查看: 3425|回复: 4
小E天气预报
    发表于 2016-4-24 20:34:36 | 显示全部楼层 |阅读模式
    将小E联网后,从openweathermap网站抓取天气数据显示在屏幕上。由于小e屏幕太小只能显示有限数据,
    否则可以做未来5天的天气预报。
    运行效果如下图所示:
    源代码:
    1. #include <ESP8266WiFi.h> //Include the library ESP8266
    2. #include <Wire.h>
    3. #include "SSD1306.h"
    4. // Initialize the oled display for address 0x3c
    5. //I2C-ADD=0X3C, sda-pin=2 and sdc-pin=14
    6. SSD1306 oled(0x3c, 2, 14);
    7. const char* network = "xxx"; //wifi name
    8. const char* password = "xxxx";//wifi password
    9. String site = "api.openweathermap.org"; //Create a string named site
    10. int cityID = 1790923;
    11. WiFiClient client; //Create the client object
    12. String answer;
    13. int indexa, indexb;
    14. void setup()
    15. {
    16.         Serial.begin(115200);// Starts the serial port with 9600 baud
    17.         oled.init();
    18.         oled.flipScreenVertically();
    19.         oled.setFont(ArialMT_Plain_24);
    20.         oled.setTextAlignment(TEXT_ALIGN_CENTER);
    21.         oled.drawString(64, 20, "boot...");
    22.         oled.display();
    23.         oled.clear();
    24.         Serial.println();
    25.         Serial.print("Conecting to network of ");
    26.         Serial.println(network);
    27.         WiFi.begin(network, password);//Connect to the network
    28.         Serial.println("Waiting connection to the router...");
    29.         while (WiFi.status() != WL_CONNECTED)//Print on the serial “-“ while the module doesn′t connect to the network
    30.         {
    31.                 delay(500);
    32.                 Serial.print("-");
    33.         }
    34.         Serial.print("\nWi-Fi connected. IP: ");
    35.         Serial.println(WiFi.localIP());//Print IP
    36. }
    37. void loop()
    38. {
    39.         Serial.println("\nWaiting connection with the server...");
    40.         while (!client.connect(site.c_str(), 80))//Wait the connection printing |
    41.         {
    42.                 delay(500);
    43.                 Serial.print('|');
    44.         }
    45.         if(client.connected())
    46.         {
    47.                 Serial.println();
    48.                 Serial.println("Sending request HTTP "); // Request from the server information about the weather
    49.                 //api.openweathermap.org/data/2.5/forecast/city?id=524901&APPID=1111111111
    50.                 client.print("GET /data/2.5/weather?");
    51.                 client.print("id=");
    52.                 client.print(cityID);
    53.                 client.print("&APPID=xxxxxxxx ");//APPID from the site OWP
    54.                 client.print("HTTP/1.1\r\n");
    55.                 client.print("Host: " + site + "\r\n\r\n");
    56.                 client.print("Connection: close");
    57.                 Serial.println("Waiting server answer...");
    58.                 while (!client.available())
    59.                 {
    60.                         Serial.print('*');
    61.                         delay(500);
    62.                 }
    63.                 while (client.available())//Read the answer of the API and keep the data on the string answer
    64.                 {
    65.                         char c = client.read();
    66.                         answer += c;
    67.                 }
    68.                 Serial.println(answer);
    69.         }
    70.         if(answer != "")
    71.         {
    72.                 Serial.print("\n\n");
    73.                 String overview = "";
    74.                 indexa = answer.indexOf("name");
    75.                 indexb = answer.indexOf("cod");
    76.                 overview += answer.substring(indexa + 7, indexb - 3);
    77.                 overview += ", ";
    78.                 indexa = answer.indexOf("description");
    79.                 indexb = answer.indexOf("icon");
    80.                 overview += answer.substring(indexa + 14, indexb - 3);
    81.                 Serial.println(overview);
    82.                 String wind = "wind: ";
    83.                 indexa = answer.indexOf("speed");
    84.                 indexb = answer.indexOf("deg");
    85.                 wind += answer.substring(indexa + 7, indexb - 3);
    86.                 wind +="m/s,deg ";
    87.                 indexa = answer.indexOf("deg");
    88.                 indexb = answer.indexOf("rain");
    89.                 wind += answer.substring(indexa + 5, indexb - 3);
    90.                 Serial.println(wind);
    91.                 String temperature = "Temperature: ";
    92.                 indexa = answer.indexOf("temp");//Find on answer an índice that starts with temp
    93.                 String stempk = answer.substring(indexa + 6, indexa + 13);//Receive from answer a String with the temperature value in Kelvin
    94.                 int tempk = stempk.toInt();//Change the stempk to integer
    95.                 int tempc = tempk - 273;//Transform the temperature to Celsius
    96.                 temperature += tempc;
    97.                 temperature += " oC";
    98.                 Serial.println(temperature);
    99.                 String humidity = "humidity: ";
    100.                 indexa = answer.indexOf("humidity");
    101.                 indexb = answer.indexOf("temp_min");
    102.                 humidity += answer.substring(indexa + 10, indexb - 2);
    103.                 humidity += " %";
    104.                 Serial.println(humidity);
    105.                 //Serial.print("rain: ");
    106.                 //indexa = answer.indexOf("rain");
    107.                 //String rain = answer.substring(indexa + 12, indexa + 17);
    108.                 //Serial.println(rain);
    109.                 Serial.print("\n\n\n\n");
    110.                 oled.setFont(ArialMT_Plain_10);
    111.                 oled.setTextAlignment(TEXT_ALIGN_LEFT);
    112.                 oled.drawString(0, 0, overview);
    113.                 oled.drawString(0, 12, wind);
    114.                 oled.drawString(0, 24, temperature);
    115.                 oled.drawString(0, 36, humidity);
    116.                 oled.display();
    117.                 oled.clear();
    118.         }
    119.         delay(60000);
    120.         answer = "";
    121. }
  • 签到天数: 981 天
    发表于 2016-4-25 09:01:58 | 显示全部楼层
    感谢分享!!!!!!!!1
  • 签到天数: 114 天
    发表于 2016-4-25 10:25:35 | 显示全部楼层
    这是小e的代码吗,兼容arduino?
  • 签到天数: 169 天
    发表于 2016-4-25 14:23:31 | 显示全部楼层
    是要跟天气服务器通讯么?
  • 签到天数: 2 天
    发表于 2016-5-9 15:48:00 | 显示全部楼层
    文章不错,请内容去经验频道一并发一下,可以有双重奖励哟http://jingyan.eeboard.com/
    GMT+8, 2024-4-26 16:46 , Processed in 0.154546 second(s), 23 queries , MemCache On.
