查看: 3925|回复: 2
[GD32F450测试]1、点亮LED+串口LCD的LED
  • 签到天数: 226 天
    发表于 2017-5-25 15:25:12 | 显示全部楼层 |阅读模式
    这个实验的内容较多,包括LED、各种时钟下的消耗电流、驱显串口黑白LCD0713等。
    点亮LED,只是测试开发板的所有首选,可以测试开发板的主芯片和IO状况,尽管是有限个IO和基本代码,但很能说明问题。为了接着的实验,控制串口LCD,因此
    线修改gd32f4xx_eval.h函数中的定义LED的那一段,直接改为:
    /* exported types */
    typedef enum{
        LED1 = 0,
        LED2 = 1,
        LED3 = 2,
        LED4 = 3,
        SDIN = 4,
        SCLK = 5,
        SREG = 6,
        SRES = 7
    } led_typedef_enum;
    增加一段LCD定义:
    /eval board LCD pins
    #define LEDn                             8U
    #define SDIN_PIN                         GPIO_PIN_2
    #define SDIN_GPIO_PORT                   GPIOE
    #define SDIN_GPIO_CLK                    RCU_GPIOE
    #define SCLK_PIN                         GPIO_PIN_5
    #define SCLK_GPIO_PORT                   GPIOE
    #define SCLK_GPIO_CLK                    RCU_GPIOE
    #define SREG_PIN                         GPIO_PIN_4
    #define SREG_GPIO_PORT                   GPIOE
    #define SREG_GPIO_CLK                    RCU_GPIOE
    #define SRES_PIN                         GPIO_PIN_6
    #define SRES_GPIO_PORT                   GPIOE
    #define SRES_GPIO_CLK                    RCU_GPIOE
    打开Utilities\gd32f4xx_eval.c文档,修改如下几个函数:
    static uint32_t GPIO_PORT[LEDn]={LED1_GPIO_PORT,LED2_GPIO_PORT,LED3_GPIO_PORT,LED4_GPIO_PORT,SDIN_GPIO_PORT,SCLK_GPIO_PORT,SREG_GPIO_PORT,SRES_GPIO_PORT};
    static uint32_t GPIO_PIN[LEDn]={LED1_PIN,LED2_PIN,LED3_PIN,LED4_PIN,SDIN_PIN,SCLK_PIN,SREG_PIN,SRES_PIN};
    static rcu_periph_enum GPIO_CLK[LEDn]={LED1_GPIO_CLK,LED2_GPIO_CLK,LED3_GPIO_CLK,LED4_GPIO_CLK,SDIN_GPIO_CLK,SCLK_GPIO_CLK,SREG_GPIO_CLK,SRES_GPIO_CLK};
    在main.c中增加:
    //GPIO Initial
    void ioInit(void){
    gd_eval_led_init(LED1);
    gd_eval_led_init(LED2);
    gd_eval_led_init(LED3);
    gd_eval_led_init(LED4);
    gd_eval_led_init(SDIN);
    gd_eval_led_init(SCLK);
    gd_eval_led_init(SREG);
    gd_eval_led_init(SRES);
    //LED Test
    void ledTest(void){
    int tts=500;
    gd_eval_led_on(LED1);gd_eval_led_off(SRES);delay_1ms(tts);
    gd_eval_led_on(LED2);gd_eval_led_off(LED1);delay_1ms(tts);
    gd_eval_led_on(LED3);gd_eval_led_off(LED2);delay_1ms(tts);
    gd_eval_led_on(LED4);gd_eval_led_off(LED3);delay_1ms(tts);
    gd_eval_led_on(SDIN);gd_eval_led_off(LED4);delay_1ms(tts);
    gd_eval_led_on(SCLK);gd_eval_led_off(SDIN);delay_1ms(tts);
    gd_eval_led_on(SREG);gd_eval_led_off(SCLK);delay_1ms(tts);
    gd_eval_led_on(SRES);gd_eval_led_off(SREG);delay_1ms(tts);
    最后的main函数中:
    //main function
    int main(void){
    systick_config();
    ioInit();
    while(1){
      ledTest();
    编译下载,结果照片见11。为了测试不同PLL下的功耗——就是测近似电流[USB测表,很不准的,只是大意吧],PLL200MHz、PLL168MHz、PLL120MHz、和IRC16MHz的照片分别是12,13,14,15。可见当打开PLL频率在120MHz以上是的电流增加的不多。就是说PLL打开后的功耗可以忽略了。
    接着作串口LCD实验。首先创建一个文件夹,先在1.4 项目中创建一个文件夹incs,将0713.h拷贝到里面,再在项目中创建1个组:incs;并且在Option中声明此incs文件夹默认路径。将0713.h加到里面,0713.h代码如下:
    #include "gd32f4xx.h"
    #include "gd32f4xx_eval.h"
    #include "systick.h"
    #include <stdio.h>
    //KS0713 LCD
    const unsigned char asc2[][6]={//8x8 Dots 32-126[0-94]
    {0x00,0x3E,0x45,0x49,0x51,0x3E},//0
    {0x00,0x00,0x21,0x7F,0x01,0x00},//1
    {0x00,0x31,0x43,0x45,0x49,0x31},//2
    {0x00,0x22,0x49,0x49,0x49,0x36},//3
    {0x00,0x04,0x0C,0x14,0x7F,0x04},//4
    {0x00,0x72,0x51,0x51,0x51,0x4E},//5-5
    {0x00,0x3E,0x49,0x49,0x49,0x06},//6
    {0x00,0x40,0x43,0x4C,0x50,0x60},//7
    {0x00,0x36,0x49,0x49,0x49,0x36},//8
    {0x00,0x30,0x48,0x48,0x48,0x3F},//9
    {0x00,0x1F,0x24,0x64,0x24,0x1F},//A-10
    {0x00,0x41,0x7F,0x49,0x49,0x36},//B
    {0x00,0x3E,0x41,0x41,0x41,0x22},//C
    {0x00,0x41,0x7F,0x41,0x41,0x3E},//D
    {0x00,0x41,0x7F,0x49,0x49,0x63},//E
    {0x00,0x41,0x7F,0x49,0x5C,0x60},//F-15
    {0x00,0x3E,0x41,0x45,0x47,0x24},//G
    {0x41,0x7F,0x08,0x08,0x08,0x7F},//H
    {0x00,0x00,0x41,0x7F,0x41,0x00},//I
    {0x00,0x42,0x41,0x7F,0x40,0x40},//J
    {0x00,0x41,0x7F,0x59,0x24,0x43},//K-20
    {0x00,0x40,0x7F,0x41,0x01,0x03},//L
    {0x00,0x7F,0x20,0x1E,0x20,0x7F},//M
    {0x00,0x7F,0x30,0x18,0x06,0x7F},//N
    {0x00,0x3E,0x41,0x41,0x41,0x3E},//O
    {0x00,0x41,0x7F,0x49,0x48,0x30},//P-25
    {0x00,0x3E,0x41,0x47,0x42,0x3D},//Q
    {0x00,0x41,0x7F,0x49,0x4C,0x33},//R
    {0x00,0x32,0x49,0x49,0x49,0x26},//S
    {0x00,0x60,0x41,0x7F,0x41,0x60},//T
    {0x00,0x7E,0x01,0x01,0x01,0x7E},//U-30
    {0x00,0x7C,0x02,0x01,0x02,0x7C},//V
    {0x00,0x7C,0x03,0x3C,0x03,0x7C},//W
    {0x00,0x43,0x24,0x18,0x24,0x43},//X
    {0x00,0x60,0x18,0x07,0x18,0x60},//Y
    {0x00,0x63,0x45,0x49,0x51,0x63},//Z-35
    {0x00,0x00,0x00,0x01,0x00,0x00},//.
    {0x00,0x14,0x14,0x14,0x14,0x14},//=
    {0x00,0x08,0x08,0x3E,0x08,0x08},//+
    {0x00,0x08,0x08,0x08,0x08,0x08},//-
    {0x00,0x00,0x00,0x24,0x00,0x00},//:-40
    //Delayer
    void delay(int counter){
    int i,j;
    for(i=0;i<counter;i++) for(j=0;j<i;j++){;}
    //Write Plus//1=clk,2=dat,3=reg,4=res
    void wri(void){
    //a B Data to LCD,dt:data,com:1-dat/0-com//1=clk,2=dat,3=reg,4=res
    void b2l(unsigned char dt,unsigned char com){
    unsigned char i;
    if(com)gd_eval_led_on(SREG);else gd_eval_led_off(SREG);
    for(i=0;i<8;i++){
      if(dt&0x80){gd_eval_led_on(SDIN);}else{gd_eval_led_off(SDIN);};
      dt=dt<<1;
      wri();
    //Set LCD X:0-102 Y:0-3
    void setXY(unsigned char pag,unsigned char col){
    b2l(0xB0+pag,0);//page
    //col+=0x04;//+4-->4bit
    b2l(0x10+((col&0x70)>>4),0);//row-H4
    b2l(col&0x0F,0);//row-L4
    //LCD Clear
    void lcdClear(void){
    unsigned char pag,col;
    for(pag=0;pag<8;pag++){
      setXY(pag,0);
      for(col=0;col<132;col++){b2l(0x00,1);};
    //c:Char,cha[]
    void c2l(unsigned char pag,unsigned char col,unsigned char c){
    unsigned char line;
    setXY(pag,col*6);//6
    for (line=0;line<6;line++)//6
    b2l(asc2[c][line],1);//b2l(hanzi[c*8+line],1);
    //KS0713LCD Initial
    void lcdInit(void){
    delay(2000);
    delay(2000);
    b2l(0xAE,0);//AE=关闭显示/AF=开显示
    b2l(0xE2,0);//LCD初始化
    b2l(0xA1,0);//刷新行顺序A0=1~132列/A1=132~1
    b2l(0xC8,0);//刷新纵顺序C0=1~64行/C8=64~1
    b2l(0xA2,0);//A2=1/65=1/7__A3=1/65=1/9速率
    b2l(0x2F,0);//电源模式28+VC+VR+VF
    delay(200);
    b2l(0x23,0);//20~27=1.9,2.19,2.55,3.02,3.61,4.35,5.29,6.48V/偏压
    delay(200);
    b2l(0x81,0);//V0电压,后跟参数
    b2l(0x2C,0);//000000~111111=0~63=8.83~11.17V/30=10V
    delay(200);
    b2l(0xAD,0);//AC=关闭游标/AD=打开游标
    b2l(0x00,0);//跟上00=OFF/01=1S/02=0.5S/03=AllOn
    b2l(0xAF,0);//开始显示
    delay(200);
    //0713 Display ASCII Test
    void dispAsc(void){
    int i,j,k=0;
    for(i=0;i<4;i++){
      for(j=0;j<16;j++){
       c2l(i,j,k);
       if(k>39){k=0;}else{k++;}
    //END Files//
    由于设置LED实验已经定义了串口的4根引脚的信号:SDIN、SCLK、SREG、SRES,因此这里省略了。main.c中需要增加一个定时函数:
    //DELAYER
    void delaym(int counter){
    int i,j;
    更改ledTest函数,只是为了测试主函数在运行,所以1个LED闪亮就可以了:
    void ledTest(void){
    int tts=1000;
    delaym(tts);
    main更改为:
    //main function
    int main(void){
    systick_config();
    ioInit();
    lcdInit();
    lcdClear();
    while(1){
      js++;
      ledTest();
      dispAsc();
      delaym(10000);
      lcdClear();
    最后修改system_gd32f4xx.c,开通下一行,其他的时钟注释掉[#define __SYSTEM_CLOCK_IRC16M (uint32_t)(__IRC16M)这一行开通,刷屏明显]
    #define __SYSTEM_CLOCK_120M_PLL_IRC16M (uint32_t)(120000000)
    下载后的待测试电流的结果照片见16,没有测电流的照片17。
    11
    11
    12
    12
    13
    13
    14
    14
    15
    15
    16
    16
    17
    17
  • 签到天数: 1018 天
    发表于 2017-5-25 16:40:01 | 显示全部楼层
    顶顶顶顶顶顶顶顶
  • 签到天数: 1354 天
    发表于 2017-5-25 22:19:24 | 显示全部楼层
    参考和学习
    GMT+8, 2024-4-26 13:53 , Processed in 0.131302 second(s), 20 queries , MemCache On.
