ATSAM3S 评估套件
板卡简介:Atmel SAM3S Series 是提供高集成度和低功耗的Cortex-M3闪存 微控制器。了解更多<<
feature:
- 1.62V to 3.6V supply
- Cortex-M3 rev 2.0 processor running at up to 64MHz
- Memory protection unit (MPU)
- Optional dual-bank Flash
- Native 4-layer AHB bus matrix, 21 DMA channels
- Embedded regulator, power-on reset, brown-out detection and multiple clock sources, including 32kHz oscillator and factory-trimmed RC
- High-speed peripherals, including USB2.0 FS device, HS SD/SDIO/MMC, USART, SPI
- Up to 16-channel 12-bit 1Msps ADC with PGA stage and differential inputs, 2-channel 12-bit 1Msps DAC, analog comparator
- Powerful and flexible 16-bit timers with quadrature decoder and gray counter. Powerful PWM unit, calendar RTC, watchdog timer
- Power consumption 2.3mW@1MHz, 1.3mW@500kHz, backup mode down to 1.8µA
- ECC on flash, independent watchdog, dual-bank flash, clock failure detection. On-the-fly external memory scrambling.
- 8-bit parallel data capture on PIO controller
- Up to 79 I/O lines with integrated serial resistors (on-die termination)
- 8-, 64- and 100-pin packages
资源附件下载<<
ATSAM4E-XPRO评估套件
板卡简介:Atmel® SAM4E Xplained Pro 评估套件是评估ATSAM4E16E微控制器的硬件平台,支持Studio集成开发平台,套件提供Atmel ATSAM4E16E的功能说明书,并可以了解到如何在自定义设计中集成器件。了解更多<<
feature:
● Atmel ATSAM4E16E microcontroller
● Embedded debugger (EDBG)
- USB interface
- Programming and debugging (target) through Serial Wire Debug (SWD)
- Virtual COM-port interface to target via UART
- Atmel Data Gateway Interface (DGI) to target via USART or TWI
- Four GPIOs connected to target for code instrumentation
● Digital I/O
- Two mechanical buttons (user, reset and force wakeup button)
- One user LED
- Three extension headers
- Xplained Pro LCD extension connector
● One CAN-bus
● 10/100-T Ethernet
● 2Gb 8-bit NAND Flash
● Dual 512K 8-bit SRAM
● Target USB, device mode
● Three possible power sources
- External power
- Embedded debugger USB
- Target USB
● 12MHz crystal
● 32kHz crystal
资源附件下载<<
ATSAM4E-EK评估套件
板卡简介:Atmel SAM4E-EK 评估板是一个Atmel 微控制器快速发展的评估套件,此开发板主要是提供高性能处理器评估解决方案给各种具有高灵活性的应用。了解更多<<
feature:
• SAM4E16 chip BGA144 package with optional socket footprint
• 12MHz crystal
• 32.768kHz crystal
• Optional SMB connector for external system clock input
• NAND Flash
• 2.8 inch TFT color LCD display with touch panel and backlight
• UART port with RS232 driver
• USART port with RS232 driver multiplexed with RS485 function with driver
• CAN port with driver
• Mono/stereo headphone jack output
• One Ethernet physical transceiver layer with RJ45 connector
• SD/MMC interface
• Reset button: NRST
• User buttons: WAKU, TAMP, Scroll-up, Scroll-down
• QTouch® buttons: Left, Right and Slider
• Full Speed USB device port
• JTAG/ICE port
• On-board power regulation
• Three user LEDs
• Power LED
• BNC connector for ADC input
• BNC connector for DAC output
• User potentiometer connected to the ADC input
• ZigBee® connector
• PIO connection interfaces (PIOA, PIOC and PIOD with 32-bit, PIOB with 16-bit, PIOE with 6-bit)
资源附件下载<<
