打印格式是 %s %d %c %x %d, 调试的时候特别好用。源码放在附件, 直接替换就能使用
#include <stdint.h>
#include "nrf.h"
#include "simple_uart.h"
#include "nrf_delay.h"
#include "nrf_gpio.h"
#define UART_DEBUG 1
uint8_t simple_uart_get(void)
while (NRF_UART0->EVENTS_RXDRDY != 1)
// Wait for RXD data to be received
NRF_UART0->EVENTS_RXDRDY = 0;
return (uint8_t)NRF_UART0->RXD;
bool simple_uart_get_with_timeout(int32_t timeout_ms, uint8_t *rx_data)
bool ret = true;
if (timeout_ms-- >= 0)
// wait in 1ms chunk before checking for status
nrf_delay_us(1000);
else
ret = false;
break;
} // Wait for RXD data to be received
if (timeout_ms >= 0)
// clear the event and set rx_data with received byte
*rx_data = (uint8_t)NRF_UART0->RXD;
return ret;
void simple_uart_put(uint8_t cr)
NRF_UART0->TXD = (uint8_t)cr;
while (NRF_UART0->EVENTS_TXDRDY!=1)
// Wait for TXD data to be sent
NRF_UART0->EVENTS_TXDRDY=0;
void simple_uart_putstring(char *str)
#if UART_DEBUG
uint_fast8_t i = 0;
uint8_t ch = str[i++];
while (ch != '\0')
simple_uart_put(ch);
ch = str[i++];
#endif
void simple_uart_config( uint8_t rts_pin_number,
uint8_t txd_pin_number,
uint8_t cts_pin_number,
uint8_t rxd_pin_number,
bool hwfc)
/** @snippet [Configure UART RX and TX pin] */
nrf_gpio_cfg_output(txd_pin_number);
nrf_gpio_cfg_input(rxd_pin_number, NRF_GPIO_PIN_NOPULL);
NRF_UART0->PSELTXD = txd_pin_number;
NRF_UART0->PSELRXD = rxd_pin_number;
if (hwfc)
nrf_gpio_cfg_output(rts_pin_number);
nrf_gpio_cfg_input(cts_pin_number, NRF_GPIO_PIN_NOPULL);
NRF_UART0->PSELCTS = cts_pin_number;
NRF_UART0->PSELRTS = rts_pin_number;
NRF_UART0->CONFIG = (UART_CONFIG_HWFC_Enabled << UART_CONFIG_HWFC_Pos);
NRF_UART0->BAUDRATE = (UART_BAUDRATE_BAUDRATE_Baud9600 << UART_BAUDRATE_BAUDRATE_Pos);
NRF_UART0->ENABLE = (UART_ENABLE_ENABLE_Enabled << UART_ENABLE_ENABLE_Pos);
NRF_UART0->TASKS_STARTTX = 1;
NRF_UART0->TASKS_STARTRX = 1;
void simple_uart_printHEX(uint32_t value)
#if UART_DEBUG
const uint8_t ASCII[16] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E', 'F'};
if(value <= 0xFF)
simple_uart_put('0');
simple_uart_put('x');
simple_uart_put(ASCII[value>>4]);
simple_uart_put(ASCII[value & 0x0f]);
else if(value <= 0xFFFF)
simple_uart_put(ASCII[(value>>12) & 0xf]);
simple_uart_put(ASCII[(value>>8) & 0xf]);
simple_uart_put(ASCII[(value>>4 ) & 0xf]);
else if(value <= 0xFFFFFF)
simple_uart_put(ASCII[(value>>20) & 0xf]);
simple_uart_put(ASCII[(value>>16) & 0xf]);
simple_uart_put(ASCII[(value>>8 ) & 0xf]);
else if(value <= 0xFFFFFFFF)
simple_uart_put(ASCII[(value>>28) & 0xf]);
simple_uart_put(ASCII[(value>>24) & 0xf]);
simple_uart_put('\r');
simple_uart_put('\n');
#endif
void simple_uart_print(char *str, uint8_t newline)
#if UART_DEBUG
simple_uart_putstring(str);
#endif
// µÝ¹éµ÷Óà just for simple_uart_printf
static void printn(unsigned int n, unsigned int b)
static char *ntab = "0123456789ABCDEF";
unsigned int a, m;
if (n / b)
a = n / b;
printn(a, b);
m = n % b;
simple_uart_put(ntab[m]);
void simple_uart_printf(char *fmt, ...)
#if UART_DEBUG
char c;
unsigned int *adx = (unsigned int*)(void*)&fmt + 1;
_loop:
while((c = *fmt++) != '%')
if (c == '\0') return;
simple_uart_put(c);
c = *fmt++;
if (c == 'd' || c == 'l')
printn(*adx, 10); //print HEX value
if (c == 'o')
printn(*adx, 8);
if(c == 'x')
printn(*adx, 16);
if (c == 's')
simple_uart_putstring((char*)*adx);
if (c == 'c')
simple_uart_put(*adx);
adx++;
goto _loop;
#endif
