查看: 6400|回复: 1
[BeagleBone Black]19. Unixbench测试系统
  • 签到天数: 592 天
    发表于 2018-1-2 19:48:48 | 显示全部楼层 |阅读模式
    19. Unixbench测试系统
    [BeagleBone Black] 连载目录
    Unixbench测试工具和使用安装过程
    Github,找到源码,安装:
    试用默认没有修改配置,直接编译:make
    运行:
    Cpu 全速运行:
    测试进度:
    测试 load 最高时候 7.41,单 arm 核:
    等结束看结果:
    测试花了 29 分钟。
    1. ========================================================================
    2.    BYTE UNIX Benchmarks (Version 5.1.3)
    3.    System: beaglebone: GNU/Linux
    4.    OS: GNU/Linux -- 4.4.91-ti-r133 -- #1 SMP Tue Oct 10 05:18:08 UTC 2017
    5.    Machine: armv7l (unknown)
    6.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
    7.    CPU 0: ARMv7 Processor rev 2 (v7l) (0.0 bogomips)
    8.    15:04:51 up 1 day,  4:37,  1 user,  load average: 0.07, 0.02, 0.00; runlevel 2018-01-04
    9. ------------------------------------------------------------------------
    10. Benchmark Run: Fri Jan 05 2018 15:04:51 - 15:33:03
    11. 1 CPU in system; running 1 parallel copy of tests
    12. Dhrystone 2 using register variables        3919998.4 lps   (10.0 s, 7 samples)
    13. Double-Precision Whetstone                      240.8 MWIPS (10.0 s, 7 samples)
    14. Execl Throughput                                359.2 lps   (29.9 s, 2 samples)
    15. File Copy 1024 bufsize 2000 maxblocks         70216.8 KBps  (30.0 s, 2 samples)
    16. File Copy 256 bufsize 500 maxblocks           22050.4 KBps  (30.0 s, 2 samples)
    17. File Copy 4096 bufsize 8000 maxblocks        152534.2 KBps  (30.0 s, 2 samples)
    18. Pipe Throughput                              171521.1 lps   (10.0 s, 7 samples)
    19. Pipe-based Context Switching                  21955.0 lps   (10.0 s, 7 samples)
    20. Process Creation                                961.6 lps   (30.0 s, 2 samples)
    21. Shell Scripts (1 concurrent)                    732.0 lpm   (60.0 s, 2 samples)
    22. Shell Scripts (8 concurrent)                     91.8 lpm   (60.1 s, 2 samples)
    23. System Call Overhead                         304206.4 lps   (10.0 s, 7 samples)
    24. System Benchmarks Index Values               BASELINE       RESULT    INDEX
    25. Dhrystone 2 using register variables         116700.0    3919998.4    335.9
    26. Double-Precision Whetstone                       55.0        240.8     43.8
    27. Execl Throughput                                 43.0        359.2     83.5
    28. File Copy 1024 bufsize 2000 maxblocks          3960.0      70216.8    177.3
    29. File Copy 256 bufsize 500 maxblocks            1655.0      22050.4    133.2
    30. File Copy 4096 bufsize 8000 maxblocks          5800.0     152534.2    263.0
    31. Pipe Throughput                               12440.0     171521.1    137.9
    32. Pipe-based Context Switching                   4000.0      21955.0     54.9
    33. Process Creation                                126.0        961.6     76.3
    34. Shell Scripts (1 concurrent)                     42.4        732.0    172.6
    35. Shell Scripts (8 concurrent)                      6.0         91.8    153.0
    36. System Call Overhead                          15000.0     304206.4    202.8
    37.        ========
    38. System Benchmarks Index Score                                         130.1
    39. root@beaglebone:/samba/byte-unixbench/UnixBench#
    40. Robe-2018.1.6  再次测试的结果。
    2018.1.2   1.6  两次测试的结果几乎无差异
  • 签到天数: 310 天
    发表于 2018-1-3 20:01:22 | 显示全部楼层
    对了树莓派单核还是偏弱的,从网上流传的测试结果来还还不是弱那么一点点,毕竟算是工业级处理器,主频比较低吧~
    GMT+8, 2024-5-10 23:07 , Processed in 0.148572 second(s), 21 queries , MemCache On.
