查看: 3485|回复: 1
[教程] 【转载】树莓派3(Raspberry pi 3)刷kali+3.5寸微雪屏
  • 签到天数: 2 天
    发表于 2016-7-15 14:06:55 | 显示全部楼层 |阅读模式
    1.点亮微雪3.5寸屏幕
    需要的工具1:https://github.com/swkim01/waveshare-dtoverlays
    1. git clone https://github.com/swkim01/waveshare-dtoverlays.git waveshare-dtoverlays
    2. cd waveshare-dtoverlays
    3. mount /dev/mmcblk0p1 /boot/
    4. cp waveshare-dtoverlays/waveshare35a-overlay.dtb /boot/overlays/
    编辑/boot/config.txt添加
    1. dtoverlay=waveshare35a
    需要的工具2:https://github.com/adafruit/Adafruit-PITFT-Helper
    1. git clone https://github.com/adafruit/Adafruit-PiTFT-Helper.git
    2. cd Adafruit-PiTFT-Helper
    3. mkdir /etc/kbd
    4. touch /etc/kbd/config
    5. ./adafruit-pitft-helper -t 35r -u /root
    全选y
    reboot,屏幕可以用了。
    2.换源
    编辑/etc/apt/sources.list文件
    对于Kali 2.0,使用ipv4网络添加如下内容
    1. deb http://mirrors.ustc.edu.cn/kali sana main non-free contrib
    2. deb-src http://mirrors.ustc.edu.cn/kali sana main non-free contrib
    3. deb http://mirrors.ustc.edu.cn/kali-security sana/updates main contrib non-free
    1. apt-install update
    3.屏幕校准
    1. apt-get install -y xinput-calibrator
    2. DISPLAY=:0.0 xinput_calibrator
    终端输出一组4个数字的数据,修改到/etc/X11/xorg.conf.d/99-calibration.conf
    如果触摸不正常请把此文件改成如下
    1. Section "InputClass"
    2.         Identifier      "calibration"
    3.         MatchProduct    "ADS7846 Touchscreen"
    4.         Option  "Calibration"   "3946 229 164 3881"
    5.         Option  "SwapAxes"      "1"
    6. EndSection
    4.安装raspi-config
    1. wget http://archive.raspberrypi.org/debian/pool/main/r/raspi-config/raspi-config_20160527_all.deb
    2. apt-get install triggerhappy lua5.1  alsa-utils
    3. dpkg -i raspi-config_20160527_all.deb
    来源作者:wangandi
  • 签到天数: 49 天
    发表于 2016-8-7 21:31:01 | 显示全部楼层
    看看
    GMT+8, 2024-4-27 07:31 , Processed in 0.110548 second(s), 16 queries , MemCache On.
