查看: 7910|回复: 10
raspberry pi支持的4个开源系统
发表于 2012-10-26 17:36:49 | 显示全部楼层 |阅读模式
Raspbian “wheezy”If you’re just starting out, this is the image we recommend you use. It’s a reference root filesystem from Alex and Dom, based on the Raspbian optimised version of Debian, and containing LXDE, Midori, development tools and example source code for multimedia functions.
Torrent2012-09-18-wheezy-raspbian.zip.torrent
Direct download2012-09-18-wheezy-raspbian.zip
SHA-13bc788d447bc88feaae8382d61364eaba1088e78
Default loginUsername: pi Password: raspberry
Soft-float Debian “wheezy”This image is identical to the Raspbian “wheezy” image, but uses the slower soft-float ABI. It is only intended for use with software such as the Oracle JVM which does not yet support the hard-float ABI used by Raspbian.
Torrent2012-08-08-wheezy-armel.zip.torrent
Direct download2012-08-08-wheezy-armel.zip
SHA-1db28d031d5f925a667c2a478c638222d9b405d5a
Arch Linux ARMArch Linux ARM is based on Arch Linux, which aims for simplicity and full control to the end user. Note that this distribution may not be suitable for beginners. The latest version of this image uses the hard-float ABI, and boots to a command prompt in around ten seconds.
Torrentarchlinux-hf-2012-09-18.zip.torrent
Direct downloadarchlinux-hf-2012-09-18.zip
SHA-156e043f3c629f6c408759bcc157d2d635ce0b6af
Default loginUsername: root Password: root
QtonPiQtonPi is an Embedded Linux platform plus SDK optimized for developing and running Qt 5 Apps on Raspberry Pi. More information is available here.
Torrentqtonpi-0.2.tar.bz2.torrent
Direct downloadqtonpi-0.2.tar.bz2
SHA-1665b6ccf59ccbd4c38827f5554aa823302730a04
Default loginUsername: root Password: rootme
  • 签到天数: 16 天
    发表于 2012-11-10 07:53:32 | 显示全部楼层
    要是翻一下就好了,呵呵,其实英文也能的
    发表于 2012-11-11 19:02:31 | 显示全部楼层
    个人建议还是看英文的,说实话原汁原味才是王道,他人翻译总跟他的计算机水平和英语水平有关系。
    2014-8-3 01:09
  • 签到天数: 34 天
    发表于 2012-11-30 22:09:44 | 显示全部楼层
    怎么感觉这么像直接复制过来的
    2013-1-2 00:30
  • 签到天数: 24 天
    发表于 2012-12-4 19:59:57 | 显示全部楼层
    学习了!学习了!
  • 签到天数: 6 天
    发表于 2012-12-8 14:08:41 | 显示全部楼层
    哪有Fedora呀?
  • 签到天数: 517 天
    发表于 2012-12-9 22:43:21 | 显示全部楼层
    嗯嗯。
  • 签到天数: 517 天
    发表于 2012-12-9 22:44:26 | 显示全部楼层
    嗯嗯。
    发表于 2012-12-10 05:38:02 | 显示全部楼层
    官方系统版本:
    Raspbian “wheezy”
    Arch Linux ARM
    RISC OS
    非官方系统版本非常多,但有个非官方系统版本值得关注:http://www.raspbmc.com/ 。
    发表于 2012-12-10 17:07:03 来自手机 | 显示全部楼层
    学习了。。。。。
    GMT+8, 2024-5-5 22:31 , Processed in 0.193918 second(s), 35 queries , MemCache On.
