查看: 2424|回复: 0
【LinkNode D1开发板试用】源代码学习求教
  • 签到天数: 851 天
    发表于 2016-9-8 15:13:47 | 显示全部楼层 |阅读模式
         LinkNode D1开发板试用的源代码学习,下面是时钟模块的采集,买了一个DS1307的时钟模块
    #include  "Wire.h"
    #define  DS1307_I2C_ADDRESS  0x68 // This is the I2C address
    int command = 0; // This is the command char, in ascii form, sent from the serial port
    byte zero=0;
    //long previousMillis = 0; // will store last time Temp was updated byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; byte test;
    //Convert normal decimal numbers to binary coded decimal
    byte test;
    byte decToBcd(byte val)
       return ( (val/10*16) + (val%10) );
    byte bcdToDec(byte val)
      return ( (val/16*10) + (val%16) );
    void setDateDs1307(void)
      second = (byte) ((Serial.read() - 48) * 10 + (Serial.read() - 48));
      minute = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
      hour  = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
      dayOfWeek = (byte) (Serial.read() - 48);
      dayOfMonth = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
      month = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
      year= (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
      Wire.beginTransmission(DS1307_I2C_ADDRESS);
      Wire.write(zero);
      Wire.write(decToBcd(second));    // 0 to bit 7 starts the clock
      Wire.write(decToBcd(minute));
      Wire.write(decToBcd(hour));      // If you want 12 hour am/pm you need to set
                                      // bit 6 (also need to change readDateDs1307)
      Wire.write(decToBcd(dayOfWeek));
      Wire.write(decToBcd(dayOfMonth));
      Wire.write(decToBcd(month));
      Wire.write(decToBcd(year));
      Wire.endTransmission();
    //Gets the date and time from the ds1307 and prints result
    void getDateDs1307()
    // Reset the register pointer
    Wire.write(zero);
    Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
       second     = bcdToDec(Wire.read() & 0x7f);
    minute     = bcdToDec(Wire.read());
    hour       = bcdToDec(Wire.read() & 0x3f);
    dayOfWeek  = bcdToDec(Wire.read());
    dayOfMonth = bcdToDec(Wire.read());
    month      = bcdToDec(Wire.read());
    year       = bcdToDec(Wire.read());
    Serial.print(hour, DEC);
    Serial.print(":");
    Serial.print(minute, DEC);
    Serial.print(":");
    Serial.print(second, DEC);
    Serial.print("  ");
    Serial.print(month, DEC);
    Serial.print("/");
    Serial.print(dayOfMonth, DEC);
    Serial.print("/");
    Serial.print(year, DEC);
    Serial.println("  ");
    void setup()
      Wire.begin();
      Serial.begin(9600);
    void loop()
      delay(2000);
      /*T(00-59)(00-59)(00-23)(1-7)(01-31)(01-12)(00-99) - T(sec)(min)(hour)(dayOfWeek)(dayOfMonth)(month)(year) - T Sets the date of the RTC DS1307 Chip.
      Example to set the time for 02-DEC-10 @ 19:57:11 for the 3 day of the week, send this command - T1157193021210
        if (Serial.available())
        {      // Look for char in serial que and process if found
          command = Serial.read();
          if (command == 84)
          {      //If command = "T" Set Date
            setDateDs1307();
            getDateDs1307();
          while(1)
            getDateDs1307();
            delay(1000);
       串口发送:"T3555144080916" 设置时间,然后每秒更新时间并在串口显示出来。有个问题,就是返回的时间经常有乱码,不知道是硬件问题还是代码的BUG?
         还有一个测试代码,编译不通过,就是采集温度湿度大气压力的数据并上传到linksprite平台。
      下面是错误信息:
    Arduino:1.6.7 (Windows 7), 开发板:"WeMos D1(Retired), 80 MHz, Serial, 921600, 4M (3M SPIFFS)"
    d:\Program Files (x86)\Arduino1.67\arduino-builder -dump-prefs -logger=machine -hardware "d:\Program Files (x86)\Arduino1.67\hardware" -hardware "C:\Users\Administrator\AppData\Local\Arduino15\packages" -tools "d:\Program Files (x86)\Arduino1.67\tools-builder" -tools "d:\Program Files (x86)\Arduino1.67\hardware\tools\avr" -tools "C:\Users\Administrator\AppData\Local\Arduino15\packages" -built-in-libraries "d:\Program Files (x86)\Arduino1.67\libraries" -libraries "C:\Users\Administrator\Documents\Arduino\libraries" -fqbn=esp8266:esp8266:d1:CpuFrequency=80,UploadTool=esptool,UploadSpeed=921600,FlashSize=4M3M -ide-version=10607 -build-path "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Administrator\Documents\Arduino\LinkNodeD1\WeatherStation\WeatherStation.ino"
    d:\Program Files (x86)\Arduino1.67\arduino-builder -compile -logger=machine -hardware "d:\Program Files (x86)\Arduino1.67\hardware" -hardware "C:\Users\Administrator\AppData\Local\Arduino15\packages" -tools "d:\Program Files (x86)\Arduino1.67\tools-builder" -tools "d:\Program Files (x86)\Arduino1.67\hardware\tools\avr" -tools "C:\Users\Administrator\AppData\Local\Arduino15\packages" -built-in-libraries "d:\Program Files (x86)\Arduino1.67\libraries" -libraries "C:\Users\Administrator\Documents\Arduino\libraries" -fqbn=esp8266:esp8266:d1:CpuFrequency=80,UploadTool=esptool,UploadSpeed=921600,FlashSize=4M3M -ide-version=10607 -build-path "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Administrator\Documents\Arduino\LinkNodeD1\WeatherStation\WeatherStation.ino"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\ESP8266WiFiAP.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\ESP8266WiFiSTA.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\WiFiClient.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\WiFiClientSecure.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\WiFiServer.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\WiFiUdp.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src\DNSServer.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src\ESP8266WebServer.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src\Parsing.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Administrator\Documents\Arduino\libraries\WiFiManager\WiFiManager.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "C:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library\DHT.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial\SoftwareSerial.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire\Wire.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "C:\Users\Administrator\Documents\Arduino\libraries\I2Cdev\I2Cdev.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "C:\Users\Administrator\Documents\Arduino\libraries\BMP085\BMP085.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "nul"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
    "d:\Program Files (x86)\Arduino1.67\tools-builder\ctags\5.8-arduino5/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
    "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L   -DARDUINO=10607 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266  -DESP8266 "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\d1" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire" "-IC:\Users\Administrator\Documents\Arduino\libraries\BMP085" "-IC:\Users\Administrator\Documents\Arduino\libraries\I2Cdev" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer\src" "-IC:\Users\Administrator\Documents\Arduino\libraries\WiFiManager" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial" "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp" -o "C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp.o"
    In file included from C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266/Arduino.h:34:0,
                     from C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\WeatherStation.ino.cpp:1:
    C:\Users\ADMINI~1\AppData\Local\Temp\build1b34506f147135b78d07f8f540ec5dbe.tmp\sketch\Read_DHT22.h: In function 'void read_dht22_data()':
    Read_DHT22.h:41: error: expected unqualified-id before '(' token
        if ( std::isnan(now_h) || std::isnan(now_t))
    使用 1.0  版本的库 ESP8266WiFi 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi
    使用 1.1.0  版本的库 DNSServer 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\DNSServer
    使用 1.0  版本的库 ESP8266WebServer 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WebServer
    使用 0.12  版本的库 WiFiManager 在文件夹: C:\Users\Administrator\Documents\Arduino\libraries\WiFiManager
    使用 1.2.3  版本的库 DHT_sensor_library 在文件夹: C:\Users\Administrator\Documents\Arduino\libraries\DHT_sensor_library
    使用 1.0  版本的库 SoftwareSerial 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\SoftwareSerial
    使用 1.0  版本的库 Wire 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\Wire
    使用库 I2Cdev 在文件夹: C:\Users\Administrator\Documents\Arduino\libraries\I2Cdev (legacy)
    使用库 BMP085 在文件夹: C:\Users\Administrator\Documents\Arduino\libraries\BMP085 (legacy)
    exit status 1
         有哪位老师能给小弟指点下吗?
    GMT+8, 2024-4-26 21:52 , Processed in 0.127444 second(s), 15 queries , MemCache On.
