查看: 3185|回复: 1
[原创] 【电鱼派试用】+烧写桌面系统遇到问题
  • 签到天数: 290 天
    发表于 2017-1-26 01:02:51 | 显示全部楼层 |阅读模式
    现在打算给板子烧写桌面系统,文件系统采用的是bone-debian-7.5-2014-05-14-2gb.img.xz解压出来的文件,boot文件还是采用电鱼开发板自带的文件,经过编译之后,上电,打印如下:
    1. U-Boot SPL 2013.01.01 (Oct 17 2016 - 03:18:54)
    2. musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk
    3. split, HB-ISO Rx, HB-ISO Tx, SoftConn)
    4. musb-hdrc: MHDRC RTL version 2.0
    5. musb-hdrc: setup fifo_mode 4
    6. musb-hdrc: 28/31 max ep, 16384/16384 memory
    7. USB Peripheral mode controller at 47401000 using PIO, IRQ 0
    8. musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk
    9. split, HB-ISO Rx, HB-ISO Tx, SoftConn)
    10. musb-hdrc: MHDRC RTL version 2.0
    11. musb-hdrc: setup fifo_mode 4
    12. musb-hdrc: 28/31 max ep, 16384/16384 memory
    13. USB Host mode controller at 47401800 using PIO, IRQ 0
    14. OMAP SD/MMC: 0
    15. reading u-boot.img
    16. reading u-boot.img
    17. U-Boot 2013.01.01 (Oct 17 2016 - 03:18:54)
    18. I2C:   ready
    19. DRAM:  128 MiB
    20. WARNING: Caches not enabled
    21. NAND:  No NAND device found!!!
    22. 0 MiB
    23. MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    24. *** Warning - readenv() failed, using default environment
    25. musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk
    26. split, HB-ISO Rx, HB-ISO Tx, SoftConn)
    27. musb-hdrc: MHDRC RTL version 2.0
    28. musb-hdrc: setup fifo_mode 4
    29. musb-hdrc: 28/31 max ep, 16384/16384 memory
    30. USB Peripheral mode controller at 47401000 using PIO, IRQ 0
    31. musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk
    32. split, HB-ISO Rx, HB-ISO Tx, SoftConn)
    33. musb-hdrc: MHDRC RTL version 2.0
    34. musb-hdrc: setup fifo_mode 4
    35. musb-hdrc: 28/31 max ep, 16384/16384 memory
    36. USB Host mode controller at 47401800 using PIO, IRQ 0
    37. Net:   <ethaddr> not set. Validating first E-fuse MAC
    38. cpsw, usb_ether
    39. Hit any key to stop autoboot:  0
    40. ----------------------Select ROM Type-----------------------
    41. 0 -- Exit To Commond Line
    42. 1 -- MT29F1G08(128M Bytes NandFlah)
    43. 2 -- MT29F2G08(256M Bytes NandFlah)
    44. 3 --  K9K8G08 ( 1G  Bytes NandFlah)
    45. ------------------------------------------------------
    46. :
    47. Please Select ROM type
    48. :b
    49. Please Select ROM type
    50. :o
    51. Please Select ROM type
    52. :o
    53. Please Select ROM type
    54. :b
    55. Please Select ROM type
    56. :b
    57. Please Select ROM type
    58. :0
    59. U-Boot# setenv bootargs "console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw
    60. rootfstype=ext4 rootwait ip=none"
    61. U-Boot# saveenv
    62. Saving Environment to NAND...
    63. Erasing Nand...
    64. Attempt to erase non block-aligned data
    65. U-Boot# boot
    66. mmc0 is current device
    67. SD/MMC found on device 0
    68. reading uEnv.txt
    69. ** Unable to read file uEnv.txt **
    70. reading uImage
    71. 3794656 bytes read in 391 ms (9.3 MiB/s)
    72. Booting from mmc ...
    73. ## Booting kernel from Legacy Image at 80007fc0 ...
    74.    Image Name:   Linux-3.2.0
    75.    Image Type:   ARM Linux Kernel Image (uncompressed)
    76.    Data Size:    3794592 Bytes = 3.6 MiB
    77.    Load Address: 80008000
    78.    Entry Point:  80008000
    79.    Verifying Checksum ... OK
    80.    XIP Kernel Image ... OK
    81. OK
    82. Starting kernel ...
    83. Uncompressing Linux... done, booting the kernel.
    84. [    0.000000] Linux version 3.2.0 (root@ubuntu) (gcc version 4.6.1
    85. (Sourcery CodeBench Lite 2011.09-70) ) #60 Sat Jan 21 00:40:51 CST 2017
    86. [    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7),
    87. cr=10c53c7d
    88. [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing
    89. instruction cache
    90. [    0.000000] Machine: am335xevm
    91. [    0.000000] Memory policy: ECC disabled, Data cache writeback
    92. [    0.000000] AM335X ES1.0 (neon )
    93. [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.
    94. Total pages: 32512
    95. [    0.000000] Kernel command line: console=ttyO0,115200n8
    96. root=/dev/mmcblk0p2 ro rootfstype=ext3 rootwait ip=none
    97. [    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
    98. [    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536
    99. bytes)
    100. [    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768
    101. bytes)
    102. [    0.000000] Memory: 128MB = 128MB total
    103. [    0.000000] Memory: 122344k/122344k available, 8728k reserved, 0K
    104. highmem
    105. [    0.000000] Virtual kernel memory layout:
    106. [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    107. [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    108. [    0.000000]     vmalloc : 0xc8800000 - 0xff000000   ( 872 MB)
    109. [    0.000000]     lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
    110. [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
    111. [    0.000000]       .text : 0xc0008000 - 0xc0690000   (6688 kB)
    112. [    0.000000]       .init : 0xc0690000 - 0xc06cc000   ( 240 kB)
    113. [    0.000000]       .data : 0xc06cc000 - 0xc0733748   ( 414 kB)
    114. [    0.000000]        .bss : 0xc073376c - 0xc0762900   ( 189 kB)
    115. [    0.000000] NR_IRQS:396
    116. [    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128
    117. interrupts
    118. [    0.000000] Total of 128 interrupts on 1 active controller
    119. [    0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
    120. [    0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
    121. [    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps
    122. every 131071999ms
    123. [    0.000000] Console: colour dummy device 80x30
    124. [    0.000091] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
    125. [    0.058563] pid_max: default: 32768 minimum: 301
    126. [    0.058685] Security Framework initialized
    127. [    0.058776] Mount-cache hash table entries: 512
    128. [    0.059143] CPU: Testing write buffer coherency: ok
    129. [    0.079498] omap_hwmod: gfx: failed to hardreset
    130. [    0.095764] omap_hwmod: pruss: failed to hardreset
    131. [    0.096832] print_constraints: dummy:
    132. [    0.097167] NET: Registered protocol family 16
    133. [    0.099304] OMAP GPIO hardware version 0.1
    134. [    0.101867] omap_mux_init: Add partition: #1: core, flags: 0
    135. [    0.103637]  omap_i2c.1: alias fck already exists
    136. [    0.104980]  da8xx_lcdc.0: alias fck already exists
    137. [    0.106262]  omap_i2c.2: alias fck already exists
    138. [    0.106567]  omap_hsmmc.0: alias fck already exists
    139. [    0.106842]  d_can.1: alias fck already exists
    140. [    0.107299]  omap_i2c.2: alias fck already exists
    141. [    0.107330] ------------[ cut here ]------------
    142. [    0.107360] WARNING: at fs/sysfs/dir.c:481 sysfs_add_one+0xa0/0xb0()
    143. [    0.107391] sysfs: cannot create duplicate filename
    144. '/devices/platform/omap/omap_i2c.2'
    145. [    0.107391] Modules linked in:
    146. [    0.107391] Backtrace:
    147. [    0.107421] [<c0018d28>] (dump_backtrace+0x0/0x110) from
    148. [<c04f74e0>] (dump_stack+0x18/0x1c)
    149. [    0.107452]  r6:000001e1 r5:c01119c8 r4:c701dcc8 r3:c06ef308
    150. [    0.107482] [<c04f74c8>] (dump_stack+0x0/0x1c) from [<c0043478>]
    151. (warn_slowpath_common+0x5c/0x6c)
    152. [    0.107513] [<c004341c>] (warn_slowpath_common+0x0/0x6c) from
    153. [<c004352c>] (warn_slowpath_fmt+0x38/0x40)
    154. [    0.107513]  r8:c7070770 r7:c702e000 r6:c7070770 r5:c702e000
    155. r4:ffffffef
    156. [    0.107543] r3:00000009
    157. [    0.107543] [<c00434f4>] (warn_slowpath_fmt+0x0/0x40) from
    158. [<c01119c8>] (sysfs_add_one+0xa0/0xb0)
    159. [    0.107574]  r3:c702e000 r2:c0600488
    160. [    0.107574] [<c0111928>] (sysfs_add_one+0x0/0xb0) from [<c0111a40>]
    161. (create_dir+0x68/0xbc)
    162. [    0.107574]  r7:00000000 r6:c7013a40 r5:00000001 r4:c7071e10
    163. [    0.107604] [<c01119d8>] (create_dir+0x0/0xbc) from [<c0111b58>]
    164. (sysfs_create_dir+0x90/0xe0)
    165. [    0.107635]  r8:00000000 r7:c06eeb00 r6:c7013a40 r5:00000000
    166. r4:c7071e10
    167. [    0.107666] [<c0111ac8>] (sysfs_create_dir+0x0/0xe0) from
    168. [<c022ce34>] (kobject_add_internal+0xa4/0x23c)
    169. [    0.107666]  r6:c06eeb08 r5:00000000 r4:c7071e10
    170. [    0.107696] [<c022cd90>] (kobject_add_internal+0x0/0x23c) from
    171. [<c022d304>] (kobject_add+0x54/0x94)
    172. [    0.107696]  r8:00000000 r7:c06eeb00 r6:00000000 r5:c06eeb08
    173. r4:c7071e10
    174. [    0.107727] [<c022d2b0>] (kobject_add+0x0/0x94) from [<c0295a18>]
    175. (device_add+0xa8/0x664)
    176. [    0.107757]  r3:00000000 r2:00000000
    177. [    0.107757]  r6:c7071e10 r5:c7071f28 r4:c7071e08
    178. [    0.107788] [<c0295970>] (device_add+0x0/0x664) from [<c029a58c>]
    179. (platform_device_add+0x120/0x280)
    180. [    0.107818] [<c029a46c>] (platform_device_add+0x0/0x280) from
    181. [<c003aae0>] (omap_device_register+0x3c/0x5c)
    182. [    0.107818]  r8:c07362e0 r7:c0500eb0 r6:00000000 r5:c706d2c0
    183. r4:c7071e00
    184. [    0.107849] r3:c06eeb00
    185. [    0.107879] [<c003aaa4>] (omap_device_register+0x0/0x5c) from
    186. [<c003ac08>] (omap_device_build_ss+0x108/0x14c)
    187. [    0.107879]  r4:c7071e00 r3:00000000
    188. [    0.107910] [<c003ab00>] (omap_device_build_ss+0x0/0x14c) from
    189. [<c003aca0>] (omap_device_build+0x54/0x5c)
    190. [    0.107940] [<c003ac4c>] (omap_device_build+0x0/0x5c) from
    191. [<c06a03f4>] (omap_i2c_add_bus+0x100/0x13c)
    192. [    0.107940] [<c06a02f4>] (omap_i2c_add_bus+0x0/0x13c) from
    193. [<c06a0574>] (omap_register_i2c_bus+0x7c/0x80)
    194. [    0.107971]  r7:c06c4a34 r6:00000000 r5:00000064 r4:00000002
    195. [    0.108001] [<c06a04f8>] (omap_register_i2c_bus+0x0/0x80) from
    196. [<c00372a0>] (i2c2_init+0x2c/0x34)
    197. [    0.108001]  r5:c06edab0 r4:000000b4
    198. [    0.108032] [<c0037274>] (i2c2_init+0x0/0x34) from [<c04f7808>]
    199. (_configure_device.constprop.8+0x40/0x58)
    200. [    0.108032] [<c04f77c8>] (_configure_device.constprop.8+0x0/0x58)
    201. from [<c069e9d0>] (dianyu335x_init+0x110/0x308)
    202. [    0.108062]  r6:c06ecf10 r5:c06c4964 r4:00000000 r3:c00b1410
    203. [    0.108093] [<c069e8c0>] (dianyu335x_init+0x0/0x308) from
    204. [<c06934bc>] (customize_machine+0x28/0x30)
    205. [    0.108093]  r7:00000000 r6:c0046a14 r5:c701c000 r4:c0733780
    206. [    0.108123] [<c0693494>] (customize_machine+0x0/0x30) from
    207. [<c00086d0>] (do_one_initcall+0x3c/0x178)
    208. [    0.108154] [<c0008694>] (do_one_initcall+0x0/0x178) from
    209. [<c0690880>] (kernel_init+0x9c/0x124)
    210. [    0.108184] [<c06907e4>] (kernel_init+0x0/0x124) from [<c0046a14>]
    211. (do_exit+0x0/0x690)
    212. [    0.108184]  r5:c06907e4 r4:00000000
    213. [    0.108245] ---[ end trace 1b75b31a2719ed1c ]---
    214. [    0.108245] kobject_add_internal failed for omap_i2c.2 with -EEXIST,
    215. don't try to register things with the same name in the same directory.
    216. [    0.108276] Backtrace:
    217. [    0.108276] [<c0018d28>] (dump_backtrace+0x0/0x110) from
    218. [<c04f74e0>] (dump_stack+0x18/0x1c)
    219. [    0.108306]  r6:c06eeb08 r5:ffffffef r4:c7071e10 r3:c06ef308
    220. [    0.108306] [<c04f74c8>] (dump_stack+0x0/0x1c) from [<c022cfc0>]
    221. (kobject_add_internal+0x230/0x23c)
    222. [    0.108337] [<c022cd90>] (kobject_add_internal+0x0/0x23c) from
    223. [<c022d304>] (kobject_add+0x54/0x94)
    224. [    0.108367]  r8:00000000 r7:c06eeb00 r6:00000000 r5:c06eeb08
    225. r4:c7071e10
    226. [    0.108398] [<c022d2b0>] (kobject_add+0x0/0x94) from [<c0295a18>]
    227. (device_add+0xa8/0x664)
    228. [    0.108398]  r3:00000000 r2:00000000
    229. [    0.108398]  r6:c7071e10 r5:c7071f28 r4:c7071e08
    230. [    0.108428] [<c0295970>] (device_add+0x0/0x664) from [<c029a58c>]
    231. (platform_device_add+0x120/0x280)
    232. [    0.108459] [<c029a46c>] (platform_device_add+0x0/0x280) from
    233. [<c003aae0>] (omap_device_register+0x3c/0x5c)
    234. [    0.108459]  r8:c07362e0 r7:c0500eb0 r6:00000000 r5:c706d2c0
    235. r4:c7071e00
    236. [    0.108489] r3:c06eeb00
    237. [    0.108489] [<c003aaa4>] (omap_device_register+0x0/0x5c) from
    238. [<c003ac08>] (omap_device_build_ss+0x108/0x14c)
    239. [    0.108520]  r4:c7071e00 r3:00000000
    240. [    0.108520] [<c003ab00>] (omap_device_build_ss+0x0/0x14c) from
    241. [<c003aca0>] (omap_device_build+0x54/0x5c)
    242. [    0.108551] [<c003ac4c>] (omap_device_build+0x0/0x5c) from
    243. [<c06a03f4>] (omap_i2c_add_bus+0x100/0x13c)
    244. [    0.108581] [<c06a02f4>] (omap_i2c_add_bus+0x0/0x13c) from
    245. [<c06a0574>] (omap_register_i2c_bus+0x7c/0x80)
    246. [    0.108612]  r7:c06c4a34 r6:00000000 r5:00000064 r4:00000002
    247. [    0.108642] [<c06a04f8>] (omap_register_i2c_bus+0x0/0x80) from
    248. [<c00372a0>] (i2c2_init+0x2c/0x34)
    249. [    0.108673]  r5:c06edab0 r4:000000b4
    250. [    0.108673] [<c0037274>] (i2c2_init+0x0/0x34) from [<c04f7808>]
    251. (_configure_device.constprop.8+0x40/0x58)
    252. [    0.108703] [<c04f77c8>] (_configure_device.constprop.8+0x0/0x58)
    253. from [<c069e9d0>] (dianyu335x_init+0x110/0x308)
    254. [    0.108703]  r6:c06ecf10 r5:c06c4964 r4:00000000 r3:c00b1410
    255. [    0.108734] [<c069e8c0>] (dianyu335x_init+0x0/0x308) from
    256. [<c06934bc>] (customize_machine+0x28/0x30)
    257. [    0.108764]  r7:00000000 r6:c0046a14 r5:c701c000 r4:c0733780
    258. [    0.108764] [<c0693494>] (customize_machine+0x0/0x30) from
    259. [<c00086d0>] (do_one_initcall+0x3c/0x178)
    260. [    0.108795] [<c0008694>] (do_one_initcall+0x0/0x178) from
    261. [<c0690880>] (kernel_init+0x9c/0x124)
    262. [    0.108825] [<c06907e4>] (kernel_init+0x0/0x124) from [<c0046a14>]
    263. (do_exit+0x0/0x690)
    264. [    0.108825]  r5:c06907e4 r4:00000000
    265. [    0.108856] omap_device: omap_i2c: build failed (-17)
    266. [    0.108856] ------------[ cut here ]------------
    267. [    0.108886] WARNING: at arch/arm/plat-omap/i2c.c:188
    268. omap_i2c_add_bus+0x130/0x13c()
    269. [    0.108886] Could not build omap_device for omap_i2c
    270. [    0.108886] Modules linked in:
    271. [    0.108886] Backtrace:
    272. [    0.108917] [<c0018d28>] (dump_backtrace+0x0/0x110) from
    273. [<c04f74e0>] (dump_stack+0x18/0x1c)
    274. [    0.108917]  r6:000000bc r5:c06a0424 r4:c701deb0 r3:c06ef308
    275. [    0.108947] [<c04f74c8>] (dump_stack+0x0/0x1c) from [<c0043478>]
    276. (warn_slowpath_common+0x5c/0x6c)
    277. [    0.108978] [<c004341c>] (warn_slowpath_common+0x0/0x6c) from
    278. [<c004352c>] (warn_slowpath_fmt+0x38/0x40)
    279. [    0.108978]  r8:00000000 r7:00000014 r6:c003bf70 r5:ffffffef
    280. r4:00000000
    281. [    0.109008] r3:00000009
    282. [    0.109008] [<c00434f4>] (warn_slowpath_fmt+0x0/0x40) from
    283. [<c06a0424>] (omap_i2c_add_bus+0x130/0x13c)
    284. [    0.109039]  r3:c0500eb0 r2:c05eaf88
    285. [    0.109039] [<c06a02f4>] (omap_i2c_add_bus+0x0/0x13c) from
    286. [<c06a0574>] (omap_register_i2c_bus+0x7c/0x80)
    287. [    0.109069]  r7:c06c4a34 r6:00000000 r5:00000064 r4:00000002
    288. [    0.109069] [<c06a04f8>] (omap_register_i2c_bus+0x0/0x80) from
    289. [<c00372a0>] (i2c2_init+0x2c/0x34)
    290. [    0.109100]  r5:c06edab0 r4:000000b4
    291. [    0.109100] [<c0037274>] (i2c2_init+0x0/0x34) from [<c04f7808>]
    292. (_configure_device.constprop.8+0x40/0x58)
    293. [    0.109130] [<c04f77c8>] (_configure_device.constprop.8+0x0/0x58)
    294. from [<c069e9d0>] (dianyu335x_init+0x110/0x308)
    295. [    0.109161]  r6:c06ecf10 r5:c06c4964 r4:00000000 r3:c00b1410
    296. [    0.109161] [<c069e8c0>] (dianyu335x_init+0x0/0x308) from
    297. [<c06934bc>] (customize_machine+0x28/0x30)
    298. [    0.109191]  r7:00000000 r6:c0046a14 r5:c701c000 r4:c0733780
    299. [    0.109222] [<c0693494>] (customize_machine+0x0/0x30) from
    300. [<c00086d0>] (do_one_initcall+0x3c/0x178)
    301. [    0.109222] [<c0008694>] (do_one_initcall+0x0/0x178) from
    302. [<c0690880>] (kernel_init+0x9c/0x124)
    303. [    0.109252] [<c06907e4>] (kernel_init+0x0/0x124) from [<c0046a14>]
    304. (do_exit+0x0/0x690)
    305. [    0.109252]  r5:c06907e4 r4:00000000
    306. [    0.109283] ---[ end trace 1b75b31a2719ed1d ]---
    307. [    0.109283] failed to get adapter i2c1
    308. [    0.109283] The board is Sail335.
    309. [    0.109924] _regulator_get: l3_main.0 supply vdd_core not found,
    310. using dummy regulator
    311. [    0.110015] am335x_opp_update: physical regulator not present for
    312. core(-22)
    313. [    0.110412]  omap2_mcspi.1: alias fck already exists
    314. [    0.110626]  omap2_mcspi.2: alias fck already exists
    315. [    0.111602]  edma.0: alias fck already exists
    316. [    0.111602]  edma.0: alias fck already exists
    317. [    0.111633]  edma.0: alias fck already exists
    318. [    0.137786] bio: create slab <bio-0> at 0
    319. [    0.139923] SCSI subsystem initialized
    320. [    0.141876] usbcore: registered new interface driver usbfs
    321. [    0.142181] usbcore: registered new interface driver hub
    322. [    0.142364] usbcore: registered new device driver usb
    323. [    0.142669] registerd cppi-dma Intr @ IRQ 17
    324. [    0.142669] Cppi41 Init Done Qmgr-base(c887a000) dma-base(c8878000)
    325. [    0.142700] Cppi41 Init Done
    326. [    0.142700] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13,
    327. plat_mode=0x3
    328. [    0.143005] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13,
    329. plat_mode=0x1
    330. [    0.144195] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
    331. [    0.158630] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
    332. [    0.159393] pps_core: LinuxPPS API ver. 1 registered
    333. [    0.159393] pps_core: Software ver. 5.3.6 - Copyright 2005-2007
    334. Rodolfo Giometti <giometti@linux.it>
    335. [    0.159515] PTP clock support registered
    336. [    0.160400] Advanced Linux Sound Architecture Driver Version 1.0.24.
    337. [    0.161682] cfg80211: Calling CRDA to update world regulatory domain
    338. [    0.162750] Switching to clocksource gp timer
    339. [    0.178192] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    340. [    0.178405] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
    341. [    0.178710] MUSB0 controller's USBSS revision = 4ea20800
    342. [    0.179687] musb-hdrc musb-hdrc.0: USB OTG mode controller at
    343. c883c000 using DMA, IRQ 18
    344. [    0.179840] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
    345. [    0.180145] MUSB1 controller's USBSS revision = 4ea20800
    346. [    0.180541] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
    347. [    0.180633] musb-hdrc musb-hdrc.1: new USB bus registered, assigned
    348. bus number 1
    349. [    0.180755] usb usb1: New USB device found, idVendor=1d6b,
    350. idProduct=0002
    351. [    0.180786] usb usb1: New USB device strings: Mfr=3, Product=2,
    352. SerialNumber=1
    353. [    0.180786] usb usb1: Product: MUSB HDRC host driver
    354. [    0.180786] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
    355. [    0.180816] usb usb1: SerialNumber: musb-hdrc.1
    356. [    0.181579] hub 1-0:1.0: USB hub found
    357. [    0.181610] hub 1-0:1.0: 1 port detected
    358. [    0.182128] musb-hdrc musb-hdrc.1: USB Host mode controller at
    359. c883e800 using DMA, IRQ 19
    360. [    0.182556] NET: Registered protocol family 2
    361. [    0.182739] IP route cache hash table entries: 1024 (order: 0, 4096
    362. bytes)
    363. [    0.183074] TCP established hash table entries: 4096 (order: 3,
    364. 32768 bytes)
    365. [    0.183166] TCP bind hash table entries: 4096 (order: 2, 16384
    366. bytes)
    367. [    0.183227] TCP: Hash tables configured (established 4096 bind 4096)
    368. [    0.183227] TCP reno registered
    369. [    0.183227] UDP hash table entries: 256 (order: 0, 4096 bytes)
    370. [    0.183258] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    371. [    0.183441] NET: Registered protocol family 1
    372. [    0.183715] RPC: Registered named UNIX socket transport module.
    373. [    0.183715] RPC: Registered udp transport module.
    374. [    0.183715] RPC: Registered tcp transport module.
    375. [    0.183746] RPC: Registered tcp NFSv4.1 backchannel transport
    376. module.
    377. [    0.183959] NetWinder Floating Point Emulator V0.97 (double
    378. precision)
    379. [    0.184173] omap-gpmc omap-gpmc: GPMC revision 6.0
    380. [    0.184204] Registering NAND on CS0
    381. [    0.190917] VFS: Disk quotas dquot_6.5.2
    382. [    0.190979] Dquot-cache hash table entries: 1024 (order 0, 4096
    383. bytes)
    384. [    0.191772] msgmni has been set to 238
    385. [    0.195098] alg: No test for stdrng (krng)
    386. [    0.195739] io scheduler noop registered
    387. [    0.195770] io scheduler deadline registered
    388. [    0.195831] io scheduler cfq registered (default)
    389. [    0.197174] da8xx_lcdc da8xx_lcdc.0: GLCD: Found
    390. TFC_S9700RTWV35TR_01B panel
    391. [    0.207763] Console: switching to colour frame buffer device 100x30
    392. [    0.214416] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a
    393. OMAP UART0
    394. [    1.631134] console [ttyO0] enabled
    395. [    1.635559] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a
    396. OMAP UART1
    397. [    1.643371] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a
    398. OMAP UART2
    399. [    1.651184] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a
    400. OMAP UART3
    401. [    1.658996] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a
    402. OMAP UART4
    403. [    1.666748] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a
    404. OMAP UART5
    405. [    1.675048] omap4_rng omap4_rng: OMAP4 Random Number Generator ver.
    406. 2.00
    407. [    1.691345] brd: module loaded
    408. [    1.699493] loop: module loaded
    409. [    1.702941] i2c-core: driver [tsl2550] using legacy suspend method
    410. [    1.709442] i2c-core: driver [tsl2550] using legacy resume method
    411. [    1.718292] mtdoops: mtd device (mtddev=name/number) must be
    412. supplied
    413. [    1.725585] omap2-nand driver initializing
    414. [    1.730255] No NAND device found
    415. [    1.733886] No NAND device found
    416. [    1.737579] OneNAND driver initializing
    417. [    1.743988] CAN device driver interface
    418. [    1.747985] CAN bus driver for Bosch D_CAN controller 1.0
    419. [    1.754425] d_can d_can.1: device registered (irq=55, irq_obj=56)
    420. [    1.803955] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
    421. [    1.810424] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
    422. [    1.817626] davinci_mdio.0: probed
    423. [    1.821166] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver
    424. unknown
    425. [    1.828979] usbcore: registered new interface driver cdc_ether
    426. [    1.835235] usbcore: registered new interface driver cdc_eem
    427. [    1.841308] usbcore: registered new interface driver dm9601
    428. [    1.847167] cdc_ncm: 04-Aug-2011
    429. [    1.850677] usbcore: registered new interface driver cdc_ncm
    430. [    1.856597] Initializing USB Mass Storage driver...
    431. [    1.861846] usb 1-1: new high-speed USB device number 2 using musb-
    432. hdrc
    433. [    1.868988] usbcore: registered new interface driver usb-storage
    434. [    1.875274] USB Mass Storage support registered.
    435. [    1.880615] mousedev: PS/2 mouse device common for all mice
    436. [    1.887451] input: ti-tsc as
    437. /devices/platform/omap/ti_tscadc/tsc/input/input0
    438. [    1.896026] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as
    439. rtc0
    440. [    1.903045] am33xx-rtc: already running
    441. [    1.907257] i2c /dev entries driver
    442. [    1.911499] Linux video capture interface: v2.00
    443. [    1.916656] usbcore: registered new interface driver uvcvideo
    444. [    1.922668] USB Video Class driver (1.1.1)
    445. [    2.014160] usb 1-1: New USB device found, idVendor=0424,
    446. idProduct=2412
    447. [    2.021148] usb 1-1: New USB device strings: Mfr=0, Product=0,
    448. SerialNumber=0
    449. [    2.030426] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    450. [    2.036926] hub 1-1:1.0: USB hub found
    451. [    2.040924] hub 1-1:1.0: 2 ports detected
    452. [    2.045318] _regulator_get: deviceless supply vdd_mpu not found,
    453. using dummy regulator
    454. [    2.054504] cpuidle: using governor ladder
    455. [    2.059570] cpuidle: using governor menu
    456. [    2.066833] omap4_aes_mod_init: loading AM33X AES driver
    457. [    2.072479] omap4-aes omap4-aes: AM33X AES hw accel rev: 3.02
    458. [    2.079010] omap4_aes_probe: probe() done
    459. [    2.083404] omap4_sham_mod_init: loading AM33X SHA/MD5 driver
    460. [    2.089569] omap4-sham omap4-sham: AM33X SHA/MD5 hw accel rev: 4.03
    461. [    2.101135] omap4_sham_probe: probe() done
    462. [    2.107788] usbcore: registered new interface driver usbhid
    463. [    2.113616] usbhid: USB HID core driver
    464. [    2.118286] tiadc tiadc: attached adc driver
    465. [    2.128143] ALSA device list:
    466. [    2.131225]   No soundcards found.
    467. [    2.134796] oprofile: hardware counters not available
    468. [    2.140045] oprofile: using timer interrupt.
    469. [    2.144531] nf_conntrack version 0.5.0 (1911 buckets, 7644 max)
    470. [    2.151153] ip_tables: (C) 2000-2006 Netfilter Core Team
    471. [    2.156860] TCP cubic registered
    472. [    2.160217] NET: Registered protocol family 17
    473. [    2.164886] can: controller area network core (rev 20090105 abi 8)
    474. [    2.171417] NET: Registered protocol family 29
    475. [    2.176086] can: raw protocol (rev 20090105)
    476. [    2.180511] can: broadcast manager protocol (rev 20090105 t)
    477. [    2.186462] lib80211: common routines for IEEE802.11 drivers
    478. [    2.192382] Registering the dns_resolver key type
    479. [    2.197357] VFP support v0.3: implementor 41 architecture 3 part 30
    480. variant c rev 3
    481. [    2.205352] ThumbEE CPU extension supported.
    482. [    2.209869] mux: Failed to setup hwmod io irq -22
    483. [    2.215393] Power Management for AM33XX family
    484. [    2.220245] Trying to load am335x-pm-firmware.bin (60 secs timeout)
    485. [    2.226928] Copied the M3 firmware to UMEM
    486. [    2.231292] Cortex M3 Firmware Version = 0x181
    487. [    2.236968] sr_init: platform driver register failed
    488. [    2.246795] clock: disabling unused clocks to save power
    489. [    2.267883] Detected MACID=bc:6a:29:db:8c:fa
    490. [    2.273437] cpsw: Detected MACID = bc:6a:29:db:8c:fb
    491. [    2.280548] input: gpio-keys as /devices/platform/gpio-
    492. keys/input/input1
    493. [    2.288208] omap_rtc am33xx-rtc: setting system clock to 2000-01-01
    494. 00:04:51 UTC (946685091)
    495. [    2.297546] Waiting for root device /dev/mmcblk0p2...
    496. [    2.313537] mmc0: new high speed SDHC card at address 1234
    497. [    2.319885] mmcblk0: mmc0:1234 SA08G 7.21 GiB
    498. [    2.326141]  mmcblk0: p1 p2
    499. [    2.405731] EXT3-fs (mmcblk0p2): error: couldn't mount because of
    500. unsupported optional features (240)
    501. [    2.415435] List of all partitions:
    502. [    2.419097] b300         7563264 mmcblk0  driver: mmcblk
    503. [    2.424682]   b301           98304 mmcblk0p1 00000000-0000-0000-
    504. 0000-000000000mmcblk0p1
    505. [    2.433013]   b302         1641472 mmcblk0p2 00000000-0000-0000-
    506. 0000-000000000mmcblk0p2
    507. [    2.441375] No filesystem could mount root, tried:  ext3
    508. [    2.446929] Kernel panic - not syncing: VFS: Unable to mount root fs
    509. on unknown-block(179,2)
    510. [    2.455749] Backtrace:
    511. [    2.458312] [<c0018d28>] (dump_backtrace+0x0/0x110) from
    512. [<c04f74e0>] (dump_stack+0x18/0x1c)
    513. [    2.467132]  r6:c07337e0 r5:c06bfb0c r4:c07363c8 r3:c06ef308
    514. [    2.473052] [<c04f74c8>] (dump_stack+0x0/0x1c) from [<c04f78ec>]
    515. (panic+0x6c/0x194)
    516. [    2.481048] [<c04f7880>] (panic+0x0/0x194) from [<c0690d1c>]
    517. (mount_block_root+0x224/0x240)
    518. [    2.489776]  r3:c701df1c r2:00000020 r1:c701df50 r0:c05e6a00
    519. [    2.495697]  r7:00000005
    520. [    2.498352] [<c0690af8>] (mount_block_root+0x0/0x240) from
    521. [<c0690f14>] (mount_root+0xf0/0xf8)
    522. [    2.507324] [<c0690e24>] (mount_root+0x0/0xf8) from [<c06910b4>]
    523. (prepare_namespace+0x198/0x1d4)
    524. [    2.516510]  r4:c07337e0
    525. [    2.519134] [<c0690f1c>] (prepare_namespace+0x0/0x1d4) from
    526. [<c0690904>] (kernel_init+0x120/0x124)
    527. [    2.528503]  r5:c06cbd18 r4:c06cbd18
    528. [    2.532226] [<c06907e4>] (kernel_init+0x0/0x124) from [<c0046a14>]
    529. (do_exit+0x0/0x690)
    530. [    2.540496]  r5:c06907e4 r4:00000000
    531. U-Boot SPL 2013.01.01 (Oct 17 2016 - 03:18:54)
    532. musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk
    533. split, HB-ISO Rx, HB-ISO Tx, SoftConn)
    534. musb-hdrc: MHDRC RTL version 2.0
    535. musb-hdrc: setup fifo_mode 4
    536. musb-hdrc: 28/31 max ep, 16384/16384 memory
    537. USB Peripheral mode controller at 47401000 using PIO, IRQ 0
    538. musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk
    539. split, HB-ISO Rx, HB-ISO Tx, SoftConn)
    540. musb-hdrc: MHDRC RTL version 2.0
    541. musb-hdrc: setup fifo_mode 4
    542. musb-hdrc: 28/31 max ep, 16384/16384 memory
    543. USB Host mode controller at 47401800 using PIO, IRQ 0
    544. OMAP SD/MMC: 0
    545. reading u-boot.img
    546. reading u-boot.img
    547. U-Boot 2013.01.01 (Oct 17 2016 - 03:18:54)
    548. I2C:   ready
    549. DRAM:  128 MiB
    550. WARNING: Caches not enabled
    551. NAND:  No NAND device found!!!
    552. 0 MiB
    553. MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    554. *** Warning - readenv() failed, using default environment
    555. musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk
    556. split, HB-ISO Rx, HB-ISO Tx, SoftConn)
    557. musb-hdrc: MHDRC RTL version 2.0
    558. musb-hdrc: setup fifo_mode 4
    559. musb-hdrc: 28/31 max ep, 16384/16384 memory
    560. USB Peripheral mode controller at 47401000 using PIO, IRQ 0
    561. musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk
    562. split, HB-ISO Rx, HB-ISO Tx, SoftConn)
    563. musb-hdrc: MHDRC RTL version 2.0
    564. musb-hdrc: setup fifo_mode 4
    565. musb-hdrc: 28/31 max ep, 16384/16384 memory
    566. USB Host mode controller at 47401800 using PIO, IRQ 0
    567. Net:   <ethaddr> not set. Validating first E-fuse MAC
    568. cpsw, usb_ether
    569. Hit any key to stop autoboot:  0
    570. ----------------------Select ROM Type-----------------------
    571. 0 -- Exit To Commond Line
    572. 1 -- MT29F1G08(128M Bytes NandFlah)
    573. 2 -- MT29F2G08(256M Bytes NandFlah)
    574. 3 --  K9K8G08 ( 1G  Bytes NandFlah)
    575. ------------------------------------------------------
    576. :0
    577. U-Boot#
    578. U-Boot#
    579. U-Boot# printenv
    580. arch=arm
    581. baudrate=115200
    582. board=am335x
    583. bootargs_defaults=setenv bootargs console=${console} ${optargs}
    584. bootcmd=mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on
    585. device ${mmcdev};if run loadbootenv; then echo Loaded environment from
    586. ${bootenv};run importbootenv;fi;if test -n $uenvcmd; then echo Running
    587. uenvcmd ...;run uenvcmd;fi;if run loaduimagefat; then run mmcboot;elif
    588. run loaduimage; then run mmcboot;else echo Could not find ${bootfile}
    589. ;fi;else run nandboot;fi;
    590. bootdelay=1
    591. bootenv=uEnv.txt
    592. bootfile=uImage
    593. console=ttyO0,115200n8
    594. cpu=armv7
    595. dfu_alt_info_emmc=rawemmc mmc 0 3751936
    596. dfu_alt_info_mmc=boot part 0 1;rootfs part 0 2;MLO fat 0 1;MLO.raw mmc
    597. 100 100;u-boot.img.raw mmc 300 3C0;u-boot.img fat 0 1;uEnv.txt fat 0 1
    598. dfu_alt_info_nand=SPL part 0 1;SPL.backup1 part 0 2;SPL.backup2 part 0
    599. 3;SPL.backup3 part 0 4;u-boot part 0 5;kernel part 0 7;rootfs part 0 8
    600. ethact=cpsw
    601. ethaddr=bc:6a:29:db:8c:fa
    602. fdt_high=0xffffffff
    603. fdtaddr=0x80F80000
    604. findfdt=if test $board_name = A335BONE; then setenv fdtfile am335x-
    605. bone.dtb; fi; if test $board_name = A33515BB; then setenv fdtfile
    606. am335x-evm.dtb; fi; if test $board_name = A335X_SK; then setenv fdtfile
    607. am335x-evmsk.dtb; fi
    608. importbootenv=echo Importing environment from mmc ...; env import -t
    609. $loadaddr $filesize
    610. ip_method=none
    611. kloadaddr=0x80007fc0
    612. loadaddr=0x80200000
    613. loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}
    614. loadramdisk=fatload mmc ${mmcdev} ${rdaddr} ramdisk.gz
    615. loaduimage=ext2load mmc ${mmcdev}:2 ${kloadaddr} /boot/${bootfile}
    616. loaduimagefat=fatload mmc ${mmcdev} ${kloadaddr} ${bootfile}
    617. mmcargs=run bootargs_defaults;setenv bootargs ${bootargs} root=
    618. ${mmcroot} rootfstype=${mmcrootfstype} ip=${ip_method}
    619. mmcboot=echo Booting from mmc ...; run mmcargs; bootm ${kloadaddr}
    620. mmcdev=0
    621. mmcroot=/dev/mmcblk0p2 ro
    622. mmcrootfstype=ext3 rootwait
    623. mtdids=nand0=omap2-nand.0
    624. mtdparts=mtdparts=omap2-nand.0:128k(SPL),128k(SPL.backup1),128k
    625. (SPL.backup2),128k(SPL.backup3),1920k(u-boot),128k(u-boot-env),5m
    626. (kernel),-(rootfs)
    627. nandargs=setenv bootargs console=${console} ${optargs} root=${nandroot}
    628. rootfstype=${nandrootfstype}
    629. nandboot=echo Booting from nand ...; run nandargs; nand read
    630. ${loadaddr} ${nandsrcaddr} ${nandimgsize}; bootm ${loadaddr}
    631. nandimgsize=0x500000
    632. nandroot=ubi0:rootfs rw ubi.mtd=7,2048
    633. nandrootfstype=ubifs rootwait=1
    634. nandsrcaddr=0x280000
    635. netargs=setenv bootargs console=${console} ${optargs} root=/dev/nfs
    636. nfsroot=${serverip}:${rootpath},${nfsopts} rw ip=dhcp
    637. netboot=echo Booting from network ...; setenv autoload no; dhcp; tftp
    638. ${loadaddr} ${bootfile}; run netargs; bootm ${loadaddr}
    639. nfsopts=nolock
    640. ramargs=setenv bootargs console=${console} ${optargs} root=${ramroot}
    641. rootfstype=${ramrootfstype}
    642. ramboot=echo Booting from ramdisk ...; run ramargs; bootm ${loadaddr}
    643. ramroot=/dev/ram0 rw ramdisk_size=65536 initrd=${rdaddr},64M
    644. ramrootfstype=ext2
    645. rdaddr=0x81000000
    646. rootpath=/export/rootfs
    647. soc=am33xx
    648. spiargs=setenv bootargs console=${console} ${optargs} root=${spiroot}
    649. rootfstype=${spirootfstype}
    650. spiboot=echo Booting from spi ...; run spiargs; sf probe ${spibusno}:0;
    651. sf read ${loadaddr} ${spisrcaddr} ${spiimgsize}; bootm ${loadaddr}
    652. spibusno=0
    653. spiimgsize=0x362000
    654. spiroot=/dev/mtdblock4 rw
    655. spirootfstype=jffs2
    656. spisrcaddr=0xe0000
    657. static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:
    658. ${hostname}::off
    659. stderr=serial
    660. stdin=serial
    661. stdout=serial
    662. usbnet_devaddr=bc:6a:29:db:8c:fa
    663. vendor=ti
    664. ver=U-Boot 2013.01.01 (Oct 17 2016 - 03:18:54)
    665. Environment size: 3554/131068 bytes
    666. U-Boot# setenv bootargs "console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw
    667. rootfstype=ext4 rootwait ip=none"
    668. U-Boot# boot
    669. mmc0 is current device
    670. SD/MMC found on device 0
    671. reading uEnv.txt
    672. ** Unable to read file uEnv.txt **
    673. reading uImage
    674. 3794656 bytes read in 391 ms (9.3 MiB/s)
    675. Booting from mmc ...
    676. ## Booting kernel from Legacy Image at 80007fc0 ...
    677.    Image Name:   Linux-3.2.0
    678.    Image Type:   ARM Linux Kernel Image (uncompressed)
    679.    Data Size:    3794592 Bytes = 3.6 MiB
    680.    Load Address: 80008000
    681.    Entry Point:  80008000
    682.    Verifying Checksum ... OK
    683.    XIP Kernel Image ... OK
    684. OK
    685. Starting kernel ...
    686. Uncompressing Linux... done, booting the kernel.
    687. [    0.000000] Linux version 3.2.0 (root@ubuntu) (gcc version 4.6.1
    688. (Sourcery CodeBench Lite 2011.09-70) ) #60 Sat Jan 21 00:40:51 CST 2017
    689. [    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7),
    690. cr=10c53c7d
    691. [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing
    692. instruction cache
    693. [    0.000000] Machine: am335xevm
    694. [    0.000000] Memory policy: ECC disabled, Data cache writeback
    695. [    0.000000] AM335X ES1.0 (neon )
    696. [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.
    697. Total pages: 32512
    698. [    0.000000] Kernel command line: console=ttyO0,115200n8
    699. root=/dev/mmcblk0p2 ro rootfstype=ext3 rootwait ip=none
    700. [    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
    701. [    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536
    702. bytes)
    703. [    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768
    704. bytes)
    705. [    0.000000] Memory: 128MB = 128MB total
    706. [    0.000000] Memory: 122344k/122344k available, 8728k reserved, 0K
    707. highmem
    708. [    0.000000] Virtual kernel memory layout:
    709. [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    710. [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    711. [    0.000000]     vmalloc : 0xc8800000 - 0xff000000   ( 872 MB)
    712. [    0.000000]     lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
    713. [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
    714. [    0.000000]       .text : 0xc0008000 - 0xc0690000   (6688 kB)
    715. [    0.000000]       .init : 0xc0690000 - 0xc06cc000   ( 240 kB)
    716. [    0.000000]       .data : 0xc06cc000 - 0xc0733748   ( 414 kB)
    717. [    0.000000]        .bss : 0xc073376c - 0xc0762900   ( 189 kB)
    718. [    0.000000] NR_IRQS:396
    719. [    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128
    720. interrupts
    721. [    0.000000] Total of 128 interrupts on 1 active controller
    722. [    0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
    723. [    0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
    724. [    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps
    725. every 131071999ms
    726. [    0.000000] Console: colour dummy device 80x30
    727. [    0.000091] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
    728. [    0.058532] pid_max: default: 32768 minimum: 301
    729. [    0.058654] Security Framework initialized
    730. [    0.058746] Mount-cache hash table entries: 512
    731. [    0.059112] CPU: Testing write buffer coherency: ok
    732. [    0.079467] omap_hwmod: gfx: failed to hardreset
    733. [    0.095764] omap_hwmod: pruss: failed to hardreset
    734. [    0.096801] print_constraints: dummy:
    735. [    0.097167] NET: Registered protocol family 16
    736. [    0.099304] OMAP GPIO hardware version 0.1
    737. [    0.101867] omap_mux_init: Add partition: #1: core, flags: 0
    738. [    0.103637]  omap_i2c.1: alias fck already exists
    739. [    0.105010]  da8xx_lcdc.0: alias fck already exists
    740. [    0.106262]  omap_i2c.2: alias fck already exists
    741. [    0.106567]  omap_hsmmc.0: alias fck already exists
    742. [    0.106872]  d_can.1: alias fck already exists
    743. [    0.107330]  omap_i2c.2: alias fck already exists
    744. [    0.107360] ------------[ cut here ]------------
    745. [    0.107421] WARNING: at fs/sysfs/dir.c:481 sysfs_add_one+0xa0/0xb0()
    746. [    0.107421] sysfs: cannot create duplicate filename
    747. '/devices/platform/omap/omap_i2c.2'
    748. [    0.107421] Modules linked in:
    749. [    0.107421] Backtrace:
    750. [    0.107482] [<c0018d28>] (dump_backtrace+0x0/0x110) from
    751. [<c04f74e0>] (dump_stack+0x18/0x1c)
    752. [    0.107482]  r6:000001e1 r5:c01119c8 r4:c701dcc8 r3:c06ef308
    753. [    0.107513] [<c04f74c8>] (dump_stack+0x0/0x1c) from [<c0043478>]
    754. (warn_slowpath_common+0x5c/0x6c)
    755. [    0.107543] [<c004341c>] (warn_slowpath_common+0x0/0x6c) from
    756. [<c004352c>] (warn_slowpath_fmt+0x38/0x40)
    757. [    0.107543]  r8:c7070770 r7:c702e000 r6:c7070770 r5:c702e000
    758. r4:ffffffef
    759. [    0.107574] r3:00000009
    760. [    0.107574] [<c00434f4>] (warn_slowpath_fmt+0x0/0x40) from
    761. [<c01119c8>] (sysfs_add_one+0xa0/0xb0)
    762. [    0.107604]  r3:c702e000 r2:c0600488
    763. [    0.107604] [<c0111928>] (sysfs_add_one+0x0/0xb0) from [<c0111a40>]
    764. (create_dir+0x68/0xbc)
    765. [    0.107635]  r7:00000000 r6:c7013a40 r5:00000001 r4:c7071e10
    766. [    0.107635] [<c01119d8>] (create_dir+0x0/0xbc) from [<c0111b58>]
    767. (sysfs_create_dir+0x90/0xe0)
    768. [    0.107666]  r8:00000000 r7:c06eeb00 r6:c7013a40 r5:00000000
    769. r4:c7071e10
    770. [    0.107696] [<c0111ac8>] (sysfs_create_dir+0x0/0xe0) from
    771. [<c022ce34>] (kobject_add_internal+0xa4/0x23c)
    772. [    0.107696]  r6:c06eeb08 r5:00000000 r4:c7071e10
    773. [    0.107727] [<c022cd90>] (kobject_add_internal+0x0/0x23c) from
    774. [<c022d304>] (kobject_add+0x54/0x94)
    775. [    0.107727]  r8:00000000 r7:c06eeb00 r6:00000000 r5:c06eeb08
    776. r4:c7071e10
    777. [    0.107788] [<c022d2b0>] (kobject_add+0x0/0x94) from [<c0295a18>]
    778. (device_add+0xa8/0x664)
    779. [    0.107788]  r3:00000000 r2:00000000
    780. [    0.107788]  r6:c7071e10 r5:c7071f28 r4:c7071e08
    781. [    0.107818] [<c0295970>] (device_add+0x0/0x664) from [<c029a58c>]
    782. (platform_device_add+0x120/0x280)
    783. [    0.107849] [<c029a46c>] (platform_device_add+0x0/0x280) from
    784. [<c003aae0>] (omap_device_register+0x3c/0x5c)
    785. [    0.107879]  r8:c07362e0 r7:c0500eb0 r6:00000000 r5:c706d2c0
    786. r4:c7071e00
    787. [    0.107879] r3:c06eeb00
    788. [    0.107910] [<c003aaa4>] (omap_device_register+0x0/0x5c) from
    789. [<c003ac08>] (omap_device_build_ss+0x108/0x14c)
    790. [    0.107910]  r4:c7071e00 r3:00000000
    791. [    0.107940] [<c003ab00>] (omap_device_build_ss+0x0/0x14c) from
    792. [<c003aca0>] (omap_device_build+0x54/0x5c)
    793. [    0.107971] [<c003ac4c>] (omap_device_build+0x0/0x5c) from
    794. [<c06a03f4>] (omap_i2c_add_bus+0x100/0x13c)
    795. [    0.107971] [<c06a02f4>] (omap_i2c_add_bus+0x0/0x13c) from
    796. [<c06a0574>] (omap_register_i2c_bus+0x7c/0x80)
    797. [    0.108001]  r7:c06c4a34 r6:00000000 r5:00000064 r4:00000002
    798. [    0.108032] [<c06a04f8>] (omap_register_i2c_bus+0x0/0x80) from
    799. [<c00372a0>] (i2c2_init+0x2c/0x34)
    800. [    0.108032]  r5:c06edab0 r4:000000b4
    801. [    0.108062] [<c0037274>] (i2c2_init+0x0/0x34) from [<c04f7808>]
    802. (_configure_device.constprop.8+0x40/0x58)
    803. [    0.108062] [<c04f77c8>] (_configure_device.constprop.8+0x0/0x58)
    804. from [<c069e9d0>] (dianyu335x_init+0x110/0x308)
    805. [    0.108093]  r6:c06ecf10 r5:c06c4964 r4:00000000 r3:c00b1410
    806. [    0.108123] [<c069e8c0>] (dianyu335x_init+0x0/0x308) from
    807. [<c06934bc>] (customize_machine+0x28/0x30)
    808. [    0.108123]  r7:00000000 r6:c0046a14 r5:c701c000 r4:c0733780
    809. [    0.108154] [<c0693494>] (customize_machine+0x0/0x30) from
    810. [<c00086d0>] (do_one_initcall+0x3c/0x178)
    811. [    0.108184] [<c0008694>] (do_one_initcall+0x0/0x178) from
    812. [<c0690880>] (kernel_init+0x9c/0x124)
    813. [    0.108215] [<c06907e4>] (kernel_init+0x0/0x124) from [<c0046a14>]
    814. (do_exit+0x0/0x690)
    815. [    0.108215]  r5:c06907e4 r4:00000000
    816. [    0.108276] ---[ end trace 1b75b31a2719ed1c ]---
    817. [    0.108276] kobject_add_internal failed for omap_i2c.2 with -EEXIST,
    818. don't try to register things with the same name in the same directory.
    819. [    0.108306] Backtrace:
    820. [    0.108306] [<c0018d28>] (dump_backtrace+0x0/0x110) from
    821. [<c04f74e0>] (dump_stack+0x18/0x1c)
    822. [    0.108337]  r6:c06eeb08 r5:ffffffef r4:c7071e10 r3:c06ef308
    823. [    0.108367] [<c04f74c8>] (dump_stack+0x0/0x1c) from [<c022cfc0>]
    824. (kobject_add_internal+0x230/0x23c)
    825. [    0.108367] [<c022cd90>] (kobject_add_internal+0x0/0x23c) from
    826. [<c022d304>] (kobject_add+0x54/0x94)
    827. [    0.108398]  r8:00000000 r7:c06eeb00 r6:00000000 r5:c06eeb08
    828. r4:c7071e10
    829. [    0.108428] [<c022d2b0>] (kobject_add+0x0/0x94) from [<c0295a18>]
    830. (device_add+0xa8/0x664)
    831. [    0.108428]  r3:00000000 r2:00000000
    832. [    0.108428]  r6:c7071e10 r5:c7071f28 r4:c7071e08
    833. [    0.108459] [<c0295970>] (device_add+0x0/0x664) from [<c029a58c>]
    834. (platform_device_add+0x120/0x280)
    835. [    0.108489] [<c029a46c>] (platform_device_add+0x0/0x280) from
    836. [<c003aae0>] (omap_device_register+0x3c/0x5c)
    837. [    0.108489]  r8:c07362e0 r7:c0500eb0 r6:00000000 r5:c706d2c0
    838. r4:c7071e00
    839. [    0.108520] r3:c06eeb00
    840. [    0.108520] [<c003aaa4>] (omap_device_register+0x0/0x5c) from
    841. [<c003ac08>] (omap_device_build_ss+0x108/0x14c)
    842. [    0.108551]  r4:c7071e00 r3:00000000
    843. [    0.108551] [<c003ab00>] (omap_device_build_ss+0x0/0x14c) from
    844. [<c003aca0>] (omap_device_build+0x54/0x5c)
    845. [    0.108612] [<c003ac4c>] (omap_device_build+0x0/0x5c) from
    846. [<c06a03f4>] (omap_i2c_add_bus+0x100/0x13c)
    847. [    0.108642] [<c06a02f4>] (omap_i2c_add_bus+0x0/0x13c) from
    848. [<c06a0574>] (omap_register_i2c_bus+0x7c/0x80)
    849. [    0.108673]  r7:c06c4a34 r6:00000000 r5:00000064 r4:00000002
    850. [    0.108673] [<c06a04f8>] (omap_register_i2c_bus+0x0/0x80) from
    851. [<c00372a0>] (i2c2_init+0x2c/0x34)
    852. [    0.108703]  r5:c06edab0 r4:000000b4
    853. [    0.108703] [<c0037274>] (i2c2_init+0x0/0x34) from [<c04f7808>]
    854. (_configure_device.constprop.8+0x40/0x58)
    855. [    0.108734] [<c04f77c8>] (_configure_device.constprop.8+0x0/0x58)
    856. from [<c069e9d0>] (dianyu335x_init+0x110/0x308)
    857. [    0.108764]  r6:c06ecf10 r5:c06c4964 r4:00000000 r3:c00b1410
    858. [    0.108764] [<c069e8c0>] (dianyu335x_init+0x0/0x308) from
    859. [<c06934bc>] (customize_machine+0x28/0x30)
    860. [    0.108795]  r7:00000000 r6:c0046a14 r5:c701c000 r4:c0733780
    861. [    0.108825] [<c0693494>] (customize_machine+0x0/0x30) from
    862. [<c00086d0>] (do_one_initcall+0x3c/0x178)
    863. [    0.108825] [<c0008694>] (do_one_initcall+0x0/0x178) from
    864. [<c0690880>] (kernel_init+0x9c/0x124)
    865. [    0.108856] [<c06907e4>] (kernel_init+0x0/0x124) from [<c0046a14>]
    866. (do_exit+0x0/0x690)
    867. [    0.108856]  r5:c06907e4 r4:00000000
    868. [    0.108886] omap_device: omap_i2c: build failed (-17)
    869. [    0.108886] ------------[ cut here ]------------
    870. [    0.108917] WARNING: at arch/arm/plat-omap/i2c.c:188
    871. omap_i2c_add_bus+0x130/0x13c()
    872. [    0.108917] Could not build omap_device for omap_i2c
    873. [    0.108917] Modules linked in:
    874. [    0.108947] Backtrace:
    875. [    0.108947] [<c0018d28>] (dump_backtrace+0x0/0x110) from
    876. [<c04f74e0>] (dump_stack+0x18/0x1c)
    877. [    0.108947]  r6:000000bc r5:c06a0424 r4:c701deb0 r3:c06ef308
    878. [    0.108978] [<c04f74c8>] (dump_stack+0x0/0x1c) from [<c0043478>]
    879. (warn_slowpath_common+0x5c/0x6c)
    880. [    0.109008] [<c004341c>] (warn_slowpath_common+0x0/0x6c) from
    881. [<c004352c>] (warn_slowpath_fmt+0x38/0x40)
    882. [    0.109008]  r8:00000000 r7:00000014 r6:c003bf70 r5:ffffffef
    883. r4:00000000
    884. [    0.109039] r3:00000009
    885. [    0.109039] [<c00434f4>] (warn_slowpath_fmt+0x0/0x40) from
    886. [<c06a0424>] (omap_i2c_add_bus+0x130/0x13c)
    887. [    0.109069]  r3:c0500eb0 r2:c05eaf88
    888. [    0.109069] [<c06a02f4>] (omap_i2c_add_bus+0x0/0x13c) from
    889. [<c06a0574>] (omap_register_i2c_bus+0x7c/0x80)
    890. [    0.109100]  r7:c06c4a34 r6:00000000 r5:00000064 r4:00000002
    891. [    0.109130] [<c06a04f8>] (omap_register_i2c_bus+0x0/0x80) from
    892. [<c00372a0>] (i2c2_init+0x2c/0x34)
    893. [    0.109130]  r5:c06edab0 r4:000000b4
    894. [    0.109161] [<c0037274>] (i2c2_init+0x0/0x34) from [<c04f7808>]
    895. (_configure_device.constprop.8+0x40/0x58)
    896. [    0.109161] [<c04f77c8>] (_configure_device.constprop.8+0x0/0x58)
    897. from [<c069e9d0>] (dianyu335x_init+0x110/0x308)
    898. [    0.109191]  r6:c06ecf10 r5:c06c4964 r4:00000000 r3:c00b1410
    899. [    0.109222] [<c069e8c0>] (dianyu335x_init+0x0/0x308) from
    900. [<c06934bc>] (customize_machine+0x28/0x30)
    901. [    0.109222]  r7:00000000 r6:c0046a14 r5:c701c000 r4:c0733780
    902. [    0.109252] [<c0693494>] (customize_machine+0x0/0x30) from
    903. [<c00086d0>] (do_one_initcall+0x3c/0x178)
    904. [    0.109252] [<c0008694>] (do_one_initcall+0x0/0x178) from
    905. [<c0690880>] (kernel_init+0x9c/0x124)
    906. [    0.109283] [<c06907e4>] (kernel_init+0x0/0x124) from [<c0046a14>]
    907. (do_exit+0x0/0x690)
    908. [    0.109283]  r5:c06907e4 r4:00000000
    909. [    0.109313] ---[ end trace 1b75b31a2719ed1d ]---
    910. [    0.109313] failed to get adapter i2c1
    911. [    0.109313] The board is Sail335.
    912. [    0.109985] _regulator_get: l3_main.0 supply vdd_core not found,
    913. using dummy regulator
    914. [    0.110076] am335x_opp_update: physical regulator not present for
    915. core(-22)
    916. [    0.110443]  omap2_mcspi.1: alias fck already exists
    917. [    0.110656]  omap2_mcspi.2: alias fck already exists
    918. [    0.111633]  edma.0: alias fck already exists
    919. [    0.111663]  edma.0: alias fck already exists
    920. [    0.111663]  edma.0: alias fck already exists
    921. [    0.137786] bio: create slab <bio-0> at 0
    922. [    0.139923] SCSI subsystem initialized
    923. [    0.141876] usbcore: registered new interface driver usbfs
    924. [    0.142181] usbcore: registered new interface driver hub
    925. [    0.142395] usbcore: registered new device driver usb
    926. [    0.142700] registerd cppi-dma Intr @ IRQ 17
    927. [    0.142700] Cppi41 Init Done Qmgr-base(c887a000) dma-base(c8878000)
    928. [    0.142700] Cppi41 Init Done
    929. [    0.142730] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13,
    930. plat_mode=0x3
    931. [    0.143035] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13,
    932. plat_mode=0x1
    933. [    0.144195] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
    934. [    0.158599] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
    935. [    0.159362] pps_core: LinuxPPS API ver. 1 registered
    936. [    0.159362] pps_core: Software ver. 5.3.6 - Copyright 2005-2007
    937. Rodolfo Giometti <giometti@linux.it>
    938. [    0.159484] PTP clock support registered
    939. [    0.160369] Advanced Linux Sound Architecture Driver Version 1.0.24.
    940. [    0.161651] cfg80211: Calling CRDA to update world regulatory domain
    941. [    0.162719] Switching to clocksource gp timer
    942. [    0.178222] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    943. [    0.178405] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
    944. [    0.178741] MUSB0 controller's USBSS revision = 4ea20800
    945. [    0.179687] musb-hdrc musb-hdrc.0: USB OTG mode controller at
    946. c883c000 using DMA, IRQ 18
    947. [    0.179840] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
    948. [    0.180145] MUSB1 controller's USBSS revision = 4ea20800
    949. [    0.180572] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
    950. [    0.180633] musb-hdrc musb-hdrc.1: new USB bus registered, assigned
    951. bus number 1
    952. [    0.180755] usb usb1: New USB device found, idVendor=1d6b,
    953. idProduct=0002
    954. [    0.180786] usb usb1: New USB device strings: Mfr=3, Product=2,
    955. SerialNumber=1
    956. [    0.180786] usb usb1: Product: MUSB HDRC host driver
    957. [    0.180816] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
    958. [    0.180816] usb usb1: SerialNumber: musb-hdrc.1
    959. [    0.181579] hub 1-0:1.0: USB hub found
    960. [    0.181610] hub 1-0:1.0: 1 port detected
    961. [    0.182159] musb-hdrc musb-hdrc.1: USB Host mode controller at
    962. c883e800 using DMA, IRQ 19
    963. [    0.182556] NET: Registered protocol family 2
    964. [    0.182739] IP route cache hash table entries: 1024 (order: 0, 4096
    965. bytes)
    966. [    0.183105] TCP established hash table entries: 4096 (order: 3,
    967. 32768 bytes)
    968. [    0.183166] TCP bind hash table entries: 4096 (order: 2, 16384
    969. bytes)
    970. [    0.183227] TCP: Hash tables configured (established 4096 bind 4096)
    971. [    0.183258] TCP reno registered
    972. [    0.183258] UDP hash table entries: 256 (order: 0, 4096 bytes)
    973. [    0.183288] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    974. [    0.183471] NET: Registered protocol family 1
    975. [    0.183715] RPC: Registered named UNIX socket transport module.
    976. [    0.183746] RPC: Registered udp transport module.
    977. [    0.183746] RPC: Registered tcp transport module.
    978. [    0.183746] RPC: Registered tcp NFSv4.1 backchannel transport
    979. module.
    980. [    0.183990] NetWinder Floating Point Emulator V0.97 (double
    981. precision)
    982. [    0.184204] omap-gpmc omap-gpmc: GPMC revision 6.0
    983. [    0.184204] Registering NAND on CS0
    984. [    0.190917] VFS: Disk quotas dquot_6.5.2
    985. [    0.190979] Dquot-cache hash table entries: 1024 (order 0, 4096
    986. bytes)
    987. [    0.191772] msgmni has been set to 238
    988. [    0.195068] alg: No test for stdrng (krng)
    989. [    0.195770] io scheduler noop registered
    990. [    0.195770] io scheduler deadline registered
    991. [    0.195831] io scheduler cfq registered (default)
    992. [    0.197174] da8xx_lcdc da8xx_lcdc.0: GLCD: Found
    993. TFC_S9700RTWV35TR_01B panel
    994. [    0.207794] Console: switching to colour frame buffer device 100x30
    995. [    0.214447] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a
    996. OMAP UART0
    997. [    1.631134] console [ttyO0] enabled
    998. [    1.635559] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a
    999. OMAP UART1
    1000. [    1.643371] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a
    1001. OMAP UART2
    1002. [    1.651153] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a
    1003. OMAP UART3
    1004. [    1.658966] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a
    1005. OMAP UART4
    1006. [    1.666717] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a
    1007. OMAP UART5
    1008. [    1.675018] omap4_rng omap4_rng: OMAP4 Random Number Generator ver.
    1009. 2.00
    1010. [    1.691345] brd: module loaded
    1011. [    1.699432] loop: module loaded
    1012. [    1.702880] i2c-core: driver [tsl2550] using legacy suspend method
    1013. [    1.709381] i2c-core: driver [tsl2550] using legacy resume method
    1014. [    1.718200] mtdoops: mtd device (mtddev=name/number) must be
    1015. supplied
    1016. [    1.725524] omap2-nand driver initializing
    1017. [    1.730194] No NAND device found
    1018. [    1.733795] No NAND device found
    1019. [    1.737518] OneNAND driver initializing
    1020. [    1.743896] CAN device driver interface
    1021. [    1.747924] CAN bus driver for Bosch D_CAN controller 1.0
    1022. [    1.754394] d_can d_can.1: device registered (irq=55, irq_obj=56)
    1023. [    1.803955] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
    1024. [    1.810394] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
    1025. [    1.817565] davinci_mdio.0: probed
    1026. [    1.821136] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver
    1027. unknown
    1028. [    1.828918] usbcore: registered new interface driver cdc_ether
    1029. [    1.835205] usbcore: registered new interface driver cdc_eem
    1030. [    1.841247] usbcore: registered new interface driver dm9601
    1031. [    1.847106] cdc_ncm: 04-Aug-2011
    1032. [    1.850646] usbcore: registered new interface driver cdc_ncm
    1033. [    1.856567] Initializing USB Mass Storage driver...
    1034. [    1.861785] usb 1-1: new high-speed USB device number 2 using musb-
    1035. hdrc
    1036. [    1.868957] usbcore: registered new interface driver usb-storage
    1037. [    1.875213] USB Mass Storage support registered.
    1038. [    1.880584] mousedev: PS/2 mouse device common for all mice
    1039. [    1.887390] input: ti-tsc as
    1040. /devices/platform/omap/ti_tscadc/tsc/input/input0
    1041. [    1.895996] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as
    1042. rtc0
    1043. [    1.902984] am33xx-rtc: already running
    1044. [    1.907196] i2c /dev entries driver
    1045. [    1.911437] Linux video capture interface: v2.00
    1046. [    1.916595] usbcore: registered new interface driver uvcvideo
    1047. [    1.922576] USB Video Class driver (1.1.1)
    1048. [    2.014129] usb 1-1: New USB device found, idVendor=0424,
    1049. idProduct=2412
    1050. [    2.021118] usb 1-1: New USB device strings: Mfr=0, Product=0,
    1051. SerialNumber=0
    1052. [    2.030456] hub 1-1:1.0: USB hub found
    1053. [    2.034484] hub 1-1:1.0: 2 ports detected
    1054. [    2.038787] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    1055. [    2.045410] _regulator_get: deviceless supply vdd_mpu not found,
    1056. using dummy regulator
    1057. [    2.054809] cpuidle: using governor ladder
    1058. [    2.059570] cpuidle: using governor menu
    1059. [    2.066833] omap4_aes_mod_init: loading AM33X AES driver
    1060. [    2.072509] omap4-aes omap4-aes: AM33X AES hw accel rev: 3.02
    1061. [    2.079010] omap4_aes_probe: probe() done
    1062. [    2.083435] omap4_sham_mod_init: loading AM33X SHA/MD5 driver
    1063. [    2.089569] omap4-sham omap4-sham: AM33X SHA/MD5 hw accel rev: 4.03
    1064. [    2.101104] omap4_sham_probe: probe() done
    1065. [    2.107757] usbcore: registered new interface driver usbhid
    1066. [    2.113586] usbhid: USB HID core driver
    1067. [    2.118255] tiadc tiadc: attached adc driver
    1068. [    2.128112] ALSA device list:
    1069. [    2.131195]   No soundcards found.
    1070. [    2.134765] oprofile: hardware counters not available
    1071. [    2.140014] oprofile: using timer interrupt.
    1072. [    2.144531] nf_conntrack version 0.5.0 (1911 buckets, 7644 max)
    1073. [    2.151153] ip_tables: (C) 2000-2006 Netfilter Core Team
    1074. [    2.156829] TCP cubic registered
    1075. [    2.160186] NET: Registered protocol family 17
    1076. [    2.164855] can: controller area network core (rev 20090105 abi 8)
    1077. [    2.171386] NET: Registered protocol family 29
    1078. [    2.176025] can: raw protocol (rev 20090105)
    1079. [    2.180480] can: broadcast manager protocol (rev 20090105 t)
    1080. [    2.186431] lib80211: common routines for IEEE802.11 drivers
    1081. [    2.192352] Registering the dns_resolver key type
    1082. [    2.197326] VFP support v0.3: implementor 41 architecture 3 part 30
    1083. variant c rev 3
    1084. [    2.205322] ThumbEE CPU extension supported.
    1085. [    2.209838] mux: Failed to setup hwmod io irq -22
    1086. [    2.215362] Power Management for AM33XX family
    1087. [    2.220184] Trying to load am335x-pm-firmware.bin (60 secs timeout)
    1088. [    2.226898] Copied the M3 firmware to UMEM
    1089. [    2.231231] Cortex M3 Firmware Version = 0x181
    1090. [    2.236907] sr_init: platform driver register failed
    1091. [    2.246734] clock: disabling unused clocks to save power
    1092. [    2.267791] Detected MACID=bc:6a:29:db:8c:fa
    1093. [    2.273345] cpsw: Detected MACID = bc:6a:29:db:8c:fb
    1094. [    2.280426] input: gpio-keys as /devices/platform/gpio-
    1095. keys/input/input1
    1096. [    2.288116] omap_rtc am33xx-rtc: setting system clock to 2000-01-01
    1097. 00:07:49 UTC (946685269)
    1098. [    2.297424] Waiting for root device /dev/mmcblk0p2...
    1099. [    2.313446] mmc0: new high speed SDHC card at address 1234
    1100. [    2.319763] mmcblk0: mmc0:1234 SA08G 7.21 GiB
    1101. [    2.326049]  mmcblk0: p1 p2
    1102. [    2.405700] EXT3-fs (mmcblk0p2): error: couldn't mount because of
    1103. unsupported optional features (240)
    1104. [    2.415405] List of all partitions:
    1105. [    2.419067] b300         7563264 mmcblk0  driver: mmcblk
    1106. [    2.424652]   b301           98304 mmcblk0p1 00000000-0000-0000-
    1107. 0000-000000000mmcblk0p1
    1108. [    2.433013]   b302         1641472 mmcblk0p2 00000000-0000-0000-
    1109. 0000-000000000mmcblk0p2
    1110. [    2.441375] No filesystem could mount root, tried:  ext3
    1111. [    2.446929] Kernel panic - not syncing: VFS: Unable to mount root fs
    1112. on unknown-block(179,2)
    1113. [    2.455718] Backtrace:
    1114. [    2.458312] [<c0018d28>] (dump_backtrace+0x0/0x110) from
    1115. [<c04f74e0>] (dump_stack+0x18/0x1c)
    1116. [    2.467102]  r6:c07337e0 r5:c06bfb0c r4:c07363c8 r3:c06ef308
    1117. [    2.473022] [<c04f74c8>] (dump_stack+0x0/0x1c) from [<c04f78ec>]
    1118. (panic+0x6c/0x194)
    1119. [    2.481048] [<c04f7880>] (panic+0x0/0x194) from [<c0690d1c>]
    1120. (mount_block_root+0x224/0x240)
    1121. [    2.489746]  r3:c701df1c r2:00000020 r1:c701df50 r0:c05e6a00
    1122. [    2.495666]  r7:00000005
    1123. [    2.498321] [<c0690af8>] (mount_block_root+0x0/0x240) from
    1124. [<c0690f14>] (mount_root+0xf0/0xf8)
    1125. [    2.507324] [<c0690e24>] (mount_root+0x0/0xf8) from [<c06910b4>]
    1126. (prepare_namespace+0x198/0x1d4)
    1127. [    2.516479]  r4:c07337e0
    1128. [    2.519134] [<c0690f1c>] (prepare_namespace+0x0/0x1d4) from
    1129. [<c0690904>] (kernel_init+0x120/0x124)
    1130. [    2.528472]  r5:c06cbd18 r4:c06cbd18
    1131. [    2.532226] [<c06907e4>] (kernel_init+0x0/0x124) from [<c0046a14>]
    1132. (do_exit+0x0/0x690)
    1133. [    2.540496]  r5:c06907e4 r4:00000000
    没能进入了系统,打印停止,求高手分析可以怎么解决!
  • 签到天数: 1354 天
    发表于 2017-1-30 23:06:33 | 显示全部楼层
    代码写的好,学习和参考
    GMT+8, 2024-4-29 16:32 , Processed in 0.120271 second(s), 17 queries , MemCache On.
