楼主: 乖乖妮
9月8日下午14:30-16:00线上技术支持讨论专用贴(直接回复)
发表于 2016-9-8 16:44:06 | 显示全部楼层
RuiJack 发表于 2016-9-8 15:22
手机APP的情况,其中的校验机制不是很人性化,实际调试过程中,遇到干扰或其他原因造成的通信错误,会导致 ...
It is more practical to shut-down the motors if connection is somehow lost. Thats's why it's implemented like this
发表于 2016-9-8 16:44:49 | 显示全部楼层
那些埋头写程序的岁月 发表于 2016-9-8 15:31
can you give me a detail  ideal about how to use DAVE4 ?
A tutorial for flashing the firmware in DAVE4 will soon be released in the GitHub repository
发表于 2016-9-8 16:45:41 | 显示全部楼层
RuiJack 发表于 2016-9-8 15:32
in some case ,the daisy chain will stuck in loop, for the serial data lost one or more byte.then,  ...
Please update to newest flightcontroller Firmware. Please also update the PINUS Motorcontroller Software, you will need a XMC Link Debug probe to do so
发表于 2016-9-8 16:46:36 | 显示全部楼层
bilibiliba 发表于 2016-9-8 15:42
问题:
请问是否有虚拟串口的驱动提供?有些电脑的系统不能自动安装。
There is a virtual com-port driver available. Will be uploaded to GitHub. However we recommend debugging the Application using microProbe for XMC
发表于 2016-9-8 16:47:10 | 显示全部楼层
wakakak 发表于 2016-9-8 15:44
recently,we found some problem about the bluetooth. it show that connection is proper. but the dive ...
It is not an issue concerning the Bluetooth Connection. Please update the Firmware of Flightcontroller and ESC's
发表于 2016-9-8 16:47:13 | 显示全部楼层
Tim_Hu 发表于 2016-9-8 16:01
Maximum amperage for one phase is 6A. 6for U, 6A for V and 6A for W
好的谢谢
发表于 2016-9-8 16:47:55 | 显示全部楼层
牛闫牛闫 发表于 2016-9-8 15:51
不用XMC_FLASH,用编译环境烧程序会有这个问题
If you already have a debug-session up and running then you have to stop it before flashing again
发表于 2016-9-8 16:48:32 | 显示全部楼层
RuiJack 发表于 2016-9-8 15:52
Oh,one more .
About the USB VCOM Drivers.
with DAVE3 on WIN10,It will be installed automatically
please refer to #65
发表于 2016-9-8 16:51:17 | 显示全部楼层
It is not an issue concerning the Bluetooth Connection. Please update the Firmware of Flightcontroller and ESC's.
发表于 2016-9-8 16:51:50 | 显示全部楼层
那些埋头写程序的岁月 发表于 2016-9-8 15:54
Can you give me a group of right PID parameter?
The right PID-Parameters are availabe in the source of the new Dave4-Version of the firmware
GMT+8, 2024-5-3 02:21 , Processed in 0.196989 second(s), 31 queries , MemCache On.
