查看: 3777|回复: 5
[软件] Uno32控制手机(Siemens CX65)打电话
发表于 2012-8-8 11:47:19 | 显示全部楼层 |阅读模式
原帖由
i7
发自:dev.eefocus.com
一、UNO32和手机连接的照片如下:
将UNO32的串口1和手机的插座,用自制的数据线连接起来。
2、程序如下:
(通过UNO32的串口1向手机发"ATD1368XXXXXXX;"命令,进行拨号)
// set pin numbers:
const int ledPin =  43;      // the number of the LED pin
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;        // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 10*1000;           // interval at which to blink (milliseconds)
void setup() {
  // set the digital pin as output:
  pinMode(ledPin, OUTPUT);
  Serial1.begin(9600);
void loop()
  // here is where you'd put code that needs to be running all the time.
  // check to see if it's time to blink the LED; that is, if the
  // difference between the current time and last time you blinked
  // the LED is bigger than the interval at which you want to
  // blink the LED.
  unsigned long currentMillis = millis();
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    previousMillis = currentMillis;
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW)
        ledState = HIGH;
        Serial1.println("ATD1368XXXXXXX;");
    else
        ledState = LOW;
        Serial1.println("ATH");
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, ledState);
3、一点说明
(1)UNO32的输出是3.3V的,手机的输入也是3.3V的(超过这个电压,手机会关机),用UNO32和arduino相比,省去了电平转换的电路;
(2)使用串口1向手机发送命令,串口0用来升级程序或向电脑打印信息,方便调试程序;
(3)应用:可以在UNO32上接上若干传感器,比如温度、湿度、光线强度,达到预设的值后。自动拨打设定的号码,进行报警;此外也可以通过发短信的方式,传送更丰富的内容;
(4)手机数据线定义见此网址:http://pinouts.ru/CellularPhonesCables/siemens_dca-510_pinout.shtml
  • 签到天数: 1341 天
    发表于 2014-1-7 23:15:01 | 显示全部楼层
    多谢 学习啦!
  • 签到天数: 189 天
    发表于 2014-1-14 13:36:23 | 显示全部楼层
    黄色的板子,好像之前看到的都是红色板子呢
    发表于 2014-1-14 13:42:46 | 显示全部楼层
    不是有卡的模块吗.
    发表于 2014-6-25 08:57:47 | 显示全部楼层
    顶你一下,好贴要顶!
  • 签到天数: 980 天
    发表于 2016-3-2 09:03:37 | 显示全部楼层
    不错  真好
    GMT+8, 2024-5-9 08:20 , Processed in 0.151837 second(s), 25 queries , MemCache On.
