查看: 1127|回复: 0
明远智睿R16 tinav2.1 常见问题参考手册
    2016-8-19 09:36
    发表于 2019-3-19 11:31:20 | 显示全部楼层 |阅读模式
    1  R16 tinav2.1常见问题
    1.1  分区
    修改target/allwinner/astar-parrot/configs/sys_partition.fex
    例如:
        [partition]
        name        = rootfs_data
        size        = 12582912
        user_type    = 0x8000
    修改其中的size属性,单位: 扇区。
    如要修改成1G,计算方法如下
    size = 1024 * 1024 * 1024 / 512
    1.2  把文件打包到rootfs
    将文件放到package/base-files/files目录下即可。如果文件过大,在pack时报错,修改分区表的rootfs分区的大小
    1.3  增加spi
    1) 在内核中添加spi 驱动
    $cd tinaV2.1
    $source build/envsetup.sh
    $lunch astar_parrot-tina
    $make kernel_menuconfig
    Device Drivers --->
    SPI support --->
    <*> User mode SPI device driver support
    2) 修改
    tinaV2.1/target/allwinner/astar-parrot/configs/sys_config.fex
    [spi_board0]
    modalias = "at25df641"
    sflash_size = 32
    max_speed_hz = 50000000
    bus_num = 0
    chip_select = 0
    mode = 0
    修改成
    [spi_board0]
    modalias = "spidev"
    sflash_size = 32
    bus_num = 0
    chip_select = 0
    mode = 0
    1.4  以太网不可用
    $cd tinaV2.1
    Device Drivers --->
       Network device support --->
          USB Network Adapters --->
             <*> Multi-purpose USB Networking Frameworksuch as cable modems)
             <*> SMSC LAN95XX based USB 2.0 10/100 ethernet devices
    GMT+8, 2024-5-6 05:37 , Processed in 0.113324 second(s), 15 queries , MemCache On.
