(anbt_com_command_HL=='A')&&(anbt_com_command_LH=='L')&&(anbt_com_command_LL=='L')) anbt_com_command_ops=0xA4;  //read PI data
        else if((anbt_com_command_HH=='I')&&(anbt_com_command_HL=='A')&&(anbt_com_command_LH=='L')&&(anbt_com_command_LL=='L')) anbt_com_command_ops=0xA5;  //read PI data
        else if((anbt_com_command_HH=='W')&&(anbt_com_command_HL=='R')&&(anbt_com_command_LH=='P')&&(anbt_com_command_LL=='X')) anbt_com_command_ops=0xA6;  //write PX
        else if((anbt_com_command_HH=='W')&&(anbt_com_command_HL=='R')&&(anbt_com_command_LH=='P')&&(anbt_com_command_LL=='Y')) anbt_com_command_ops=0xA7;  //write PY
        else if((anbt_com_command_HH=='W')&&(anbt_com_command_HL=='R')&&(anbt_com_command_LH=='P')&&(anbt_com_command_LL=='Z')) anbt_com_command_ops=0xA8;  //write PZ
        else if((anbt_com_command_HH=='W')&&(anbt_com_command_HL=='R')&&(anbt_com_command_LH=='I')&&(anbt_com_command_LL=='X')) anbt_com_command_ops=0xA9;  //write IX
        else if((anbt_com_command_HH=='W')&&(anbt_com_command_HL=='R')&&(anbt_com_command_LH=='I')&&(anbt_com_command_LL=='Y')) anbt_com_command_ops=0xAA;  //write IY
        else if((anbt_com_command_HH=='W')&&(anbt_com_command_HL=='R')&&(anbt_com_command_LH=='I')&&(anbt_com_command_LL=='Z')) anbt_com_command_ops=0xAB;  //write IZ
        else if((anbt_com_command_HH=='P')&&(anbt_com_command_HL=='W')&&(anbt_com_command_LH=='O')&&(anbt_com_command_LL=='N')) anbt_com_command_ops=0xAC;  //motor pwm on
        else if((anbt_com_command_HH=='P')&&(anbt_com_command_HL=='W')&&(anbt_com_command_LH=='O')&&(anbt_com_command_LL=='F')) anbt_com_command_ops=0xAD;  //motor pwm on
        else anbt_com_command_ops=0;
    命令相应一:返回电池电压值。
    if(anbt_com_command_ops==0xA1)    //圆点博士:返回电池电压,注意,如果电机电源没开,将返回0
      BS004_COM1_Send_Str_Head();
      BS004_COM1_Send_Str_Body("read bat voltage .");
      BS004_COM1_Send_4bits_BCD_Num(bs004_bat_value);
      BS004_COM1_Send_Str_Tail();
    命令相应二:返回版本号。
    else if(anbt_com_command_ops==0xA2) //圆点博士:返回版本号
      BS004_COM1_Send_Str_Body("version 10.");
    命令相应三:返回接收到的最后一次遥控器指令。包括油门数据,俯昂角度,滚动角度,和航向
    else if(anbt_com_command_ops==0xA3) //圆点博士:返回遥控器数据
      BS004_COM1_Send_Str_Body("read remote control data .");
      BS004_COM1_Send_4bits_BCD_Num(BS004_Ctrl_Gas);
      BS004_COM1_Send_Char(',');
      BS004_COM1_Send_4bits_BCD_Num(BS004_Ctrl_Pitch);
      BS004_COM1_Send_4bits_BCD_Num(BS004_Ctrl_Roll);
      BS004_COM1_Send_4bits_BCD_Num(BS004_Ctrl_Yaw);
    命令响应四:返回PID参数中各个轴的P值
    else if(anbt_com_command_ops==0xA4)  //圆点博士:返回P值
      BS004_COM1_Send_Str_Body("read All P data .");
      for(i=0;i<3;i++)
       BS004_COM1_Send_4bits_BCD_Num(pid_setting_P_value);
    命令响应五:返回PID参数中各个轴的I值
    else if(anbt_com_command_ops==0xA5)  //圆点博士:返回I值
      BS004_COM1_Send_Str_Body("read All I data .");
      for(i=0;i<3;i++)
       BS004_COM1_Send_4bits_BCD_Num(pid_setting_I_value);
    命令响应六:设置X轴P值
    else if(anbt_com_command_ops==0xA6)  //圆点博士:设置X轴P值
      BS004_COM1_Send_Str_Body("write PX data .");
      if(pid_data_buffer_valid==1)
       pid_setting_P_value[0]=pid_data_buffer;
       pid_data_buffer_valid=0;
      BS004_COM1_Send_4bits_BCD_Num(pid_data_buffer);
    命令响应七:设置Y轴P值
    else if(anbt_com_command_ops==0xA7) //圆点博士:设置Y轴P值
      BS004_COM1_Send_Str_Body("write PY data .");
       pid_setting_P_value[1]=pid_data_buffer;
    命令响应八:设置Z轴P值
    else if(anbt_com_command_ops==0xA8) //圆点博士:设置Z轴P值
      BS004_COM1_Send_Str_Body("write PZ data .");
       pid_setting_P_value[2]=pid_data_buffer;
    命令相应九:设置X轴I值
      else if(anbt_com_command_ops==0xA9) //圆点博士:设置X轴I值
      BS004_COM1_Send_Str_Body("write IX data .");
       pid_setting_I_value[0]=pid_data_buffer;
    命令相应十:设置Y轴I值
      else if(anbt_com_command_ops==0xAA) //圆点博士:设置Y轴I值
      BS004_COM1_Send_Str_Body("write IY data .");
       pid_setting_I_value[1]=pid_data_buffer;;
    命令相应十一:设置Z轴I值
      else if(anbt_com_command_ops==0xAB) //圆点博士:设置Z轴I值
      BS004_COM1_Send_Str_Body("write IZ data .");
       pid_setting_I_value[2]=pid_data_buffer;
    下面命令用于电机电源的开启或者关闭。
    else if(anbt_com_command_ops==0xAC) //圆点博士:打开电机电源
    BS004_COM1_Send_Str_Body("motor power on.");
    BS004_Motor_Power_On();
    else if(anbt_com_command_ops==0xAD) //圆点博士:关闭电机电源
    BS004_COM1_Send_Str_Body("motor power off.");
    BS004_Motor_Power_Off();
    2014-11-28 09:29
    发表于 2014-8-6 23:15:22 | 显示全部楼层
    收藏研究!
    2015-8-5 08:38
  • 签到天数: 12 天
    发表于 2014-8-8 23:19:07 | 显示全部楼层
    感谢博士,表示支持
    GMT+8, 2024-4-26 15:56 , Processed in 0.144862 second(s), 19 queries , MemCache On.
